I can't make it this year, but I am dead keen to get there one year. Good luck Tom
Anthony, they block off a section of the old lakes way near bulahdelah. A bit like the old pac highway, an absolute blast to drive with no speed limits :)
sounds good.
will have to try one year.
ah yea i drove that bit of road recently.. its good fun.
Cheers.
The Bulahdelah hillclimb is organised twice yearly on the challenging hill of the Bulahdelah Mountain crossing of the old Pacific Highway. Now bypassed by the modern highway, the course is set in pristine bush land and just to be there for the day is a relaxing family experience. Throw in the excitement of the climb and you have a great day.
Newcomers welcome! Participating in this event qualifies you for a full competition licence for 12 months at the very much reduced rate of $50.00!
Qualified official? We need you on the day, please join us in the day's fun.
For entry and supplementary regulation details, visit our web site on
e-mail enquiries are welcome on
Entry $120.00
For visitors to our area, accommodation of your choice can be selected at the following web sites:
www.tripadvisor.com.au
  • 3 weeks later...
Cancellation of Hillclimb Event March 2013
We regret that we have had no option but to cancel the March Hillclimb. This has been due to there having been insufficient entries. We have noted that at this time of the year, several other events are on offer so we attract a few less competitors.
There may be a few who would want to turn up on the day, but we cannot plan for this, the costs of staging the event, unless covered by entry fees would see us unable to continue in the longer term.
So we hope to see you at our next event, which we believe at present will be held on September 22nd 2013.
0408 290 286 OR 0403 748 629
    • Would love some videos, and if Jackie is keen maybe even a fly by.
    • This place doesn't sound good at all, what a shame. Losing one customer is losing out on more potential customers.
    • My guess? Almost perfect separation. The pressure pulses would bleed across, but because they have to squeeze through the gap, they will be substantially attenuated. Given most twin gates are plumbed back to atmosphere..... I would say that experiment is well understood. But in reality, it would make no difference to spool at all, if they are 2 completely separated gates. What happens downstrema of them will not affect spool at all.
    • Look, it's very simple. The 6 bolts or the 9 bolts are interface between the clutch and the flywheel. Any flywheel will bolt to any RB crank - the bolts in the centre there are the same same. So, you just need teh flywheel to suit the turbo clutch. That's all. No more to think about. Get both, boost off into the sunset. (only without the boost).
    • Correct ~ fuel gauge receives power (usually about 10volts) from a linear regulator on the cluster board (gives a stable reference voltage), and as you say, via a variable resistor to ground (float level) ; high resistance when tank empty, a low resistance when tank full. As you surmise, if the fuel sender wire was shorted to ground, there'll be full defection of the fuel gauge needle. I haven't got an R34 wiring diagram, but going by the R33 spaghetti schematic, about the only thing common here between headlight & fuel gauge circuits is the SMJ connector...
