hey all just a quick question, last night i was giving my r32 gts-t a bit of a boot on the way hame and i noticed that the boost is at 12-13 ish PSI all the way to about 5G roughly but then past that it goes back down to 10PSI ??? is this just the stock turbo running out of puff....or do you reccon iv got a leak some where?
iv only just noticed it now coz the engine has been missing for the last 4 months and i was slowly tryin to figure out what was wrong (was the plug gap!) there for havent realy given it a thrash b 4 now.
any thoughts
cheers mark
Over 5G the presure in the turbo zaust housing gets too great which forces the waste gate open and that is why you are losing boost. HKS sell waste gate replacments that are rated at 12 psi instead of 7psi and they should hold fine, they cost about $180 in total.
This is the case for r33's but i am not sure about r32's...
    • See my post here If you put the Haltech in, you won't have to worry about any of that. And, in case you're worrying about my lack of credentials in doing your exact swap, I put a Neo in an R32. There has never been a stock boost solenoid near my car and the Neo's ECU has never cared. Nor should it, because it is electronically impossible for it to care.
    • That's 100% wrong. Did you wire in the boost sensor? If you did not, then that is 101% your answer. Neo ECUs do suck a bit.
    • Hello, I'm trying to make this thread basically the thread with all the answers to common questions regarding specifically the RB20 DE NEO + T engine, that comes in the R34. Answers will and only should be provided by those who have done this conversion or actually have some relevant real life experience please. Please feel free to ask questions in the comments if you have any so other members can answer. I feel like this thread is really needed, especially with more Americans buying (unknowingly going to regret it too) rb20 neo r34s. My first question being - What do you guys use for tuning? I have purchased a haltech elite 2500 Plug and play kit for the rb25det NEO because the ecu plug is the same, but I am unsure if any of the pins would need to be repined to match. Second question that I see asked very often - After this conversion, did you install the boost solenoid/ actuator? I see many people doing a + T setup on their rb20 NEOs while running stock RB25DET NEO ECUs with no tune. I am wondering how they are going about doing that and consistently abusing the car because many of these people have had these untuned setups running for a very long time. That was my original plan, but my engine cuts out at 5 psi of boost using the stock ecu with no tune and no boost solenoid/actuator.
