Stripping 2X Rb25Det Motors One Was Running
Complete head with covers $240
Complete head with adjustable gear no covers $240
Complete bottom end running with sump $250
Injectors and rail $50
Crank angle sensor $60
Balancer $30
Intake plenum $40
Ac pump 40
Alternator 50
Power steer pump 50
Throttle bodie $30
Tbs $30
Flywheel $40
Engine brackets $40
Engine mount very good nick $40
Rb25 turbo and lines $90
Turbo Manifold $30
Coilpacks all working $40
Coilpack harness very good condition still soft $80
Injector loom $40
Engine loom complete not chopped $150
Under plenum loom $40
Knock sensors $30
And anything else I have missed
Gold Coast
0487924497
 Share
    • Yes, it's similar length.
    • Is the CD009 similar length from bell to shifter?    car will just be for the street with the odd track day. It’s RB30det, and weighs about 1000kg
    • The r34 gearbox is like $3400/3700 landed from Japan sometime last year.   Contact jessestreeter.com for info and quotes. From memory the navara gearbox needs input shaft machined down as I looked into a while back and there's a thread somewhere here from 2018-2021 about it. Depends on what your doing with the car maybe worth the dollars to go cd009 or a 8hp50/70.
    • VCAM doesn't really increase peak power, it just widens the powerband. So if you were giving up power with adjustable cam gears to get better low-end response yes in theory it "increases power" but otherwise not really. Stroker kit might put you in a more efficient region of the compressor map which will get you more power but at say 7000 rpm I'm not sure that much will change. The original HKS GT2530, -5s, and GTX2860R gen 2 are all roughly the same kind of turbo. If you want 600 horsepower those are the turbos you need. So 500 whp. Just expect to spend some quality time trying to figure out intake/exhaust piping. The "twin turbo" pipe is an obvious place to start. Make sure the actuator preload and all of that fun boring stuff is set up correctly. Throw a VCAM step 2 at it if you want good response, 2.8L stroker too. If you're not actually wedded to 500 whp all the time you can barely get there with -7s or Nismo R3 turbos, you just have to run E85 or race gas and run them hard:
