Hey guys,
Long story short is I have taken my exhaust off to try get its measurements and work out what could be a restriction at 250rwkw.
I do not understand the results and where to go from here. The dump results confuse me and after the muffler to the cannon is an odd number.
To me the results are all over the place.
Results were acheived by either measuring the circumference and using an online calculator to get the diameter or measuring across the exhaust and just getting the exact diameter.
Cat pipes = 2.5inch (calculated by circumference)
Cat flange = 3inch (exact diameter)
Dump = 3.35inch (exact diameter)
After cat to muffler = 3.5inch (calculated by circumference)
After muffler = 3.88inch (calculated by circumference)
https://www.sau.com.au/forums/topic/419906-confusing-exhaust-sizes/
  • Replies 44
AFAIK they usually rate stuff by internal diameter not external diameter, so the pipe wall thickness will be skewing your results. Your cat looks like the problem with those 2.5in pipes. If its not already a metal matrix 100 or 200 cell one, around 4inch core, you'll probably get good results from a change there.
Hey Daniel - the first is a decat pipe 3" the second cat in the photo's i sent is this -> "metal matrix 100 or 200 cell one, around 4inch core, you'll probably get good results from a change there"
As I said earlier in another post on this subject in the ACT section. Cats are genrally not the issue in restricting air flow (that is if they haven't collapsed). The muffler is
All this stuff about Catalytic converters and cfm ratings is mostly BS from people who wish to sell you there product.
Decat is obviously better as it has NO internals so absolutely no issue - EXCEPT it breaks EPA regs.
@250 kws with your decat (cat with the guts ripped out) and turbo is NOT your issue. Add 100kws to that and then start thinking about restricted air flow.
I'll go measure both internal diameters if I really have to. Tis better if you just come check them both out.
Will organise to come check them out possibly this weekend. My main thought was the whole exhaust ranges from 2.5 inches to close to 4 inches at the end.
Gases flowing from the larger dump and hitting the cat that has pipes going into that are 2.5 inches would have to restrict right?
Or should I be focusing on getting rid of my muffler and stupid cannon and going a different route?
True it's a science I dont understand either.
Logically the best system would be the same internal diameter from inlet to outlet.
Spose what I am saying is I dont think your pulling and pushing enough air for it to be an issue. Not yet any way...
Hmmm not sure what else would be restricting my setup compared to all the other hypergear guys.
They all seem to be making the same power or better on lower boost. Everything else on my setup is similar or better then what others are running. Only thing I haven't touched is this exhaust.
Possibly this muffler and cannon then?
I'll take it for a brap around the roads with and without the cat etc and see if I find a difference
Why dont you drop the exhaust from the cat back and test to see if it is creating a restriction.
It would show on a dyno if it is the cause of the restriction. I thought hypergear recommend tuning like this first? Also are the other results on the same dyno?
Just the fact without the cat, muffler it is crazy loud.
Then when you chuck it all back on its fairly quiet in comparison.
Less noise = more restriction?
Also that I feel with my setup I should be making more power.
Or at least the same power on less boost.
I guess I should wait for this dyno day so then I have 2 results to compare
My results
Other results
intake pipe makes abit of differences to response. here's one more result from a customer's R34 skyline running SS1PU. made 255rwkws @ 16psi with 2psi creep mid range. This car's also runs a return flow cooler that get abit hot. With a proper cooler at 20psi it should be getting pretty close result as my test car.
There has been a recent FNT angle update, might affect tinny bit in response but not power wise.
Another results on an SR20
Here it is. SS1PU internally gated bolton version for S13 SR20det non vct.
The thin red line is on stock cams, while the thick red line is on big Tomei Pro 270 dur cams which made it bit laggy. The tune is based on pump 98.
The car's not 100% done at this stage, my expectation sits around the 280rwkws with bit more boost once all finished.
    • A lot of what you said there are fair observations and part of why I made that list, to make some of these things (like no advantage between the GSeries and GSeries II at PR2.4 in a lot of cases) however I'm not fully convinced by other comments.  One thing to bare in mind is that compressor flow maps are talking about MASS flow, in terms of the compressor side you shouldn't end up running more or less airflow vs another compressor map for the same advertised flow if all external environmental conditions are equivalent if the compressor efficiency is lower as that advertised mass flow takes that into consideration.   Once the intercooler becomes involved the in-plenum air temperature shouldn't be that different, either... the main thing that is likely to affect the end power is the final exhaust manifold pressure - which *WILL* go up when you run out of compressor efficiency when you run off the map earlier on the original G-Series versus G-Series II as you need to keep the gate shut to achieve similar airflow.    Also, how do you figure response based off surge line?  I've seen people claim that as an absolute fact before but am pretty sure I've seen compressors with worse surge lines actually "stand up" faster (and ironically be more likely to surge), I'm not super convinced - it's really a thing we won't easily be able to determine until people start using them.     There are some things on the maps that actually make me wonder if there is a chance that they may respond no worse... if not BETTER?!  which brings me to your next point... Why G2 have lower max rpm?  Really good question and I've been wondering about this too.  The maximum speed *AND* the compressor maps both look like what I'd normally expect if Garrett had extended the exducers out, but they claim the same inducer and exducer size for the whole range.   If you compare the speed lines between any G and G2 version the G2 speed lines support higher flow for the same compressor speed, kinda giving a pretty clear "better at pumping more air for the same speed" impression. Presumably the exducer includes any extended tip design instead of just the backplate, but nonetheless I'd love to see good pics/measurements of the G2 compressors as everything kinda points to something different about the exducer - specifically that it must be further out from the centerline, which means a lower rpm for the same max tip speed and often also results in higher pressure ratio efficiency, narrower maps, and often actually can result in better spool vs a smaller exducer for the same inducer size... no doubt partly due to the above phenomenon of needing less turbine speed to achieve the same airflow when using a smaller trim. Not sure if this is just camera angle or what, but this kinda looks interesting on the G35 990 compressor tips: Very interested to see what happens when people start testing these, and if we start getting more details about what's different.
