Looks like someone went to an awful lot of trouble to give no f**ks. :rolleyes:
awful lot of trouble = 2 years of delivering pizzas.
im not bagging the kid out. good on him. i really want to like the car, but i cant for some reason. i appreciate the work and love he put into it though
Here's a kid who looks like a total hippie, who has never had a drop of alcohol nor a puff of weed. He makes a shitty living and lives in his parents house while he goes to enginering school. And yet he was able to save up $13,000 to put into go-fast shit for his car. All the mechanical bits on the car are totally legit stuff that you'd see on a proper track or project car, and not a dime was spent where it didn't need to be spent. It runs cool and smooth. It required no fine-tuning at the last minute like all these "pro" tuner shops do before we film their cars. It's fast as f**k. 2400 lbs and 330 whp is no joke. And the kid knows the car inside and out, can fix anything with basic tools very quickly, and drives it ridiculously fast and with skill. One of our cameramen, Zack, took a ride with Corbin up Stunt Rd, where Corbin does his "testing," and said that he had never been up Stunt that fast, in any car, at any price, with any driver.
its kinds cool, a bit try hard, theirs plenty of f**ks given trying to look cool but atleast hes taking the piss a bit.
supprised how many times i have seen this posted though, i sont see the huge big deal. still good on him, hope he gets lots of love and hate and keeps going.
This thing is the epitomy of all internet car fashion and related memes. Pedo bear sticker, V8 conversion, rusted look, steelies, etc. It's like he put together a shopping list of shit that was cool in the last 3 years on speedhunters and built it.
He forgot the roof racks with a bmx and some fuel cans, random stickerbombing, and of course a bushy hipster beard for himself. Probably too young to grow one
Can't grow one, he clearly has a giant gaping vagina
    • Update: I got the magnet out. I bought 3 different flexible magnetic reach tools, but none of them worked. The magnet on the tip was all less than 2lbs of force, so i had to buy a special cylindrical magnet that had a pull force of 9lbs.  The magnet finally came in the mail yesterday, so i got under the car to get to work. The super strong magnet isn't that long, so i only have about 1 finger pinch lengths to hold it. I was so scared when i was going in the hole, that the 9lb magnet would just fly away inside the oil pan never to be seen again, but i had my butt cheeks clenched and finger gripped on that thing so tight, i managed to get it to suck the other magnet out.  It was a victory for me last night.
    • Yep, pretty much what you said is a good summary. The aftermarket thing just attached to the rim, then has two lines out to valve stems, one to inner wheel, one to outer wheel. Some of the systems even start to air up as you head towards highway speed. IE, you're in the logging tracks, then as speeds increase it knows you're on tarmac and airs up so the driver doesn't even have to remember. I bet the ones that need driver intervention to air up end up seeing a lot more tyre wear from "forest pressures" in use on the highway!
    • Yes, but you need to do these type certifications for tuning parts. That is the absurd part here. Meaning tuning parts are very costly (generally speaking) as well as the technical test documentation for say a turbo swap with more power. It just makes modifying everything crazy expensive and complicated. That bracket has been lost in translation many years ago I assume, it was not there.
    • Hahaha, yeah.... not what you'd call a tamper-proof design.... but yes, with the truck setup, the lines are always connected, but typically they sit just inside the plane of the rear metal mudguards, so if you clear the guards you clear the lines as well. Not rogue 4WD tracks with tree branches and bushes everywhere, ready to hook-up an air hose. You can do it externally like a mod, but dedicated setups air-pressurize the undriven hubs, and on driven axles you can do the same thing, or pressurize the axles (lots of designs out there for this idea)... https://www.trtaustralia.com.au/traction-air-cti-system/  for example.... ..the trouble I've got here... wrt the bimmer ad... is the last bit...they don't want to show it spinning, do they.... give all the illusion that things are moving...but no...and what the hell tyre profile is that?...25??? ...far kernel, rims would be dead inside 10klms on most roads around here.... 😃
    • You're just describing how type certification works. Personally I would be shocked to discover that catalytic converter is not in the stock mounting position. Is there a bracket on the transfer case holding the catalytic converter and front pipe together? If so, it should be in stock position.
