Hi,
I tried searching the forum, but just ended up with more questions (or multiple different answers to mine), hoping someone can help me. And it all relates to a 2003 Coupe.
1. Does anyone have detailed before and after photos of a coupe converting to 350z springs
2. Are all 350z springs the same, or are there different rates and lengths etc
3. My V is a 2003 model, what range of year models should I be looking at in 350z's
4. I'm lazy, so anyone got a rough ballpark idea of how much I should expect to pay a garage to fit them?
5. from my understanding, I should expect a 1" drop. But have have read posta saying to only expect 0.5 and others say 1.1". Is it a known quantity, if so what?
6. Anyone got some for sale (I'm in Sydney)
Thanks in advance.
Edited by vee35
I thought the track version 350z had lower springs, i would only expect 0.5 too nothing more. Installation on a full set of 4 springs would probably take a professional max 2 hours so i'd say anything more than $200 is a rip off but it's not very difficult to DIY.
Sheldon2369 had the 350Z springs, and his car looks like it dropped more than 0.5 of an inch, but he also has a body kit which may help give that impression. Maybe the track version is lower, and it gives 1". I found it also confusing as you have to be careful to check if your reading about a coupe or a sedan. Hopefully someone will know for sure.
I took this from one of his posts, as his "before" photo:
and from his carsales add, looking at his rear wheel, I think it looks at least an inch:
cp5716328642610073470.jpg?height=350&aspect=FitWithinNoPad&width=525
As for DIY, its a tool, location and time thing. If its left for me to do, it wont happen.
I believe the coupe is 0.5in lower than the sedan as standard, so 350Z springs drop a sedan 1in and a coupe 0.5in.
The G35 guys like to a 'G/Z combo' on their sedans, which is 350z springs in the front and coupe springs in the rear as that seems to make the gap between when wheel and the guard even all round.
I believe all 350z springs are the same height, but they did do a revision of the rear spring rate at about 04, they made them firmer.
have a look here. it gives some good info on how to identify the springs on their colour markings.
http://g35driver.com/forums/brakes-suspension/211105-z-springs-front-coupe-springs-rear-id-reference.html
    • Ah right. Maybe my rb just loves chewing through batteries lol.
    • On the R34 can't you just unplug the IACV? This is the way I've always done it on the R33. Disconnect IACV, get it idling around 650rpm, and then do a power reset on the ECU to get it to relearn idle (factory ECU).   The big reason no one has touched on as to why you'd want to get the base idle right, is that it means the computer needs to make smaller adjustments to get a good idle at 700-750rpm.   Also, cleaning the IACV won't normally make the car suddenly idle lower or higher. The main issue with the IACV gumming up is that the valve sticks. This means the inputs the ECU gives, aren't translating to changes in air flow. This can cause idle choppy ness as the ECU is now needing to give a lot of input to get movement, but then it moves too far, and then has to do the same in reverse, and it can mean the ECU can't catch stalls quickly either.
    • 12.8 for a great condition, fully charged battery. If the battery will only ever properly charge to about 12.2V, the battery is well worn, and will be dead soon. When I say properly charge, I mean disconnect it from the car, charge it to its max, and then put your multimeter on it, and see what it reads about an hour later. Dieing batteries will hold a higher "surface charge", but the minutest load, even from just a multimeter (which in the scheme of things is considered totally irrelevant, especially at this level) will be enough over an hour to make the surface charge disappear.   I spend wayyy too much time analysing battery voltages for customers when they whinge that our equipment (telematics device) is causing their battery to drain all the time. Nearly every case I can call it within about 2 months of when the battery will be completely dead. Our bigger customers don't even debate it with me any more ha ha ha. A battery at 12.4 to 12.6 I'd still be happy enough with. However, there's a lot of things that can cause a parasitic draw in a car, first of which is alarms and immobilisers. To start checking, put your multimeter into amps, (and then connect it properly) and measure your power draw with everything off. Typical car battery is about 40aH. Realistically, you'll get about half this before the car won't start. So a 100mA power drain will see you pretty much near unstartable in 8 days.
    • Car should sit at 12.2 or more, maybe 12.6 or 12.7 when fully charged and happy. If there is a decent enough parasitic load then it will certainly go lower than 12.2 with time. You can't beat physics.
    • Ok guess I can rule out the battery, probably even the starter and alternator (maybe) as well. I'm gonna clean those leads and see what happens if it's still shit I might take it to an auto electrician. Unless the immobiliser is that f**king heavy, but it shouldn't be.  If I start the car every day, starts up perfectly never an issue. Isn't 12v low, shouldn't it be around 12.5v?
