Well, today is an exciting day for me. I have been after this car for the better part of two years.
After tracking down the lady who’d been driving it, i found out it belonged to her uncle who owned it since new and he’d lent it to her ten years ago! He wasn’t really interested in selling it but after calling up to check every couple of months he finally relented. I had wanted this one to be my tenth R31, but i bought the silo 5 days before as a fixer upper. The simmons will be going on the gts until i can source another pair
It is quite rough on the outside as you can see and the interior needs some work but thats exactly why i’d wanted it. It seems to have all the original bits except for two of the rims – developed the cracks – but im sure any GTS aficionados will help pointing out whats needed smiley.gif
Standard tape deck!!!
Standard speakers?
  • Like 1
well the real miracle about finding one of these is that pete has personally killed more nissan actually made. On the bright side he would have left lots of bits at wreckers
Thanks guys. Im really suprised at how well it drives, handles better than any of my other street 31's
Did a bit of a clean, needs a lot more work but it feels nicer now. The polish worked, it'll need a cut though but im not sure how much paint is left. There’s bare metal on the bonnet
I don’t know if i mentioned it before but the car got broken into a couple of weeks before i bought it. so i had to replace the loom behind the ignition, now i can start it without having to jump the starter haha.
I’ve also ordered a new ignition barrel with extra door lock barrels
Did an engine oil flush as it was blaaaacck and new tank of premium with injector cleaner in it. Must have been some sh1t in it, stalled on me about 20min later and had to floor it to start again with a big puff of smoke. Running much better/smoother now.
Also, I tried to adjust the front bar gap. I think the reo is bent so for the interim i pushed the right side up and pulled the left down so theres about a 10mm evenish gap now. No pic atm
Haha, yep. Got a set of Simmons V4's to go on, just need to get a lip straightened on one.
The ones you see on the silo in the first picture.
  • 1 month later...
New number plates finally got here and i put the fog lights back in at the same time.
Also, shiny new O2 sensor. The old one had a rattle..
Cold idle is new and improved.
  • 8 months later...
Funny you posted now :)
I only just put rego onit and drove it for the first time since june.
But other that that, I haven't really done much to it. Been on the back burner while I've been playing with grumbles :)
    • Big single, and seqy. #sorted
    • The R32 suffers from an instrument binnacle that is uncomfortably close to the design of a VN Commodore's. But beyond that, the layout of the rest of everything, and the materials (ie the vinyl coverings on dash, armrest, etc) are acceptable, and the patterns on the fabrics are not as blergh as those in the R33. And R33 seats are....quite unattractive. I know it's only small details there, but I reckon the R33 got worse than the 32. But the big blergh is the overall shape of the dash on the R33. It's just has that whole Maxima/Pulsar sort of look to it. Nothing special at all. Generic Nissan sedan. Whereas, at least the R32 dash/binnacle was different. Less a wide expanse of boringly curved plastic. More a "cockpit" sort of look, even if nowhere near to the degree that the A90 Supras got. R34 seats look good on their own, until you realise that they are indistinguishable from the shape and fabric on 70 other Japanese cars. And the foam bolsters on them suffer even worse than the earlier cars. Other than that I don't really have an opinion the rest of the R34 interior. I took the bits of the R34 I wanted (brakes and engine) and added them to the best external appearance Skyline in the modern era (the 32). So nyerr!
    • Can I be your first customer? I would like hard lines done for the fuel system, 8AN up and 8AN back and the underside wire wheeled and coated (brush or sprayed) with that black tar shit.
    • Speak for yourself, I love the R33 interior. 32 is blergh. I like the 34 interior too. Then you start getting much newer in most cars and they all turn back to blergh. 😛
    • 500-600hp into a RB is already 'sinking endless amounts of money' into an engine. Especially a 30 year old engine. Unfortunately this is the RB Game. Considering stock power (or at least stock components) will do ~360whp on 98 by simply turning up the boost on the stock gear on a RB26, that would be where I'd say the cutoff point for "sinking endless amounts of money into the engine" Cause to even do this reliably you'd probably need to replace all the bits anyway cause they're old, starting your sinking journey anyway. I reckon the least painful way is rebuilding the engine to make 50hp over stock lol. The 'plan your ownership around a rebuild' was a common saying 15 years ago.
