been having a problem every now and then with my Profec A boost controller
Every now and then the overtake boost button fails to work - this is essential as its needed for re-programming. It also drops back to stock boost every now and then, then returns to the set boost. Its very wierd,
Just wondering if anyone else has had this problem, and if mine if rooted and requires replacement?
Chris
https://www.sau.com.au/forums/topic/41981-greddy-profec-a-problems/
  • 3 months later...
just wondering if u ever found the solution to ur profec A problems. i am having one atm where it will return the car to stock boost settings (as if its spiking and overboosting) but it isnt overboosting.. its anouying, it happens alot on downshifts when boost comes on hard... i was thinking cleaning the stepper motor or something?
Kinda, as I found another Profec A control unit on ebay
I'd make sure your power and earth wires are located to a good power source and try re-proggraming it again and see what happens
I would doubt it would be the stepper motor, they usually just stop working all together
Chris
the unit itself is very stable. the power is always maintained and the overboost alarm never comes on.... when it swtuffs up it will readch 10psi then instantly drop to 7psi. happens alot when i dont boost right througha gear, say start at 3000rpm+ and nail it... i was thinking something like a ratio control, but it doesnt have one...
do u think this could happen if it wasnt able to bleed off air fast enough..l atm my bleeder nipple isw position just away from the rengine bay wall. i will try and move it for better airflow just incase..
i'll try a reprogram and include the downshifts in the learning procedure...
other then this th controller has been good.. brings on boost faster and sits neatly in my ash tray :D
I had this problem when i was running mine of a less than optimum power source
I also re-programmed mine after I re-wired it, and it seemed to work. I found in the P1 learing mode, drive it around for a good 20-30 minutes boosting it as much as possible so it learns all the ways boost comes on. It will be much more stable from doing this, then press the OTB button so it goes into P2 and give it one more run in 3rd full boost to max revs and it should work fine - hopefully
Do you run a small inline filter going to the solenoid?
na i didnt get a one with it. ive heard they are more trouble then they are worth.
I'll try the rewire thing, atm its comming off my ciggy lighter 12v... it used to only happen randomly/rearly, but the other night it wasnt holding hardly any runs, so its prompted me to fix the situtation..
also, if u do the P1 learning the idea is that
You to a few runs runing the car to redline in 3rd gear then for the p2 u do the same by up to the redline in 4th gear.
Mine works perfectly im running it off the fuse box its connect to the same wirer than runs my sound system + i add a fuse just incase it got to much power
i thought that the . means .05 of a bar? so 0.9. = 0.95
anyways been using the B more, and its great. Holds boost perfectly, the same everytime, and i have gained more power for some reason. must be the balance as ive set it to hard and it builds like a mother. Only thing i have to sort out is the different boost/2nd and 3rds. i get 1psi exactly more.
So yeah. Bspec is cool. same results as a perfectly tuned A out of the box!
also the solenoid doesnt make these funky noises like the a-spec does!
only bad side so far of the B is that it doesnt have a boost readout. so when ur setting boost u dont know how much until u try it out and check the boost gauge.
    • Yeah they charge a little extra for mods , last year I noted no mods but I did have an exhaust fitted after that so  better to let them know cause these kinds of things can cause the policy to be void if you ever need to claim.
    • Hello, just just bought an 1999 enr34 with a stock rb25neo and I'm looking to upgrade the engine to 500whp I know some basic things but wondering if there are things I'll need to do to upgrade the stock block and all the bits and pieces to achieve this.
    • Thanks everyone for the replies and suggestions. Got the seats out (hoping I could find some existing grommets but no such luck). By tapping and measuring etc. I could figure out where I could drill through if needed. But first I borrowed an inspection camera and managed to go through factory holes in the chassis rail and could see that the captive nut was holding steady which is why it could retighten. So it was indeed a stripped section of thread, so I applied downforce by levering the bolt head with a screwdriver and went slowly back and forth until it came out. Camera helped a lot cos I could monitor that the captive nut was holding tight. Now I just have one very seized main subframe nut to tackle 馃槄
    • BOVs do have a purpose, if you ever log pressure before and after the throttle body, you will see a spike pre throttle on lift off from a WOT condition. Enough to bend throttle blades / damage e-throttle motors or simple assist in blowing off cooler pipes. FWIW, the above on really applies to those running at least 2 bar of boost. OP shouldn't have an issue, on the other hand, here are some videos of my shit box over a decade ago with some succulent dose with the airbox on and off. That shit box is unrecognisable these days 馃珷
    • I've tried all different combinations of BOVs/ no BOV and stock bypass valves over the years, on gear changes the stock bypass valve seems to get the car back on boost quicker because in part the turbos wheel speed isn't being slowed down by reversion, although they have issues holding boost much over the stock setting. Most aftermarket BOVs you can adjust the spring, tighter will make it open later and close sooner, but in my experience it'll cause a bit of flutter at low load/rpm anyway. I've also got some input into this whole no bov causing turbo wear, never had an issue on any on my turbos HOWEVER, I got my R33 GTST with 200k kms on it, with from what I can see still has the original turbo, no lateral shaft play but has about 4-5mm of play in and out which to me seems like a worn thrust bearing from years (100-150k kms?) of turbo flutter running no bov, so maybe there is some truth to it in the long run. But that'll never stop me loving the Stutututu while I have the car.   OP just wants to know if he can run a atmo vented BOV with no major issues and the answer is YES, plenty of people do it, there's no harm in installing it and seeing how it runs before spending $$$ on an aftermarket ecu, last time I bought a Nistune it was $2400 for install and a tune , unsure of todays prices but you get me. Crazy money to spend just to fix the minor inconvenience of stalling that can be overcome by letting the revs come down to near idle before putting the clutch in or a little bit of throttle to avoid it. You're better off leaving the ecu and tune for after a bigger turbo/injectors have been installed to take full advantage of the tune and get your moneys worth.   Let OP have his Whoosh sound without trying to break his bank haha
