Talk so far with has only been about the 0.63AR IWG Garrett housing, so I'm assuming that will be the one, but I should double check. Fuel will be pump 98.
I'd be lying if I said I wasn't quite excited about it. Not only my first major mod, but also something a bit different from the norm. Hopefully it comes up with the goods.
Fitting one of those should be easier than all the other Garrett GT30 offerings because they use a smaller diameter compressor housing and a smaller inlet boss .
You maybe doing this at the right time because GCG tells me that Garrett are keen to ditch their GT30/35 IW turbine housings , and the plain type four bolt outlet types may all be going V band outlet .
I would go the 0.63 AR housing too on a GTX3067R because that's what Garrett generally offers standard . I would however ask for the big flap valve version if they aren't all like that now .
I'm also keen to hear the results of your conversion , going GT30 takes a bit of effort but once done any future turbo upgrades are much easier .
Hoping you''ll be impressed , cheers Adrian .
I've read about this big flap version of the housing elsewhere on here. Something about a -M on the part number or something, but everywhere else I've looked on the web I haven't been able to find any reference to it. Was starting to wonder if Garrett have just started offering the big wastegate flap version as standard.
I'll post full specs when I get the dyno plot to put up.
More reasonably recent threads are popping up involving the GTX3067R . There's an ongoing one at NASIOC where STi people are testing them and comparing them to GT3076Rs and GTX3071Rs . Some claim the 10 blade X67 wheel has better aero than the 11 blade vesrions , first I've heard of that .
Some are considering trying them with 0.82AR housings though most suspect more lag for small gain up high . Tial V Band housings are popular in the States and some opt for the 0.63AR ones with external gates .
Some numbers mentioned are 375 wheel Hp on their pump 93 PULP and again a bit over 400 on E85 . They get excited at full boost ~ 3000 revs and with limited tuning not so much at what goes on much over 6000 revs . Not saying they hit a wall just that they probably fall off in the 6-7 area .
The one that current uses love is the rapid boost transients and one feller who wanted an EFR 6758 reckoned basically why bother .
Good to see more interest in this turbo because for a truly light to moderate tune car it's looking like the tits so far .
Damn I wish these were out back in my FJ20 days .
A .
I think you would be the only person on this forum to use the words light and moderate in a sentence with the word TUNE.
The rest of us want to go fast, very f**king fast.
  • Like 3
Indeed. Though in fairness while I would pick a different turbo for my needs, my little crystal ball suggests that a GTX3067R on stock manifolds and engine on E85 would make a pretty impressively quick all around usable car.
Quantify light moderate - meaning effort and expense too .
Reasonably straightforward with sub systems not overkilled to the 500 Kw degree .
For example don't need the antics of 20a current draw fuel pumps and 2000cc injectors swirl pots etc .
Don't need 3.5 to 4" booming exhausts or an intercooler that's looks like the car was bolted to it not the other way around . Or a hole saw .
To me light moderate means something that's very easy to live with on a daily basis , that anyone can get in and drive round town feeling fine . Not to say it can't have great squirt and scare people it they boot it but you can have both worlds IMO .
Hard arse means choppy cams and solid face clutches , turbos that do f**k all under 4000 revs .
Everyone seems to peg Mick Os Skyline as a benchmark , it could have run any of the GT30 turbos . Would have been smooth and flexible to drive around town and all that'd differ is the boost threshold and the numbers . I think the dryer he chose took most standard and light/moderate tune bits fairly close to their perceived limits and I congratulate him for a great result too .
However , for someone who wanted performance they could use all day every day and occasionally cruise down the expressways at 110 a 3067 could do it for them too .
This is not to put down a GTX3071Rs abilities it's just saying in round town use the 3067 is possibly a better all rounder .
A .
Hi sir, any progress? Keep us up to date, there are probably a few people quietly intrigued to see how this comes out :D
Hasn't been much to report as of yet unfortunately. Apparently were some issues sourcing turbine housing, but turned up yesterday.
I'm super keen to see how it goes as well. I promise I'll put up results for review even if it turns out crap.
Cool, man - it's the internally gated Garrett housing? What boost control etc are you running? May need a good electronic setup to make it come on hard etc.
Good luck :)
Brief update. Parts have all just about arrived and Galvsport are looking to start install on Monday.
Parts invoice says it's the 0.82 housing though, which surprised me. At least it's the genuine Garrett one.
I agree. Will talk to Galvsport about it, as he mentioned some issue about getting the right housing for this turbo hence the delay in starting the install. I'm not clear on what the issue was though.
