  • Replies 44
Yer, i really don't want to leave it on the street overnight. I have had two cars keyed in the past and it's heartbreaking not to mention expensive.
I have seen some 'loading ramps' made from lightweight aluminum that are used to load mini excavators/bobcats etc onto trucks - but they are about $400.....bit exxy.
The other idea I had was to get one of those plastic speed humps you see in car parks - i reckon if i put it in just the right place it might help 'hop' the front bar over that part of the drainage dip. They cost about $70 - and I could probably get that past the council as it's not a trip hazard.
We installed a speed hump made out of rubber to prevent the front splitter of the GT-R from scraping.
After trying different positions over half an hour, we got it right.
Masonry bolts are drilled into the concrete, but later on, they can be removed (when you move again).
Corporate Body is understanding?
I had a similar issue. My driveway is quite steep, and my exhaust was always scraping on the road when I drove into the driveway. Then, about halfway up, it dips, then increases the gradient again. I bought a sheet of 20mm MDF from Bunnings for $30, cut it into rectangles about 50cm long by 20cm wide, glued 2 together so its total thickness was about 40mm, and drilled them into the concrete using masonry bolts, so they can be removed later. I only had to put 2 at the bottom of the driveway, and then another 2 halfway up. As long as you get the tyres on the boards on your way up and down, it doesn't scrape at all anymore. I also got one of those EZ Lips for my front bar, as its made out of foam, it stops the concrete scratching my bar if there is any issues.
I've got one of those rubber lips, not fitted yet - how do they stand up to the scrapes? do they start looking ratty after a bit?
if it was my house i'd reconcrete it, or at the very least drill a ramp on. But......I can't. I might have to ghetto rig some boards up and just slot them under when I go in and out.......and start whoring myself to afford a cup kit.
Thanks Terry, i might experiment with a bit of wood first, see if that sort of solution would work for me. Would be a good 'inoffensive' addition to the street scape though.
I got the rubber for free, I'll take a pic tomorrow. Went to playground and council was installing some and had off cuts, they gave me a strip. Maybe ring up council and ask if they doing any playgrounds and have left overs ?
Your 20mm lower than stock and your complaining.......please
Your point?
Anyone can drive in to the garage and wind their coilovers down til the threads run out, but if you can't get the car back out of the driveway, what's the point?
And smash a $1200 front bar into the concrete until something gives?
Unless you measure 'manliness' by the ability to break things, then I dunno how that would 'manning up'?
Not really constructive input but thanks for dropping by.
Edited by SMOKEYV35
Sorry mate, that content doesn't show on iPad/iPhone. I didn't see it. My bad.
Bought some sleepers from bunnings today, cut them to length and bolted some handles to them to make moving them around easier. It sorts out the front bar clearance, but not the exhaust/rear subframe unless I get the entry mm perfect......groan.
    • This was a huge help.  We followed the steps,  although shifting into 2nd was actually into 3rd for us,  and 1st was into 2nd ( steps 9 and 11) .  The long flash was the 4th flash.  So shift solenoid A is possibly the culprit.  Is this inside the transmission itself? Or is it accessible by just front the pan? Or is it bolted to the outside of the transmission?  Thanos for your help everyone
    • Can you enlighten me on your best practice regarding these hoses? I don't wanna make the same mistake if you already got a better solution.
    • I have some silicon hoses already, for example engine to watercooler. But yeah, I get the sentiment. The lower intercooler silicon hose is drippy too, despite not being very old. Does anyone except Nismo make these same lines out of rubber? Long term I think they'd be the better replacement, especially since the car won't live as hard a life anymore as in the past nor be driven as often.
    • I know most issues are just age related. But for example the turbo oil drains, there is dash adapters for these and you can just make a braided teflon line for them and (probably) never have them leak again. Also not terribly expensive. Can you even get the factory hardlines from new? Or are they repairable if they break?
    • I know it'd be much much easier with the tool. I hope I can find one that won't take 3 weeks to get to me an isn't a "Asian models kit" that has tons of (to me) useless adapters for a load of cash.   It's a summer project/fun car. I do wanna enjoy it, without endless downtime over and over. So yeah I would even go and buy an engine crane + stand to save myself the trouble of hard to reach or unreachable places going bad later on. Would also be a good opportunity to put on a Fluidamper, renew the mains seals and stuff like that. I have some money on the side that I can use for that, what I wouldn't want to or be able to do is let everything be done by a shop or have my engine completely rebuild right now. I intend to do most of the "doable" jobs myself. Pulling an engine can't be that hard, can it?
