  On 02/07/2014 at 12:30 AM, juggernaut1 said:
@ Mark - here was my previous GT3071 setup revved to 8,000rpm so 4,000rpm would be around 112klms
Did the S15 have a 5 speed box in it?
If the gearing etc is the same that makes GTScoTT's GTX3071R capable of 20psi < 4000rpm - which is really quite impressive :)
Just picked up the car. Haven't had a chance to go for a proper drive yet, but here's the dyno plot:
Boost is both lower and later than I was expecting. I got the impression talking to Josh that they didn't quite solve the boost issue they were having. He mentioned potentially using a different rated actuator spring to improve things (currently 10psi).
Very happy with the quality of the install they've done though. They really took the effort to keep the stock / black theme, and using quality fittings for things like BOV return. Can post up pics if anyone is interested.
Hmm it's strange that it's coming on that late, looking at the curve it doesn't look to be a boost control thing to me. You are running Nistune? Is VCT being used?
That boost curve doesn't look like it is necessarily using the full potential of the turbo but as you mentioned, good chance the actuator is making it impossible to go any further. It's decent power for the boost through, I reckon - and while in the range of what seemed doable there could be a bit more in it with a stiffer actuator.
Let us know how it drives when you get more of a chance! Be interested in how quickly and easily it comes on, the curve makes it look no better than my old GT3076R which doesn't really make sense, I am assuming there is more than meets he eye going on there.
Also for sh!ts and giggles, here's comparison with previous stock turbo (just with exhaust, pod and tune).
When I get a chance will take some photos of install (looks very neat), and hopefully can feedback on driving impressions.
That comparison looks a heap better when comparing apples for apples. So is your Nistune setup running VCT? If that's not with VCT and there is more boost available then the result starts seeming a lot more understandable. Driving (ie, response) should give a fair bit more of an impression of how well it works :)
Thanks for keeping us updated through it all!
I have the Z32 ECU with Nistune so should still have VCT.
Aiming to get a decent drive in on the weekend, but power does feel great when it comes on. But impossible for me to gauge how it is compared to other setups except stock.
OK, interesting.
When you drove it did it feel conspiciously laggier than the stock turbo? A typical "full boost at 3750rpm" combo would feel very noticeable. Maybe we should just let you get the weekend and have a proper go? :D
Perth dyno's always read lower :whistling:
Yep just throw more boost into it once the control issue is sorted.....as it one thing the GTX's seem to thrive on.
Please post up pics.
Edited by juggernaut1
I thought the z32 ecu needs an additional window switch to control the vct.
Mat only very recently added vct control to the z32 ecu's. I would look into whet you actually have it or not.
A quick way would be disconnect vct plug and go for a drive. If it's the same you need to get it working.
Contact matt at nistune about the update.
  • Like 1
  On 03/07/2014 at 12:14 AM, Ben C34 said:
Yep. I got z32 and r32 confused!
Still worth checking as I mentioned.
Sounds easy enough to check. I assume it won't hurt anything if unplugged?
Lith, it definitely feels laggier than stock turbo. Need to get out on the weekend when less traffic around so I can try and get a better feel of when boost builds. I will say though that it feels like it ramps up real quick, whereas on dyno plot looks like more of a gentle increase.
Josh did mention that PZP's dyno tends to read low, but I'm not going to put any stock in that unless I can confirm somewhere else.
Can I also get some advice from you guys? I was told that to make use of higher boost, I really needed to look into freeing up flow more (cams, cam gears, and possibly freer exhaust). I was told the turbo actually has quite a bit more to give seeing as GTX series like higher boost, but couldn't get there without these changes. Does that sound right?
Definitely won't damage anything driving with the vct plug unplugged.
I wouldn't think cams are the best use of money at this stage.
Cam gears perhaps, but the dyno time to dial them in might not be worth it.
    • As you're looking at using a Link ECU, then large injectors are not a problem. But there's not really any need to go 1000s on an RB20 unless you're planning >>600HP on E85, which would seem unlikely. There are other options for injectors. The Xspurt ones are available from a number of places and you can get them in the mid 600s and 725cc, which is probably a sensible place to be. These are all EV14 based. If you are not using the stock AFM (at all, which would be the case with a Link) then a large turbo intake pipe to suit the ATR turbos is not an obstacle, so you should use one instead of a highflow. Results will be better.
    • Hey guys,  I'm after some advice and this here is the best place to get it imo. I was a member a looong time ago under another account, with a lost email address. Its nice to jump back on and see some of the same names still giving good advice.  I mothballed my car when i moved to perth in 2013, and after getting towed across the nullabor a few times it has officially done more km's on a trailer than under its own power. Now that i have started the process of tidying up and modifying it, i see the fruit available (and the fruiterers selling the produce) is different than back in the day. hence my questions, as i used to 'know' what to get and now, i'm not so sure. Engine wise the car (92 gtst) has a walbro 255, k+n, fmic, cam gears and and turbo back 3"exhaust. Wish list is a Hypergear high flow or ATR43G1, Link G4x and some newer injectors before a tune up. My goals are modest, only low 200's power wise. i know i could achieve this with less, but i've been swapping out old for new where i can. Every cooling hose has been replaced, along with mani gaskets, WP, thermostat and radiator, fuel pump and timing belt, tensioner and idler, and i rebuilt the steering rack. Regarding the injectors, the fruiterers all seem to sell what used to be considered quite large injectors. There are a lot of options for bosch 1000cc EV14's, and i would like to know if that is a suitable choice for my build. Is modern injector design good enough to run these at the low duty cycles that i likely would be? is there a downside to running a too large injector these days? or, would there be an upside to running a smaller injector at higher duty cycle? I can see that there are smaller injectors still available, but the ones i have seen specifically marketed for RB's are pretty large (see: https://golebysparts.au/collections/fuel-rail-injector-kits/products/nissan-rb20-fuel-rail-bosch-980cc-1150cc-injectors-turbosmart-fpr800-regulator-kit), and i dont know enough about them to say one not marketed for RB's would fit or not. I have searched the forums, and amongst all the posts on older tech, I did see gtsboy recommend EV14's, but no size was mentioned... again, i'm not clear on if the smaller size bosch injectors are also EV14's as they do look similar.  also, if someone can recommend a tuner familiar with RB's in the Geelong or West Melbourne area i'd appreciate it. Thanks in advance guys. Cheers, Rowdy
    • FWIW the depth of the groove in the rubber pad is not super essential, the blocks are rubber and squish a bit. If you are worried an angle grinder will make a deeper groove quick smart
    • I mean, if you were to move the jacking points away from the original location, that is, away from the wheels and closer to the centreline of the car, then it will be more likely to overbalance and tip off the supports. Same as we talked about before. I was talking about moving for-aft. If the sill is bent outward or inward, then the car would obviously look unstraight from the outside. Hopefully that hasn't happened either. Again, you can do comparative measurements from the chassis rails to see if there is much deflection.
    • Can you elaborate what you mean with your first sentence? I meant move as in the bulge kinda seemed like it got pulled "outward" meaning it got pulled down and to the side with the jacking rail itself, so the load bearing bulge now sits lower than usual and is not level with the sill on the other side of the jack point. Either that or the jacking rail just got pushed in a good bit.