0.82 rear should be fine. It will help the turbine breathe nicely in the top end, and hold off the det a little longer. 0.63 might still be a little small imo. If only there was a 0.73 option... Perhaps Kando do one?
So is it internal gate?
Bugger. I don't think being 0.82 will be a failure at all, especially given it will be run on pump gas - though not necessarily my first recommendation for someone aiming for the old GTRS type response territory. As mentioned by Scotty it will have its advantages in terms of not choking the motor, it may prove surprising in terms of power and really I still expect response to be pretty impressive... Just not quite as aggressive as it could have been.
Let us know how you get on
Sent from my GT-I9505 using Tapatalk
    • have no doubt and wanted too trust me and may regret later not necessarily worried about weight (would be 8 kg ish total) it was more the $$ to do it properly is about $6 - $7K in hardwear need long 310mm stroke jacks etc - plus install and call me whatever im not doing it myself even if wanted too cant weld etc  - thats $10K installed vs fraction of that cost while Ive spent some money on this POS I actually really dont like doing so unless its got a large chance to make me go faster 😁 hey in still carting this things around on a 15 yr old rusted open trailer so I can spend on racing not buy a new trailer to look better the manual jacks Ive had done are heavy and take space but are transportable and usable anywhere - taking or organizing even compressed air let alone nitrogen which is more whats needed coming from Perth to Winton or Sydney or the like honestly just adds to my brain headaches/ hurts of organisation also ha 15 mins job will get down to 2 - 5 min job vs 1 min job for airjacks - all tradeoffs I spose
    • Purely out of curiosity, how do you know all this @dbm7? Do you work with automatic gearboxes professionally? This goes way way way beyond "I've had an automatic Skyline once and did some mucking around"
    • I'll just reiterate that it's best to do all the wiring diagnostics, before even thinking about buying replacement solenoids ~ that is, be absolutely sure the solenoid is bad.....ie; bad connector(s), rodents chewed through a wire, etc etc. If you don't so this, you can fork out all the money for solenoids, only to find something else is wrong (this'll make you cry if you pull the valvebody only to find a broken wire is at fault... ...some more glue on the solenoid packs -- this is the RE5R01A shift solenoid assembly.... ...these are all shift solenoids ~ ostensibly they're the same as the shift solenoids from the 4-speed auto.... ...this is the RE4R01A solenoid set... ...with these, you have 3 shift solenoids attached to the plate, and the separate solenoid is the EPC solenoid (line pressure control) -- with both designs, the TC lockup clutch solenoid (also PWM so they could slide the clutch shut), is located on the lower valvebody half.... ...(story time)...back in the 90's, it was a common fault that the EPC solenoid (or TC-lock solenoid) would fail, but Nissan only sold them as part of the assembly (think ~$350 at the time) ~ thing was, Isuzu also used these boxes in light commercials, and you could buy the PWM solenoid as a separate part, so it was possible to buy/use that solenoid (around $65), and make it fit (remove the circlip, fit to old plate and deal with wiring)...making it a more cost effective repair. I've not seen the RE5R01A shift solenoid assembly, but with the 4-speed RE4R01A it was possible to hack/fit a single shift solenoid onto an other working set, using a donor solenoid from another set with failed EPC....(by rights the whole set should be replaced), but it ends up being a question of how much life is left in the box itself ; sometimes it's a viable repair to fix one solenoid, just to get another 100k of road miles out of it before it needs first overhaul...other times the box is that old/worn, you're as well doing first overhaul and replacing the solenoids and starting fresh... What Nissan did here with the 5-speed, was relocate the EPC solenoid to the lower valvebody (next to the TC lockup solenoid), and stuck the direct-drive clutch solenoid (for the extra gear) where the EPC solenoid used to be on the 4-speed....I can only imagine they did this for serviceability ; the PWM solenoids are most likely to fail, and it's a doddle to drop the pan and change these out (as opposed to dropping the valvebody itself to get at a top mounted EPC)... ...also keep in mind, that some BMW 3/5 series & Mazda (and maybe some Ford/Mazda rebadges, not sure), also used the RE5R01A box under a different name/part number...not saying parts availability is any better, but sometimes it helps to know this when it comes to NOS floating about in the EU.... HTH
    • FWIW, air jacks are actually pretty light and simple to add, they are just 4 hydraulic cylinders (often at the main cage A and C pillar points) and an externally accessible airline  - they make quick work a breeze
    • Maximum Attack has entered the chat
