I tried searching on here and I even did some googles so now I come to you.
So I need to replace the engine oil sump on my ER34 as it got dented.
It doesn't look like it's going to be a super easy easy job.
Does anyone have any tips? Would it be easier to take the engine out or can I undo the engine mounts and use an engine crane to raise the engine enough to drop the sump off and get it out?
Cheers,
Andy
https://www.sau.com.au/forums/topic/419934-r34-gtt-engine-oil-sump-removal/
Damaged sumps are a very common problem in Syklines and for example of the 6 RB25's I currently have only three have sumps without a mark on them.
There are two ways that you can do this.
The first is the standard engine out - replace sump - reinstall.
The other option is to raise the engine slightly with an engine crane and install an engine hanger that spans fron one front guard to the other and then support the engine from the hanger. Next you support the car on a hoist for easy access under the car. Then remove the engine mounts, undo the lower control arms inner mounts and then remove the front crossmember.If you then raise the car on the hoist you have easy access to the bottom of the motor to remove the damaged sump and install a new one.
Either approach is not that difficult it just requires equipment and time to complete the job.
The other day a couple of people said I should be able to get it out by taking all the bolts for the sump out and undoing the pickup and taking that out with the sump.
Does this sound plausible?
    • I don't really know general street pads too well, but there is no reason you can't get a low dust, long wearing, no squeal pad that works for those calipers at a reasonable price....they would just be a low end to medium price daily style pad.  If new pads don't have much bite or they loose it over time, it is probably just the pad glazing up which you can fix by giving them a good thrashing every now and then (or get the mechanic to deglaze them at next service) Track or semi track pads are where you have to put up with excessive dust (and potentially squealing as a side effect of that) in return for good bite and performance when very hot. Street pads have nothing like that sort of punishment, even long downhills with the brakes on are easier than a track session
    • lol yeah I'll check that, reminds me of the LDV thread!  I don't think that is the problem here, the starter doesn't even solenoid click. I did do a super quick test by removing the starter motor's power cable from the engine bay fuse box and the battery voltage was still 10v, so something super fishy is going on. BTW here is a R33 fuse box table I threw together from a few sources....use at own risk! R33 Fuse Box and Sources.xlsx
    • Johnny's approach, throw all the Nissan electronics into the trash. Best thing I've done to my shit box, go DBW.
    • Sounds like the JAX guys must have installed some really awful pads, are they BenShit/BenDicks pads by any chance?
    • Result of another R35GTR build. Similar specs as above except this is running our bigger size SS-2 profile option. Made similar power except this car runs on Pump 98 fuel. Build specs are: Nissan R35 GTR 2015 model stock engine and box. ETS street intercooler boost logi intercooler piping with tial bov, boost logi turbo inlet pipe ID 1050 injector DW 300C fuel pump Decatted oem down pipe and y pipe& HKS exaust 3inch intake pipe Upgraded actautors HyperGear SS-2 high flow option Final result is 639whp / 477wkws hubs, Ron 93 / P98 fuel at 20psi.
