Alright so last Friday i had my brand new CD009 transmission (06-07), SS clutch lines, new pivot ball, new throw out bearing, new rear main seal, Southbend clutch & flywheel installed. Along with this i put brand new Amsoil 75w90 gl4 gearbox oil, and Penrite SIN 600 brake/clutch fluid.
Now for the issue-
When i drove the car home from my mate/shop owner i noticed that when the clutch is engaged whilst driving and changing gears, there is a sort of rubbing or gurgle noise. It is very hard to explain but if you can sort of imagine the clutch spinning and then having something solid behind it rubbing against it. Now when the clutch is engaged but the car is still, there is no noticeable noises that are the same as the one i hear while driving. Also when i downshift and rev match, the noise gets louder since i am reving the motor while the clutch is engaged then releasing when i reach the same RPM.
Before anyone says flywheel chatter it's not that, the new flywheel is only a little bit lighter than the factory dual mass flywheel and makes the same normal chatter i always here when accelerating from a stop.
I have been searching the internet like crazy and asking mates that have a lot of experience with cars and no one seems to be able to give me a definite answer without obviously driving the car.
Some people are saying that it's normal for a copper mix clutch and that there is a "bed in period" of around 500-1000km, others are saying to flog the car do skids and see what happens lol.
I got in touch with Coz from ConceptZperformance in the US who supplied me the parts. I explained the problem to him and he basically said that he's never heard of this happening before with the Southbend setup and he seems to think it's got something to do with the installation of the parts. But the bloke that did it has a great deal of knowledge and says he didn't come across any hurdles when installing everything and he can't understand the problem. He's just said to drive it for around 500-1000km or until the noise stops, then take it back to him and he'll check it out.
I know this is a huge thread but it's annoying me a little bit, i have driven probably 300km since then and have not noticed the noise getting quieter at all. If anyone has any actual knowledge on copper mix clutches or have a clue what the problem could be, please share your knowledge and help me out.
Thanks!
Anyone have some sort of input? I'm getting it looked at again this Sunday, texted the bloke that did it saying i don't think it's going to improve and he's happy to check it out for me. Also last night driving home i got a strange shudder through the gearknob but only while coming to a stop going from 3rd to 2nd gear then it stopped. Was weird.. didn't happen this morning though coming to work.
I used a brand that was recommended in the DIY servicing section on here-
Clutch fluid:
Brand: Penrite SIN 600, Motul RBF 600
But as i said, the clutch engages and dissengages with no noticeable noises and have no problems changing gears. I was just speaking with another mate, he thinks it could be something to do with greasy hands while bolting in the flywheel and clutch, and possibly the rust-proof seal on the face of the clutch and flywheel have not been removed?
Far as I can see your options are
1) keep driving on it, clock up the 1000km's using the bedding in technique - see if it stops.
2) if that doesn't work, drain fluid, replace with recommended CVT fluid - see if it stops
3) if that doesn't work - drain fluid again, keep it in a container. Drop box and investigate - see if it stops.
4) if that doesn't work - clutch dump time*. Got a video of me doing a 1st to 2nd* gear burnout if you want guidance.
*SMOKEYV35 does not recommend or condone these activities in real life.
Thanks Mat,
Well i have the car going in on Sunday again, everything has been installed correctly i have been quizzing my mate that did it to try and rule anything out that may be incorrect but it all seems to add up.
Haha i'm not too confident that will fix anything, i don't think that's a good idea :P
But if we have no luck at all this Sunday, i guess the first thing would be to do is change the clutch fluid
So there is perhaps something different between the boxes? You sorted out the pivot bolt already, right? Could it still be the wrong length?
Have you compared the size of the input shafts? Was the pilot bushing lubricated/replaced? Perhaps the throwout bearing is faulty? All these are things than need to be checked while it's on the hoist. What makes noise is slowly wearing so you should keep an eye out for metal flakes etc. It should be fairly obvious I imagine.
Well, my 03 comes with a small pivot ball. But the 04-07 came with a longer pivot ball. The box was originally installed with the new pivot ball, which is too long, everything was then bolted back up but the clutch couldn't be adjusted because of that so the old pivot ball was put back in. It was not faulty at all, i made sure my mate checked. Brand new throw out bearing so i'm not sure how that would be possible. I will see if there's any difference between input shafts too but i was under the impression by many individual and Coz himself that this CD009 gearbox is a direct replacement of the CD001 the only difference is pivot ball. Everything else should just bolt straight up and have no issues. Car is going back on the hoist this Sunday so we'll see i guess.
Scotty-
i asked the questions that you asked me, to the bloke that fitted it. This exactly what he replied with-
"yeah pilot bush was replaced, and lubed by oil under pressure, til it leaks out of the bush. Didn't check shafts, but it won't be different, that's a common size on all nissans, my SR20 clutch tool fits perfect into your clutch"
    • Oh yeah forgot to also mention need to also unplug the IACV as well. Thanks for the reminder @MBS206 Unplugging the TPS takes it out of closed loop so you're able to screw down the IACV without the ECU trying to add/subtract timing to maintain the idle (not sure PowerFC can even do this, but Nistune and the OEM definitely does)
    • For sale is my 1999 Nissan Skyline R34 GT-T, tuned to 234 kW / 313 hp. I've had the car for a few years as my daily driver. The car is original (as far as Skylines go), with only a few minor upgrades to enhance performance and driving experience, as typical for such a car of its age. Overall, it is in great condition with no body rust, thanks to its earlier import date. It features a top-notch security system (not literally, but it's great!) with remote start and still functional 4-wheel steering via HICAS. It comes with several performance and handling upgrades, including:     Hypergear 450HP Turbocharger running 17 PSI boost, installed mid-2021 by Jaustech     550cc injectors     Nistune ECU     Front-Mount Return-Flow Intercooler     X-Force Stainless Steel Exhaust     Upgraded engine mounts     Bottom end bearings replaced     BC Coilovers     Lenso DR1 rims     Bridgestone Potenza Adrenalin RE003 TL 245/40R18 97W tires, fitted early 2023 The interior is mostly stock, with a few additions:     Viper Satellite Tracking System with remote start     Bluetooth Double-Din Touchscreen Head Unit     Steering wheel cover Cons:     A few paint imperfections here and there     Driver’s seat shows more wear than the others. It's not torn at all, but I've added a seat cover to protect its condition. I also have a CarVX Vehicle History report available for serious buyers, so you don’t need to purchase it yourself. Price: $26,000 ONO.
    • I've had two suzukis in the past have an extremely hard time turning over and not starting after sitting for a few weeks. Ended up the alternator would seize up causing the starter to force. Same issue both times.  Maybe they're sourcing their alternators from the same place...
    • Ah right. Maybe my rb just loves chewing through batteries lol.
    • On the R34 can't you just unplug the IACV? This is the way I've always done it on the R33. Disconnect IACV, get it idling around 650rpm, and then do a power reset on the ECU to get it to relearn idle (factory ECU).   The big reason no one has touched on as to why you'd want to get the base idle right, is that it means the computer needs to make smaller adjustments to get a good idle at 700-750rpm.   Also, cleaning the IACV won't normally make the car suddenly idle lower or higher. The main issue with the IACV gumming up is that the valve sticks. This means the inputs the ECU gives, aren't translating to changes in air flow. This can cause idle choppy ness as the ECU is now needing to give a lot of input to get movement, but then it moves too far, and then has to do the same in reverse, and it can mean the ECU can't catch stalls quickly either.
