  • Replies 51
hard one of them nights tonight everything going great manifold almost back on nek minute stud randomly strips out of the block :( arhhh thank god for helicoils really want it back on before the weekend so i can get stuck in to other things and take it for a spin ;)
CARS GOING AGAIN manifolds back on and all going not leaking from manifold any more but is a small leak coming from where the dump pipe bolts to the turbo as one of the bolts are stripped will fix that should be easy fix hope so anyway then would like to take it to have it put on the sniffer just to make sure everything is ok with the tune and that as im not sure whats been done look it for a good drive last night and filled it up and drove 184km on highway and i had just over quarter of a tank left!! :woot: so it really really loves fule its done smell to rich and its not all black up the back of the car i believe it has something to do with the auto box and it slipping as its getting worse wont even go skids :( so sad but all that will change as soon as i get the manual in it cant wait to have it done and few little issues left and should be running good only really need to sort out the hand break and cable now...
Yes thank you damo he is my teacher and I am his grass hopper!! Solved my issue of what crossmember will fit the 25 box in to the laurel we discoved C CROSSMEMBER will fit a manual 25box in to a auto laurel with no mods :) as we have have done a test run on my mates laurel as his was already manual only had to really worrie about the crossmember and the tail shaft I already feel more confident in taking it on just hope my gearbox and other stuff turn up soon so I can get stuck in!!
all my goodies showed up today thanks to phatlavish for everything now have
-rb25 gearbox
-crossmember C (fit right in no mods needed tested this on frenchie1001's laurel the other night)
-excedy button clutch
-flywheel
-break and clutch pedals
-manual dash cluster
-laurel manual center console
-manual shifter
-all bolts for gearbox and everything
-r33 tailshaft
-manual wiring loom
-sandwitch plate
parts still needed:
-clutch slave cylinder
-clutch master cylinder
-clutch line
-r32/a31 manual handbreak
-a31/c33 handbreak cable
-mod tailshaft (going to try front 33 back manual laurel shaft
-gearstick dash surround
hope i haven't forgotten anything
havent done anything else to mine and probably wont this week been working every night this week on zacs laurel (frenchie1001) and after almost 12 months of work building it will (finger crossed) start tomorrow been a great build and learnt heaps be awesome to see it back on the track!!!
Thank you once again sir I have scored zacs hand break and front bit of the hand break line hope it will just hook up in to the where the auto hand break line splits off in to the Y just behind the gearbox and have got his bolting brackets so I can just drill the holes in the tunnel and and bolt it up just speedo now really anyone out there brought a pre made speedo drive to convert electric to cable speedo as I would rather get a good one then stuff around with the d22 nav ones and have my speedo out if I can help it!
well today i actually worked on my own laurel for a change pulled the manifold and everything back off and to find the new manifold is warped really pissed off about this as it was brand new trying to decide on what to do weather to get another one the same or try something different but im not spending $1200 on a 6 boost cant see the sense in that and i all so have bad heat problems wiring melting around the strut tower oil drain line off the turbo has melted through and the silicon bend off the turbo must of been touching as well and has done the same :( so will have bend welded to turbo and the oil drain made longer so it clears the manifold and try to move the wiring on the gearbox conversion side ive recived the the gktech clutch line very fast postage and after being stuffed around something shocking by kudos motorsports with the clutch master and slave told them dont bother after waiting weeks and weeks ive just brought a slave and master of the same guy i got the gearbox and the other parts off he has been a great help and ive found a company in NZ that can convert my electronic speedo to a cable so i can use the 25 box in the laurel so alot going on but im in no rush....
well over the ester had a awesome day at the Tasmania drift practice day at symmons plains even if i wasn't driving and and done a little to my car pulled out all the left over aircon ie pump and lines ive started on my conversion as well removed the auto shifter foot break and auto break pedal mounted the clutch pedal and clutch master and the clutch line having trouble getting the actual pin as its in the worst spot and hanging upside down in your car is horrible and with the manifold ive the flange of the manifold in 3 spots (pics to come) as ive been told it can bring the manifold back in to shape and it has so im just gonna give it ago and bolt it up but wont know till the conversion and everything is done but hopefully next weekend can get the auto box out and look at putting the manual in :) cant wait
well this weekend auto box was pulled out all the pedals done dash cluster has been changed im ready to put the clutch in now but i have never done this before so is there anyone out there with a good walk through on how to do it and what else i have to pull off as ive taken the converter off the back and the auto flywheel thing and am not stumped in what to do :/
You'll need to most likely make some relief cuts in the Auto spigot bearing then smck/pull it out of there. You'll then need to purchase a Manual Spigot bearing and smack it in with a hammer and a socket around the same size.
ok so ive need to get a spigot bearing i have a spigot bush that is like a brass bush that im guessing slips in side the bearing? i got a big bearing with my clutch that i was guessing was a throwout bearing? and i brought a small brass bearing from nissan guessing it was the spigot bush do i also need a manual spigot bearing??... sorry for the noob questions
    • Yeah one of the first things I out in when I started having catch can filling up issues. Still prefer to empty 1-2 times a track day rather than every session
    • You'll find this link is probably more useful  Performance Turbochargers - Garrett - G GT GTX GTW Series Turbo TBG G35 1150 map may not even get added to my list depending on how it looks, the G35 1050 already is a mixed bag for making the numbers you would expect from the compressor map due to mismatch - I don't know how another 10lb/min of compressor flow is going to make that any better.   I've left out others for similar reasons as it's already getting quite big.   In terms of Precision, provide me with legit compressor maps for them and I'll do my thing   I'll add some more of the newer Xona Rotor options are they're pretty boss, I'd take a 68mm Xona over a G35 "1150" any day of the week - or Precision for that matter.
    • Ahh got it. Well maybe install a drain for the catch can somewhere down low and accessible like a wheel well too....
    • Before you blow your car up, have you checked you've made all the correct modifications to the wiring if you're still using the RB20DE loom?   Some things to look at: The pin used for the map sensor on the RB25DET, is the same pin used on the RB20DE for the Ring Gear Crankshaft Position Sensor, no idea what you've got it plugged into now. The turbo pressure control valve solenoid you're talking about on the RB25DET, the same pin is used for the Variable Air Intake Control Valve on the RB20DE.   The factory manual has the wiring pinouts in it for you to check everything. It also has the diagnostics process to read codes out. In addition, there's a great table that shows what sensors and what actuators not functioning will relate to which signals. And Nissan confirm the as everyone else has from experience, the Solenoid being disconnected won't cause a fuel cut. However, the turbo pressure sensor being missing / wrong, WILL cause a fuel cut. https://www.nicoclub.com/service-manual?fsm=Skyline%2FR34-Workshop-Manual-English.pdf
    • I've been hunting info on the G Series II - this is best I have found so far(Link below). Still waiting on the G35-1150 comp map, kind of very keen   So how do we go about getting precision on that little table of yours ?   https://turbosbytm.com/sites/default/files/product/technical-info/Garrett-G-Series-II-Product_Flyer 25 30 35_1.pdf
