Is the last photo supposed to be up there?
looks as though the rear seal in the gearbox is leaking slightly, hard to say for sure from the pictures but looks like it has a slow leak and as you drive along it pushes all the oil back into the exhaust
It had a heavy duty clutch put in just before I bought it so guessing the mechanic did a shit job?
The fluid on the exhaust is dripping down from above.
Theist pic I thought I'd pic there just in case and if I don't get an answer for it I'll post it in a thread on the suspension section.
What do I do about the leak? Take if back to the mechanic and get him to do if properly this time?
Thats a leak?
I can't see where it's actually dripping.
Even if it is leaking, it's an advanced anti rust feature that slowly administers an advanced lubricant to the under carriage. Ingenious design!
R33 GTS-T
With regards to the last picture what I experience sometimes is a similar sensation to driving over one of those street lines that has all the bumps and kind of hums. So I figured the tyres were rubbing on something. And if you look in the pic on the bit of metal above the wheel you see it has been rubbing on that but I can't find a particular circumstance when it occurs. Probably happens most when going downhill.
Yeah I wouldnt stress about that, I have about the same gap on my UCA and dont have any issues. Is the rubbing in a straight line or when turning, I think from your description it is just straight driving. Its not the tyre rubbing on the inner guards or anything like that? mine does that sometimes.
O.K so where it is rubbing should move with the wheel as it is attatched to the hub. Should be able to see what I'm talking about from these screenshots:
This is the front hub:
I've circled the bit in red to match it up to the front suspension:
So the red bit is what joins the hub to the arm that you can see rubbing on. So the only way I can see the tyre rubbing here is if you have to much wear in the 'king pin' or somewhere there. It shouldnt be able to rub there as it should move with the tyre/suspension so I would check around there to make sure there arent any problems
Perhaps take it somewhere for a suspension check. Like pedders etc and tell them what its doing
Edited by 89CAL
Not in the engine bay, that's for sure. You know where the gearbox is? The fill hole is on the side of it. Check level there. Car on hoist stuff.
Yeah I thought it probably was, was hoping for an easy check I guess. Need a hoist? Can't get under there with a trolley jack and stands?
Yeah can't even understand how it's possible...
just undo the bung on the side of the gearbox (with the car level of course). stick your finger in the hole, there should be oil right up to the hole, but no more. if you have to shove your whole finger in there and reach down to find it, then it needs a top up. i had the same issue recently. the seal itself is cheap and easy to replace, but the exhaust and drive shaft need to come out to do it.
    • Can also confirm these work a treat for most balljoints and bushes. If you have access to a big rattle gun, they make the job so much easier and quicker, compared to using a socket wrench or shifter on the c-clamp 👍
    • Its sort of street but got used for circuit sprints on account of I never drive it on the road because I dont have the time to spare. So it usage was sits around for months at a time then gets driven either 50 or 250 kms to the track followed by 20 laps followed by 50 or 250kms home followed by stuck in the shed until next time. So yeah neither fish nor fowl. Just dont want to break it on the track as a preference. Hence the fairly short sensor/mod list. Probably more worried about it pinging itself to destruction more so than anything oil related.
    • My thing I'd be doing, is pulling it out, and just getting the tune cleaned up for now. Before that even happens, checking over everything, like vac hoses, fuel hoses, etc. No point dropping thousands on sensors if the moment you start it back up all the oil leaks out, or it has massive vacuum leaks etc.   But really, to know what to do, depends on what your use case is. Hard core track car? Throw most sensors available at it. Street car, I'd probably just run oil pressure, oil temps, water pressure, water temp, probably fuel pressure too. I don't know exactly what the Link can handle and do with those though. And if it's mainly just to cruise the streets, rather than mountain runs, you can probably skip most of the above if you've already got them in as gauges and warning lights.   PS, inb4 "sell it and buy a modern sportscar"
    • Keen to see the turbosmart data, to date I've only seen negative things in terms of response for them. Very small sample size though.     Hawkins is a big advocate in his videos of the larger rear housings. I managed to make similar power with a lower spec motor on the smaller .8 rear, keeping decentish spool.  The people he works with now are big power cars compared to mine though, mine really is setup to drive around and enjoy.  I don't have any back pressure monitoring though, so couldn't say if its good or bad on my car, just that it does what I want it to do.   Future I want a higher compression more cubes motor to give a bit more bottom end and hopefully the new g35-1150 gets me to the 850 rear comfortably.  But maybe I won't due to exhaust back pressure.
    • No, I refuse to buy their cheap ass crap! I do need to order a bunch of different nuts/bolts to refill my nut/bolt wall though. Maybe you could go for a walk through Bunnings for me? (Or send me some stuff from your work? )   I really struggle to work out how the US standardised to Metric in what the 70s or 80s, and yet, half a century later, there's been little done to actually bring it into fruition. It truly baffles me    On the whole Fastenal thing, I went reading their site (My god they sell a lot of varied stuff!), and it seems like it really depends what store you're near if you can walk in and just grab a few small things, or if that branch is primarily distribution with only a small window of "counter time" available (if at all). That definitely makes it harder, as move locations and it drastically changes your ability for success   For things like your M6x1.0, if you want to work on your own Skyline, and you also have a "home workshop" I'd recommend setting yourself up a small Nut/Bolt wall/section. It doesn't even need to be big at all. Most things depending on the diameter, will be a specific pitch, like the M6x1, M5x0.7 etc. Bigger bolts is mostly 1.5, except for a small number of things and that will come down to torque. From memory bolts for the brake calipers (and other things that need a lot of torque) will end up being a 1.25mm pitch. Save up a few dollars, and order a range of nuts/bolts. If you want to minimise cost a little, buy something like M6 x 40, and M6x70mm (1mm pitch) in both. In addition, buy yourself an M6x1mm thread chaser. That way you have long bolts that you can cut down to size, and then chase the threads out. Funnily enough, I find what I'd pay here for ordering 5 bolts, I can pay about 50% more and you'll get 100 of them.   If that doesn't quite work out due to space / ability to buy plenty up front, then each time you need some bolts, order 100 of what ever you're getting. Put them in clearly marked containers. Over a few years, you'll acquire plenty of different sizes, and will end up ordering less and less. And the cost for 100 bolts won't be much more than you paid for your 5 you needed to order anyway  Just takes a little planning ahead, by investigating what nuts/bolts you'll need, and ordering them before doing the job.     Edit: If it's also primarily for working on just the Skyline, for some reason my brain is screaming that at some point, either Nissan, Nismo, (Or possibly a third party) was selling a "kit" of every nut and bolt in a Skyline, purely for people restoring/rebuilding. It'd likely be quite expensive, but would give you every/any nut/bolt you need for stock/factory things. I'm not sure if it's still available, or even if it actually fully came to market, it's just something niggling in the back of my brain that you could look into further if that sort of thing interested you? (It might have been for the R32 GTR or something specifically too, and not just any Skyline)
