Hey guys the wait is over ive got my first laurel after waiting for about 2 month to get it from nsw just picked it up today and could not be happier i fell in love at first sight and now the long hard road begins fixing little things up to get it to what a want quick list of things done
ENGINE:
- Its an RB25det series2 out or a R33 skyline with 80,000klm and have all recipes for work done.
- Greddy intake manifold.
- 80mm billet throttle body
- Denso 740cc injectors
- Custom fuel rail with braided lines
- Turbosmart FPR1200 fuel reg
- Walbro 500hp fuel pump
- Stainless steel hight mount manifold
- Turbosmart 38mm external wast gate with screamer pipe
- t04E turbo with polished housing .8 rear housing
- Full 3" stainless mandrel bent exhaust system
- 300/600/100 intercooler and piping
- 52mm alloy radiator
- Tomei Poncams 256 degree cams
- adjustable cam gears
- Gates racing timing belt and all tensioners and rollers wear changed
- EMS Computer (ECU)
- Turbosmart duel stage boost controller
- Greddy turbo timer PLUS SO MUCH MORE
SUSPENSION & BODY
- Tein full adjustable coilovers
- Tubed control arms Rose jointed
- R33 4piston Calipers front
- R33 2piston Calipers rear
- Rear wheel bearings have been changed
- 18" black with machined lip rims 8.5" front and 10" rear with stretched tyre's
- 5 Stud conversion done with all new wheel bearings
INTERIOR:
- Fully retrimed in a light tan leather
- The sound system is basic but affective with all Alpine head deck and splits and amp
- The roof has been custom made with down lights and the laurel emblem in the roof needs to be finished
- Downsides
- there is a bad manifold leak at the moment but will be first thing fixed
- and the car is a AUTO :( but this will be the big thing that will be changed and am going to begin collecting parts to do this asap
https://www.sau.com.au/forums/topic/419933-my-laurel-c33/
  • Replies 51
well this weekend made the start on the laurel took it for its last drive for while as i start fixing things up getting ready to go over the pits for rego
things to do:
fix exhaust manifold leak
fit new steering rack boots
fits lights,horn
try to find out whats going on with the power steering
need to check over the car and check the cams and make sure it has actually got the poncams in it and find out whats going on with the computer and what it is as i looked and looks like a stock r33 but as he said had a ems but was told the ems may of been cut in to the loom like a chip so hoping i didnt get shafted on that but still got it for a good price and cant complain about that
will put more pictures up later once i slip rocket covers off get some pictures of the cams and try to find some numbers on them and try and find out what they are...
https://www.sau.com.au/forums/topic/419933-my-laurel-c33/#findComment-6754571
got the manifold off today was a battle :( and i found out what i thought was gonna be wrong with it the manifold is warped so ill be sending it off to get planed hope they can fix it with no problem now can anyone shed light on what washers go on manifolds on the laurel there was the manifold then a spring washer then the nut but on my r32 that is set up basically the same its manifold spacer spring washer then nut
so just wondering what is the right way???
and whats every ones thought on best manifold gasket to use looks like the one on there is a multi layer stainless steel
post-93126-0-39535200-1361100005_thumb.j
post-93126-0-88348500-1361100089_thumb.j
https://www.sau.com.au/forums/topic/419933-my-laurel-c33/#findComment-6755302
yeah think ill just do the same took the manifold to the machine shop today to see about getting it fix and since it had warped 4mm out on each side that fixing it would make it very thin so ive decided to scrap the dirty cheap china manifold and get something good as everything else is good quality on the car so now ive gotta make a decision on what sort of manifold to go with
suggestions very welcome ;)
https://www.sau.com.au/forums/topic/419933-my-laurel-c33/#findComment-6756265
It looks like an additional injector controller. Back in the olden days before chips etc if you wanted extra fuel on a fuel injected car they sometimes plumbed in another single injector to the intake to supply some extra fuel. Seems laughable given the tuning that can be done these days.
https://www.sau.com.au/forums/topic/419933-my-laurel-c33/#findComment-6760070
well yesterday i sold the r32 thank god so now the manual gearbox will come and getting closer to doing the conversion spent today putting on the new steering rack boots and taking the aircon pump out (as it was left in there with just the pump and nothing else) still waiting on the manifold and other gaskets to come then put all that back on cant wait to drive it again even if it is auto
https://www.sau.com.au/forums/topic/419933-my-laurel-c33/#findComment-6763800
alright so im almost there with all my conversion parts ive got a question ive searched and havent been able to find the answer...
