hey guys
im looking for the best mechanic to take my M35 stagea to in adelaide, prefered northern suburbs.
ive been having some problems and need someone who knows what there looking at with the stageas.
or if anyone on here could help me out and take it for a drive so i can show you the issues that would be great.
cheers
https://www.sau.com.au/forums/topic/419926-adelaide-m35-mechanic/
its getting to be a decent list of things wrong.... starting with a shudder in the front end under hard acceleration, then vibration in the steering at around 100kms, and then im pretty sure my front discs have warped even tho i got them machined bout 3 months ago.
then it goes to a knock in the front passenger wheel well and a loud grinding noise when turning right to fast.... which is my main concern.
there is more but i cant think of them atm...
hahaha... thanks for the offer tho mate :D
yeah i work in wingfield, i know theres something suss going on when i dont see a "working girl" as their called..
we actually named them as we seen them LOL we had skippy, blondey, iraqy and aneurism..... the result of dead days at work....
    • First up, I wouldn't use PID straight up for boost control. There's also other control techniques that can be implemented. And as I said, and you keep missing the point. It's not the ONE thing, it's the wrapping it up together with everything else in the one system that starts to unravel the problem. It's why there are people who can work in a certain field as a generalist, IE a IT person, and then there are specialists. IE, an SQL database specialist. Sure the IT person can build and run a database, and it'll work, however theyll likely never be as good as a specialist.   So, as said, it's not as simple as you're thinking. And yes, there's a limit to the number of everything's in MCUs, and they run out far to freaking fast when you're designing a complex system, which means you have to make compromises. Add to that, you'll have a limited team working on it, so fixing / tweaking some features means some features are a higher priority than others. Add to that, someone might fix a problem around a certain unrelated feature, and that change due to other complexities in the system design, can now cause a new, unforseen bug in something else.   The whole thing is, as said, sometimes split systems can work as good, and if not better. Plus when there's no need to spend $4k on an all in one solution, to meet the needs of a $200 system, maybe don't just spout off things others have said / you've read. There's a lot of misinformation on the internet, including in translated service manuals, and data sheets. Going and doing, so that you know, is better than stating something you read. Stating something that has been read, is about as useful as an engineering graduate, as all they know is what they've read. And trust me, nearly every engineering graduate is useless in the real world. And add to that, if you don't know this stuff, and just have an opinion, maybe accept what people with experience are telling you as information, and don't keep reciting the exact same thing over and over in response.
