  • 3 weeks later...
Ok, so I've had some more work done to try and eliminate things which might be holding the GTX3067 back:
* Dump pipe changed from split dump to bellmouth
* Actuator changed from 8psi to 18psi
* Replaced cat (which was an older model high flow) with a 100 cell high flow
After the dyno run to check power etc, the sum effect of the above was... zero.
No change in peak power, no improvement in boost threshold.
Tuner said boost control is much better now, and that the dump pipe no longer gets as hot.
His recommendation next is to change out the turn-flow intercooler, but I'd rather look at mods for better response first if anything.
I've tried getting my hands on a 0.63 A/R IWG housing, but have been told no stock in Australia and Garrett is no longer manufacturing. I believe Disco mentioned this before too.
Option now is to source from US, or second hand (annoyed I didn't get the one AngryRB was selling now).
Only US supplier I really know of is ATP turbo. Any other suggestions?
If it were me id be keeping the housing and sending the turbo to FP , turn it into a HTA3073 and dump the turn flow intercooler, ive got the piping from intercooler to throttle for sale, could be done cheap.
Edited by AngryRB
Funnily enough I've been thinking about the HTA3073... but not ready to spend on changing turbo's again just yet. I'm actually pretty happy with how it's going at the moment, just it's always been bugging me about what it might be like with the 0.63 housing, which it probably should have had from the beginning.
Will see how I go sourcing a housing first.
What style piping do you have? Goose neck over the cam covers? Or over the radiator shroud?
I would lean towards getting the turbocharger right , I use the same IC and my at the time GTRS on its knees made 271 at the bags . Back then the tuner said boost pressure fell from 17 to 14 indicating that it was choking on the hot side .
A .
The one that goes across the radiator, not the best but works. I've gone the plazmaman plenum.
Maybe hypergear has a suitable housing that could bolt onto your turbo?
Edited by AngryRB
Having had the dump remade twice now to suit this Garrett housing, I'd be reluctant to change dump pattern again. I'd still keep the 0.82 housing in case of later upgrades (e.g. to HTA3073).
It sure is, and I tried to buy it through them, but they refunded my order saying they couldn't get any stock.
I absolutely hate it when they don't update their stock when they know they have none....... ass holes!
They didn't realise there wasn't any available until they tried to fill my order. I got the impression they ship direct from Garrett Aus and don't hold stock themselves so they weren't aware there wasn't any stock in the country. He said they'd update their website now they know.
    • Have you checked the foam over the years? No deterioration to the foam from e85 mixing in oil? (assuming you're on E85)
    • Add to this... What blew the fuse too? If a circuit feeding power to the coils was blown, how were the coils even functioning to let the car start?   There is some seriously wrong wiring in that car for certain, and I'm betting there is some melted cables somewhere, but I can't explain the 30v either, unless there is something back feeding on that power line that has a dodgy power system and the electronics are giving it hell.
    • This is typically the case with such threads. What I cannot quite get my head around is where a reading above 12V (or 13.8 or 14.x or whatever the maximum achievable voltage might actually be in that specific car) comes from. 25V or 30V should be completely impossible. There's no way to create it. Hard to answer that question. It will literally depend on whether the current tune relies on the values as set. I'd guess it probably does. ie, the real base pressure being 49 means that the flowrate through the injectors will be higher than if it was 43.5. The Haltech's modelling should be handling that, but because it thinks the pressure is only 43.5, then..... I dunno. It should be thinking that it will be injecting less fuel with each pulse duration than is actually happening. So, something is definitely not-as-it-should-be, but specifically what that is is beyond my abilities to imagine. Someone like Dose who spends more time with Haltechs might have a better thought.
    • Bit of a late reply here as me and my wife have been really busy with new born twins. I finally got these issues fixed and it was something really stupid that caused all of this 🤦‍♂️... After alot of mucking around with trying to figure out what is causing these issues, I back probed one of the R35 coils on the power 12v supply, with the engine running it got 25v! And I thought, hang on..., this isn't normal. Measured my battery with the engine running to check for over charge from the alternator and it wasn't that. So then I dissconnected the R35 PRP coil harness and backprobed the power supply on the engine loom where the ignition coil harness connects, with the key on ignition (engine off) it measured 30v! So then I had to trace where that high voltage was coming from and it lead me to the brown relay "ECM & IGN coil relay" inside the cabin next to the ECU on the passanger wall. This relay feeds power to the ECM and ignition coils. Tried swapping it with another same relay. nah still 30v.. coming from the 2 green/white wires in the brown relay. So then I set my multi meter to the beep continuity mode and probed every fuse on the fuse box inside the cabin to try and find this high voltage power source. Wasn't any of the fuses inside the cabin. Then probed all the fuses in the engine bay and BAM, got my power source that was a 10AMP fuse called "ENG CONT". Pulled the fuse out, and what do you know... it was blown. 🤦‍♂️  So then I quickly replaced it with a new 10AMP fuse, started the car and yeah haha [insert extreme face palm]... The RPM blimping thing went away, car idles smoothly now like what it was before. I swear! I checked all my fuses with my test light twice before I created this forum thread. I think, maybe because one side of that faulty 10A fuse lit up on my test light, I must have thought it was still ok and not blown. But now I know to have both sides light up on the test light when checking fuses... I hate diagnosing electricals.... I'd take mechanical problems over electrical problems any day🤣. Drove the car around my suburb with the engine up to operating temp and it runs fine like before. However, I notice that my fuel pressure is still at 49psi. So I'm thinking this must be normal for my system as I've upgraded the stock fuel pump to a Walbro 255L/h with a constant 12v mod.  But anyway, I'm just glad to have my daily back on the road! Thanks everyone for the replies on this thread, all sorted now! One thing I want to ask you tuner guys, my base fuel pressure on the haltech main settings are set to 43.5psi from default (my tuner must have not checked the fuel pressure maybe when tuning my car?). Do I set it to what it actually is idling on at 49psi? Or just leave it ("if it aint broke, don't fix it/leave it")?
    • The max they would go for me is 50.
