Hi Guys
Up for sale is my r33 gtst series 2 1996 model project car 105600klm on the clock
current modifications
just rebuilt the head completely
superspark coil packs
just did timing belt service with crank seals and cam seals with gates racing belt
whiteline swaybar front and back
strut brace front and back
cusco tension rod brace
nismo solid shift short shift
GTR spoiler carbon fibre
tinted windows
black wire alarm system
braded brake lines
3 inch stainless exhaust from turbo back
HDI GT2 front mount intercooler
turbo smart BOV
forward facing plenum
Tomei 264 cams int and ext
bride carbon style seats
turbo smart eboost street boost controler only boosting at 6psi at the moment as the fuel system needs to be upgraded first
K&N POD filter with Hi Octanedirect POD box
will come with walbro 255L fuel pump and fuel rail if the price is right
probably forgot things but will add as i remember.
car gets serviced every 1000klm for oil and filter motul oil always used
gearbox and rear diff serviced every 2500 motul oils always used
car runs great would finish the car off myself but i have just started my own business and need to cut my overheads looking for $10000 happy to negotiate have original seats so i can reinstall them and take the bride seats out and not include the extras if you want to drop the price
if you want more photos pm me car in sydney NSW 0414188763
    • Hey lads, reviving an old thread.  As an update, since the last time replied to this thread, ive done mostly suspension. Havent touched the motor except for maintenance. Though upon changing spark plugs, found out i had splitfires pre-installed! Updates: - Got me some stock airbox top cover and snorkel to fit onto the original intake. Should be free of defects - Bought a set of R34 GT-T brakes (not installed yet, going to rebuild + respray in champion blue + white 'Nissan' text) - Bought the last set of bilsteins from @Sydneykid and had them installed. Has been making some sounds on the rear but hopefully should be sorted out after this New Year break. - Regreased front caster rod bushings (poly bushes..) - Rear upper camber arms - Whiteline sway bars (BNF27Z 22mm + BNR11XXZ 24mm).  The rear sway bars are a bit short (ive read 50mm else where) but was still able to get them in.  Anyhows, I reckon suspension is sorted now. Maybe replace bushes (do have a set of front upper control arms from SK not installed yet) but should be okay for now. From now, I'm wanting to start working on the motor, drivetrain etc etc. Still debating on the order to go on and what to buy etc but: - ECU ( Haltech or Link ( Link states that it dont support A/T or AWD functions... Can anyone attest to this? ) - Highflow turbo ( ATR43ss2 ) - Intercooler ( Not decided yet, but cant find many good afoordable ones. Toshi says to opt for crossflow Japanese. Bit difficult this one, unless I get a returnflow Blitz from JJ? ) - Injectors ( Any recommendations ? I do have a nismo FPR ( Thanks SK ) ) - Seats - Tune by either Toshi or DVS To be fair, I did consider just keeping the stock turbo and nistuning it. Sat in a mates stock N, that had something like 200kw, and I reckon that felt more than enough. Maybe I should just go this route ahhaha. Too many choices.... Planning a trip down south, so wanting to just clean things up and make sure it gets to and from in one piece. Anything else specifically I should do before ? Cheers lads
    • Must be for the car’s lucky charm 🤷🏽‍♂️ She runs fine, but it just seems to take about 1L less. Maybe I’ll have the oil sump dropped at some point to check if there is anything
    • Hmmm interesting. Mine is the exact same and clearly the right one.  The mystery of the engine oil being full after 3.5-4L continues
    • Yes I as well would like to find out where I could get some of the seat material with the red or blue small squares in it
