OK peoples, done some preliminaries.
We will get a w/end of speed .
Goes like this ATM
Arrive in Collie bout 10am Sat , out to the track for a looksee around the circuit, some basic training and then proper timed laps.There will be flag marshalls , fire crew and ambo's.
After that we have 1/8 mile drags ( unfortunately only one at a time cos of insurances. )
We also have a ,ermm, motorkhana which allows for some free expression ( insert go nuts )
O/night dorm style with showers etc but bring own sleeping bag ( no , not your g/f stupid !! ) and pillow.
May even be a bar set up by then and the prices are reasonable I have been told.
Get up on Sunday and start all over again about 9.30 till we packup at about 3 pm to go home.
Am asking for late Nov , early Dec and price will be about $150 per head based on thirty people.
Will need names , numbers and deposits but will keep you informed as prices and dates are firmed up.
This is being done in conjunction with the Performance Forums guys so we can get the numbers
Ken
https://www.sau.com.au/forums/topic/4200-wend-of-speed/
Mick
I was asked to put something together cos nobody else could be bothered. It's all done thru the new Motoring Southwest Car Club who control the Collie Powerhouse circuit
There is no profit in it for me, it just helps the club.
And it should be a good fun w/end :) :burnout: :pissed:
https://www.sau.com.au/forums/topic/4200-wend-of-speed/#findComment-67330
I'm a member of motorsing southwest. and have been in a weekend of speed with all fours.
I camped up there with a few friends.
They do club membership for $12/year
Insurance (cams lisence) is $30/day or $80/year (I think)
$150-200 sounds a little steep, but if there is full fire crew, flag marshalls and ambo's i guess it'd be close.
With allfours, we had open track all day saturday. To drift or put down fast times.
Had some burnouts later in the day.
Had a hillclimb on sunday.
Drags and motorkhana sound like fun.
btw I can get slicks and stock 16" wheels for about $50ea
keep me posted.
https://www.sau.com.au/forums/topic/4200-wend-of-speed/#findComment-67484
keep me posted.
CMS drifter
If your a member then why don't YOU organise it.
As I said , there's no money for me . These are the prices your Club Prez , Phil Boston emailed me. In fact he said today it may be more.
If you have a problem with the pricing , ask him.
Ken
https://www.sau.com.au/forums/topic/4200-wend-of-speed/#findComment-67703
Canned
Not enough interest and the usual Too from the PF guys and gals. Thats
Too far
Too soon
Too expensive
Too rough !! FFS
Too many exams
and a few more Too's I won't go intoo
Anyway , will prolly organise a one day track and expression session down there in the new year cos that was the only date avaliable till Xmas
https://www.sau.com.au/forums/topic/4200-wend-of-speed/#findComment-68957
    • Lucky man, who owns it in the family? Any pics?
    • The engine stuff is Greg Autism to the Max. I contacted Tony Mamo previously from AFR who went off to make his own company to further refine AFR heads. He is a wizard in US LS world. Pretty much the best person on earth who will sell you things he's done weird wizard magic to. The cam spec is not too different. I have a 232/234 .600/603 lift, 114LSA cam currently. The new one is 227/233 .638 .634. The 1.8 ratio roller rockers will effectively push this cam into the ~.670 range. These also get Mamo'ified to be drilled out and tapped to use a 10mm bolt over an 8mm for better stability. This is what lead to the cam being specced. The plan is to run it to 6800. (6600 currently). The Johnson lifters are to maintain proper lift at heavy use which is something the LS7's supposedly fail at and lose a bit of pressure, robbing you of lift at higher RPM. Hollow stem valves for better, well everything, Valve train control. I dunno. Hollow is better. The valves are also not on a standard valve angle. Compression ratio is going from 10.6 to 11.3. The cam is smaller, but also not really... The cam was specced when I generated a chart where I counted the frames of a lap video I had and noted how much of the time in % I spent at what RPM while on track at Sandown. The current cam/heads are a bit mismatched, the standard LS1 heads are the restriction to power, which is why everyone CNC's them to get a pretty solid improvement. Most of the difference between LS1->LS2->LS3 is really just better stock heads. The current cam is falling over about 600rpm earlier than it 'should' given the rest of my current setup. CNC'ing heads closes the gap with regards to heads. Aftermarket heads eliminate the gap and go further. The MMS heads go even further than that, and the heads I have in the box could quite easily be bolted to a 7.0 427ci or 454 and not be any restriction at all. Tony Mamo previously worked with AFR, designed new heads from scratch then eventually founded his own business. There he takes the AFR items and performs further wizardry, CNC'ing them and then manually porting the result. He also ports the FAST102 composite manifold: Before and after There's also an improved racing crank scraper and windage tray. Helps to keep oil in the pan. Supposedly gains 2% power. Tony also ports Melling oil pumps, so you get more oil pressure down low at idle, and the same as what you want up top thanks to a suitable relief spring. There's also the timing chain kit with a Torrington bearing to make sure the cam doesn't have any thrust. Yes I'll post a before and after when it all eventually goes together. It'll probably make 2kw more than a setup that would be $15,000 cheaper :p
    • Because the cars wheels are on blocks, you slide under the car.   Pretty much all the bolts you touched should have been put in, but not fully torque up.   Back them off a turn or two, and then tighten them up from under the car with the wheels sitting on the blocks holding car up in the air.
    • Yes. Imagine you have the car on the ground, and you mine away all the ground under and around it, except for the area directly under each individual wheel. That's exactly how it'd look, except the ground will be what ever you make the bit under each wheel from
    • Yes, if you set the "height" right so that it's basically where it would be when sitting on the wheel. It's actually exactly how I tighten bolts that need to be done that way. However....urethane bushes do NOT need to be done that way. The bush slides on both the inner and outer. It's only rubber bushes that are bonded to the outer that need to be clamped to the crush tube in the "home" position. And my car is so full of sphericals now that I have very few that I need to do properly and I sometimes forget and have to go back and fix it afterwards!
