copycutter Posted February 12, 2013 Share Posted February 12, 2013 A while ago my ABS warning light lit up on my dash, and naturally I ignored it for a while However I eventually got around to an auto electrician and they diagnosed the fault via OBD2 cable. Here's what they wrote on my receipt: Run diagnostics test. Find ABS motor fault. Code said: ABS Motor (off failure) I did some searching here on SAU and saw some threads about how the relays attached to the ABS motor (black box with plugs) is a common fault. My symptom also matched someone else who had this problem. If I hold the brake pedal and start the car, no ABS warning light comes one. However as soon as I release the brake, ABS light comes on. Today I went to a wrecker and managed to pick up one of these black relay boxes, and plugged it in but same issue, ABS light still on. Does this mean that it's likely the actual ABS motor is failed? Should I look somewhere else? Link to comment https://www.sau.com.au/forums/topic/419822-abs-fault/ Share on other sites More sharing options...
xntrq Posted February 16, 2013 Share Posted February 16, 2013 I've got a R34 ABS motor for sale if you need Link to comment https://www.sau.com.au/forums/topic/419822-abs-fault/#findComment-6753966 Share on other sites More sharing options...
copycutter Posted February 18, 2013 Author Share Posted February 18, 2013 Thanks man, but it turned out to be the relay after all. To everyone with that abs error, go to a wrecker and try the relay. Try multiples to make sure. Link to comment https://www.sau.com.au/forums/topic/419822-abs-fault/#findComment-6756362 Share on other sites More sharing options...
