i just put iridium 4's in and went to see sam at xtc who told me to take them out and put other ones in as they arent the best suited plugs.
this really piissed me off cos they cost $120 now i need to change them
the other thing that annoyed me about this is i went to REPCO and simply asked the guy who seemed to no a bit for a set of the best plugs i could get for my gtst
he sold me these iridium 4's and as i had heard the Hype about them i thought yeah why not as oi always put the best of everything into my car.
i dont think i can take them back either cos i dont have the reciept and the boxes had to be fished from the bin so im $120 down and still need new sparkies.
F#@$NG REPCO.
so yeah what do you all use in your cars?
cheers
https://www.sau.com.au/forums/topic/41992-which-spark-plugs-for-rb20det/
i use bcpr7es11's in mine... juct coppers...... they are perfect for my car i rekon... sydneykid reccomended them to me... and mine makes over 300rwhp so they cant be bad eh... gap to .8 if u run mildish boost and .6 if over 16 psi or so.... depends how u go...
    • Out of curiosity, what's the reason for converting? I think @R3N3 might have the Frenchy's kit in the R33? I somehow think of you as the ambassador for realistic and clean street-driven setups nowadays
    • careful when running the car after a boil over. Ive heard you can lose enough coolant that it won't show the right temps because of too much air in the system (or something like that). Make sure the levels are good before trying again.  Maybe a mobile mechanic can come have a look with their scan tool ?
    • OK, just for some extra clarity - there is more than one option at Frenchy's. 1. You can buy the whole kit - with or without the actual compressor. The whole kit includes mounts, hoses, condensor, etc. That's either ~$2200 or ~$2800. No surgery required with this option. 2. You can buy just the bracket (~$600), or the bracket with the compressor (~$1200). Either of this or the above option "without the compressor" is if you already have an Echo comp or you are able to source one locally. Whatever the case, in this option, you will need surgery done on your hoses to adapt to the new compressor. When I said "the Frenchy's kit", I meant the whole kit in option 1. It is obviously somewhat more $$ than a $1500 OEM compressor. But if I had to spend $1500 on an OEM compressor, I would certainly consider spending double that to renew and significantly update everything forward of the firewall. Another option is to rebuild your original compressor. My R34 comp is currently dead and I will be most likely doing that to it if the spare one in the shed is also leaky.
    • I’m thinking that’s the route I’ll  go, thanks for the input!
    • Hey all, my 2004 Nissan Skyline 350GT overheated the other day with coolant boiling and leaking out of the coolant reservoir when I was parking. So today, I started it up again just to see if it was a thermostat/head gasket issue. After about 20 mins of running, temps were normal again, no coolant was leaking out and the upper reservoir hose was warm but my engine suddenly cut off. I checked the oil dipstick and cap when it was running and there was no white foamy residue and the exhaust did not have white smoke. I tried starting up the car again but it would only crank, similar to when I had a camshaft sensor issue just that now there’s no check engine light on the dash. Any ideas? Unfortunately I don’t have an OBD2 that can read the Nissan's programme.
