Well, today is an exciting day for me. I have been after this car for the better part of two years.
After tracking down the lady who’d been driving it, i found out it belonged to her uncle who owned it since new and he’d lent it to her ten years ago! He wasn’t really interested in selling it but after calling up to check every couple of months he finally relented. I had wanted this one to be my tenth R31, but i bought the silo 5 days before as a fixer upper. The simmons will be going on the gts until i can source another pair
It is quite rough on the outside as you can see and the interior needs some work but thats exactly why i’d wanted it. It seems to have all the original bits except for two of the rims – developed the cracks – but im sure any GTS aficionados will help pointing out whats needed smiley.gif
Standard tape deck!!!
Standard speakers?
  • Like 1
well the real miracle about finding one of these is that pete has personally killed more nissan actually made. On the bright side he would have left lots of bits at wreckers
Thanks guys. Im really suprised at how well it drives, handles better than any of my other street 31's
Did a bit of a clean, needs a lot more work but it feels nicer now. The polish worked, it'll need a cut though but im not sure how much paint is left. There’s bare metal on the bonnet
I don’t know if i mentioned it before but the car got broken into a couple of weeks before i bought it. so i had to replace the loom behind the ignition, now i can start it without having to jump the starter haha.
I’ve also ordered a new ignition barrel with extra door lock barrels
Did an engine oil flush as it was blaaaacck and new tank of premium with injector cleaner in it. Must have been some sh1t in it, stalled on me about 20min later and had to floor it to start again with a big puff of smoke. Running much better/smoother now.
Also, I tried to adjust the front bar gap. I think the reo is bent so for the interim i pushed the right side up and pulled the left down so theres about a 10mm evenish gap now. No pic atm
Haha, yep. Got a set of Simmons V4's to go on, just need to get a lip straightened on one.
The ones you see on the silo in the first picture.
  • 1 month later...
New number plates finally got here and i put the fog lights back in at the same time.
Also, shiny new O2 sensor. The old one had a rattle..
Cold idle is new and improved.
  • 8 months later...
Funny you posted now :)
I only just put rego onit and drove it for the first time since june.
But other that that, I haven't really done much to it. Been on the back burner while I've been playing with grumbles :)
    • Ok gotcha, so one post to fpr  another to bov  and I have the mishimoto boost controller and a link g4+ so I’d just have the tuner set it up properly. For the last two from plenum post throttle to  ecu/ boost controller, I know that I have a hose coming from the ecu that I was confused about so I assume that’s what connect to the boost controller from the ecu? And then the last is just from plenum to boost controller then to wastegate?
    • From there, it was just a quick electrical check, prime the oil and start her up Which, is not what happened. 1. Bloody seppo Aeropro battery holder. Not only was it too tall for the battery (which I'll forgive them for, I have another battery the same nominal size that is taller than Neil's one, but the bracket is a fixed height so the battery was spaced up) But the thing that really shits me is the hardware to hold it on requires a 7/32 Hex key. WTF. No-one will ever be able to remove or install the damn thing without a hex key they don't own 2. Kill switch no longer worked once the console was installed. Neil mentioned above he had to adjust the length but it no longer cleared the console once installed. Sorted. 3. Suspiciously, the brake light holders were hanging in the boot with no globes. Sure enough the stopper on the brake pedal was missing so they are always on unless the kill switch is activated. Will pick one up tomorrow (turns out 32 and 33 don't use the same stopper) 4. All that sorted, I turned on the kill switch, turned the key to ACC. Nothing. Turned it to IGN. Nothing. Checked some fuses and found the main IGN in the boot was missing which improved things once it was replaced. Now ECU and dash lights turn on with IGN but still no fuel pump. 5. Turned it to Start....ECU on, no fuel pump, no starter. Plus the voltage dropped straight to 9v.  I suspect the starter is f**ked but am going to have to work through it all and see what is happening, really looks like more than one issue. Does anyone have the R33 fuse box key with the circuit it sources from (eg BAT, ACC, IGN, SRT etc) and supplies? I can find a translated list showing Amps and circuit without supply circuit, and I can find supply circuit without Amps and target circuit.
    • 3rd time lucky, the AAC is now all plumbed up after getting some final fittings All set up under the plenum of maximum access
    • OK, so the weight has been bugging because it was really low. I did it again today and got a more believable answer at 1246 without driver And with a 93kg driver I'm pretty sure the car was still slightly on the quickjack last time meaning the full weight was not on the scales
