Hi Guys,
My new turbo is going to into my R34 GTT soon and so a retune is in order
After a talk with my mechanic and him talking to Insight, my car is due to go on the dyno in 2-3 weeks
I just wanted to see if anyone else has had their car tuned there and what was your experience with them?
How was the staff? How did your car run afterwards?
Thanks in advanced
https://www.sau.com.au/forums/topic/419978-insight-motorsport/
I and a couple of other members on NSCC have had there cars tuned by Scott at Insight. He did an awsome job on my car and sorted a few issues that were not picked up by my previous tuner.
His Dyno cell is a work of art in technology.
You will be pleased with the result
  • 3 weeks later...
So the car got dropped off on tuesday morning and I picked it up around midday wednesday after the cold start tune
Car made 220kw on 16psi, Maxed injectors and AFM
I am loving the car, a lot more low end torque, boost is holding throughout the revs.
They also fixed an idling issue I was also having.
The guys at Insight were great to talk to, had a lengthly discussion on options for the car down the track
I am very pleased with the outcome
Just that the injectors and AFM were maxed.
Ill put 1000cc injectors and I'll need to change the ECU, thinking Haltech
Also a problem with the VCT which ill make sure is fixed before the next tune
Had to weld a new bracket for the wastegate as the one on the turbo wasnt strong enough to hold boost
That seems ridiculously laggy for the power output, GTRS especially. Did they say you had to address anything after the tune?
There are afew possible reasons that could have caused this, that R.o.B. hasn't mentioned, in terms of the extent of modifications........
Hpi turbo to cat downpipe
Hks exhaust
Hks mushroom filter
R33 GTR Intercooler
Apexi PowerFc
Bosch 044 fuel pump
HKS GTRS Turbo
Turbosmart Wastegate
Greddy Profec B II boost controller
As an engine builder myself, having the right tune for start up (Standard - Standard Factory tune is sufficient.......Modified with Nistune or aftermarket ECU - for anything out of the norm, besides a test start up,dyno is recommended!) after a rebuild is critical. A handful of engine rebuilders I know (which includes touring car/race car engineers) will only warrant (high performance street) engines tuned by Scott at Insight Motorsport!
As a racer for years, both drag & rally, Scott's tuned some of the best. I've pulled up at his workshop & heard something on the dyno before I get out of my car, only to find Scott tuning something like Glenn Seton's old Peter Jackson Ford Sierra RS500 Touring car or 500kwatw F2 procharged street car!
My only advice, as an engine builder, is preparation. Plan - talk to everyone! Find reputable engine builders & tuners. Talk to them, tell them what YOU want to do, examine the pros & cons. Collect parts that are going to work for what you want, then start letting the spanners fly. Don't deviate from what you want your car to do (bigger numbers coming on at 6500rpm are not as good as slightly lower numbers at 4500rpm - depending on the application).That way,when tuning comes around, you won't be disappointed by a mismatch in parts.......
Ok, so your intake hasn't been greatly increased by a HUGE front mount. Are your cam sprockets standard? Is your intake manifold standard? How well does the Power FC handle the operation of them both?
Sprockets and intake manifold are standard
Is your PFC causing this or is it an oil issue? The oil passages around there are pretty fine,make sure they aren't blocked. For a standard setup, when you hit 4000rpm, the engine should pull hard!
I ah, *AHEM* hate missing stuff, but yor PFC might be causing you issues.
My first question is, who tuned your car at Insight?
POSSIBLY, there could be timing issues that could hamper the operation of the VCT or manifold operation? Please, anyone, correct me if I'm wrong! How many km has your engine done? When was the timing belt changed, was it correctly fitted (as to cancel out a mismatch between crank & 120 degree reference 1 & 2 - 1 tooth advanced could make a difference!)?
Unsure, my mechanic hasnt had a chance to have a look at the VCT since the tune
I'll mention this to him though
Either Scott or Bob would of tuned it.
Engine has done early 150k from memory
Timing belt was replaced before I got the car (April last year)
    • I went from stupid 600+HP setup, to an NA Barra in mine...
    • You have the option to do this. Nobody but me ever did this (go slower, I mean) Everyone seems to fall victim to "This would be a great setup for you, but for me, I need a little more power..."
    • Save yourself the headache of an alarm. Immobilizer on the signal side of the main EFI relays so it won't start is good enough. DIY killswitch is the same thing except instead of a nice passive system you need to remember to switch it on and off.
    • Yeah, the advent of canbus was supposed to cut down on wiring weight, then some bright marketing wonk says "oh, look at all these wonderful tech gadgets we can cram in here now that we have this wonderous technology" and some arsehole safety legislator says "oh, look at all the wonderful surveillance and tracking gadgets we can cram in here now that we have this wonderous technology" and some dipshit young engineer who has grown up thinking that an extra 500000 lines of code is not a problem because storage is cheap these days says "oh look at all this wonderful shit I can do to one up those dipshit arsholes over at VW" and the Karens of the world all go "oh look at all these fancy things I can do on my screen (so long as I am not driving on a bumpy road wherein touch screens immediately become the single most stupid shit idea ever shoveled into a car) and my 19 zone airconditioning keeps my sweaty fat folds a bit less damp and the windows close themselves because I'm too fat and lazy to wind them up for myself and these reversing sensors would have been great if I'd paid attention to them instead of smashing them on the bollard while I was reversing and staring fixedly forward that day I went to pick up little Charlize from ballet" and the sweaty mongoloids who say "oh this wonderful collision avoidance technology with these 45 excellent radar antennae scattered across the front of my car mean I can tailgate like a methed up tradie at full speed with no fear because the car and the 35 airbags will protect me if it all goes wrong" ...... </shallistopranting?>
