No need to explain why you had that photo handy Dale... We understand... :P
Only chicks I saw at Golburn were you and Craig, Alex.
Guess I had that coming. :unsure:
receptionist....?
Forgotten that, or was that Artz?
That was Artz drooling. :)
Yep. :P
On topic, have there been any strange noises under your bonnet yet Dale? Swearing and the like?
Yep. :P
Lol, how did you know? :whistling:
It's all fitted, and I'm pretty sure it's leak free now. Entirely my own fault; I should've known better, I re-used the OEM clamps on the Bleed block. :domokun:
Rookie error.
Ended up stripping right back to the valley, as I wasn't 100% sure I didn't have a leak on the bottom AN fitting. Ended up the coolant was sneaking down the inside of the Fireproof sleeve and pooling behind the plate in the valley.
Hose was perfect length, and with a tiny amount of detergent and a cup of boiling water to soften the hose; went together without issue.
EVERY SINGLE PHOTO I took has somehow been deleted from my camera, (4 year old camera aficionado to blame here), and I'm not pulling it down again. :no:
I haven't had a chance to drive it far yet, so I'm not sure of the improvement, but going by the slug of air trapped in the valley; it can't be worse.
  • 8 months later...
hey Rudi did this fix your issue? i got the same noise going on.. and same vibration through the throttle peddle... noise is far my noticeable above 70kmh for me.. hope its BOV and not something more sinister :)
Edited by Sage222
no love? that's ok i got under it on the weekend. front right wheel bearing needs replacing
Have you had the CV boot replaced recently?
Mine failed after it was disturbed when I had the CV repaired.
sorry, have not been on a while yes it was bov , all sorted :yes:
thats pretty scary.. yeah had a CV boot replaced about 10 weeks ago.. i watched the guy do it.. seemed to do it well.. have checked it its still intact..
I think pressing the shaft out of the wheel bearing is the straw that breaks the camel's back (so to speak) on bearings right at the end of their life.
Amayama is the best source for replacement bearings; buy a pair & make it worth the postage. ;)
Pretty much at any time of their life. Front (Flat) roller bearings require sufficient clamping force (the tightened driveshaft provides this), for correct operation. So, any excessive pressing/hammering/bashing of the shaft to remove it from the hub, will most likely kill the bearing.
If, for any reason, the car needs to be moved with the driveshaft removed, the outer cup needs to be removed from the shaft, refitted to the hub & tightened, or bearing failure WILL occur.
    • Also did some work to the shed and a massive clean out of stuff. It's now got a small fab/dirty room and has helped keep shed cleaner. Built some new work benches and re organised things also got a TV out there so good having something playing while working on the cars. Got a pedestal drill and linisher off a mate that need to pick up too.
    • First thought, have your current injectors flow tested. If they test fine, keep the diagnostics going. It's not the injectors. If the injectors are the issue, find some new or used (cleaned and flow tested) injectors.  While I really love a good excuse to get a modern ECU installed, just needing new injectors probably isn't a good enough reason to do so.
    • A bit from column A, B and C. Mainly C   Update time, after deciding it was time to tick off a bucket list goal I finished up full time at MSR and have gotten back behind the wheel and making progress on the S15. Goal has been to drive Bathurst at an event and I have had my entry accepted for Challenge Bathurst in November. Since I don't want to go unprepared I need it running to test and get comfortable.  Been chipping away at it and started by stripping inside, getting it all cleaned and sealing some holes up. With stripping inside I removed the whole wiring loom and found a few surprises.......... its pretty butchered and shit branching and I'm not a fan of the haltech fuse boxes so it's all out and trying to come up with a plan to rewire it all either new fuse/relay box or pdm.  I haven't been happy with how I did the intercooler mounting and been wanting to tuck it up under rad support. O e issue with that is headlights will need a decent trim or get replacement covers. Took the time to mount it with some stand off's and new hardware. Stands are some m8 button bolts, washer, aluminium tube and factory radiator top mount rubbers. It's nice and solid also stiffens rad support which still requires some trimming. Bonus of factory rad mounting is used all factory hoses just need to weld a pressure cap to radiator now. Got sensor block and fuel filter mounted. Plan today is to get vac lines all sorted with push in nylon tube and design oil cooler mounting solution.  Been driving BRZ a heap and went out to Morgan Park for time attack and went pretty well for a wet day. https://youtu.be/gAlQgcQpWj4?si=kojOAOjhhX_X3AXR Getting pretty comfortable in it now and want to do a few more bits to it but restraining myself as don't need 2 race cars at the moment.
    • @sunsetR33 There is obviously a huge culture gap here. There is nothing in place like this in Australia, where if you fit a Mines branded pipe and later replace it with a Jun branded pipe, both pipes are essentially identical - BAM - huge penalties! Where is the Mines pipe?? You can't have a Jun pipe when you said you had a Mines pipe!  Makes no sense to me. Surely makes no sense to anyone else here either.  I'm sure a lot of us would agree that our registration/engineering system is pretty stupid at times, but it's not that stupid.  *** More serious question here. If you replace a factory rubber hose with a silicone hose, is the car illegally on the road now? Does it become legal if you have certification of what brand the silicone hose is? Then would it become illegal again if you replaced that silicone hose with a difference brand of silicone hose? And then would it become legal again if you had certification of the new brand of silicone hose?  I really want to know that answer to that question.
    • Good you making progress with this rig. Aluminium welding is painful to learn, have you got a pedal as I found it so much easier with one. If that's the AMG I think it is, you would working with Benny?