As im putting the 25 box on to the 25 motor what sort of sandwitch plate will i need to bolt up or should it bolt straight to the bell housing ???
https://www.sau.com.au/forums/topic/419933-my-laurel-c33/#findComment-6767210
Should bolt straight up if using RB25 G/box to Rb25 motor. Sandwich plate is only used to mate different engine and gearbox combo's like a toyota engine to Nissan gearbox. Most Nissan stuff is good to go from that era so a Z32 g/box and RB g/box will have the same pattern.
https://www.sau.com.au/forums/topic/419933-my-laurel-c33/#findComment-6768336
yeah well hope it all works out just have to sort the tailshaft out hoping can just join the backpart of the auto shaft to the front of the 33 fingers crossed
You won't be able to just join the 2 tail shafts. They are a fair bit different. But it easy to get the 2 made into one. Take a measurement from the end of the output shaft on the gearbox to the center bearing bolt holes. Take that measurement and both the tail shafts to dynamic balancing in invermay and they will sort you out.
https://www.sau.com.au/forums/topic/419933-my-laurel-c33/#findComment-6770496
    • Gday, Due to not finding much up to date info on this topic I thought I'd make a thread to get peoples latest opinions/recommendations. Background info -  I've got a S1.5 R33 GTST as a fun project car, mainly for street use and occasional drag strip, apart from all the cosmetic things I'll be doing a full rebuild of the engine with forged internals. Since it'll be getting new cams (kelford) and springs to match I thought I might as well get new lifters and valves while I'm at it, the dash says 160k KMs but the engine seems pretty tired, compression measures about 130psi across all cylinders so I'd like to freshen everything up. This is where I'm tempted to just fork out the extra and go solid lifters while it's all apart, aiming for 400-450kw atw with a flex tune. Assuming all supporting mods (oiling, fuel and all bolt ons) with a lightly ported head and turbo to match (yet to make a decision possibly gtx3582r or similar from Hypergear) I've seen the Tomei kits with just the buckets getting around, Supertech sells most things - Supertech High Performance Cam Followers | Trusted Racing Cam Followers Questions -  Has anyone found the Hydraulic lifters to limit them at this power level? Is it usually found that you can just clean the stock lifters and find they work fine?  Does going solid lifters save any headaches/issues with hydraulic lifters in the future? Any recommendations on other things that will need to be replaced, I know I'll need to get the solid profile cams but can you use the same type of valves and springs/retainers and is it recommended to change the guides and stem seals?    Summary -  Basically looking for pros/cons and wanna know if I'll actually need the extra RPMs from solid lifters or it'll just be bragging rights to say it ReVs OvEr 8000 Cheers
    • Ha ha ha, this stuff they had was installing Toshiba PLCs that were made some time in the 1990s, and they were replacing GEM80 PLCs. To let those two talk (staged upgrade along a ~1.2km long building that was split into 4 sections), was a bunch of WinXP machines running Java gateways... There was no way to put something like ProfiSafe in... Most of the HMI machines were WinXP, with Java program, with a custom button board emulating a keyboard... About the only buttons in the operator stations that went direct to the PLCs was the eStop. There was some interesting design stuff in that place...
    • Stock bypass valves are good for plenty of boost.
    • Check for fuel flow out of the outlet end of the rail. Check for spark. Try to start with aerostart (or pressure can brake cleaner or similar solvent in a car) prayed in through TB. If you have fuel and you have spark and it will fire on substitute fuel, then seriously suspect that E85 sitting for ages in your fuel system has destroyed something and put it in your injectors.
    • Nissan stock oil pressure is typically about 1 bar at 1000 rpm plus about 1 bar per thousand revs on top.
