Looking at re-wiring the car and replacing all the individual looms. Any suggestions of decent auto-electricians or companies that do this? Did have two options but both are unable to do so in the near future.
Cheers,
Dan
A skyline. Dude thats a massive job and wiring will never match up to factory codes
You can buy kits from rocket industrie that cover a large amount of stuff for a basic car or race car
But to do a line ? Why would you unless you had a new oem harness
https://www.sau.com.au/forums/topic/420017-car-re-wiring/#findComment-6753419
In short without going through all the details, re-wiring the engine-bay while the car is getting a re-spray and the engine is out. Had a few issues with the way 2-3 workshops have wired it up in the past so deciding to get 'disgusting' wiring done properly. Did have someone lined-up but unfortunately his co-partner is retiring leaving him to run the normal everyday business and not focus on complete cars.
Cheers 4door - can you pm the contact details? (or I'll just find the online/on here)
https://www.sau.com.au/forums/topic/420017-car-re-wiring/#findComment-6753632
I know Simon Michelmore does this - not sure if he will do it for a 'non-friend' (ie. he doesn't have a business as such), but you never know .... https://www.facebook.com/simon.michelmore.7?fref=ts
https://www.sau.com.au/forums/topic/420017-car-re-wiring/#findComment-6753983
Cheers Andrew - worth a shot
https://www.sau.com.au/forums/topic/420017-car-re-wiring/#findComment-6754543
I done this myself for my toyota,
Got a ARC 8000 switch panel and a 4000 switch panel. Wired up a positive to everything that needed power and a switch job done.
Loom for engine on the other hand that was a bit more work.
https://www.sau.com.au/forums/topic/420017-car-re-wiring/#findComment-6755613
    • First up, I wouldn't use PID straight up for boost control. There's also other control techniques that can be implemented. And as I said, and you keep missing the point. It's not the ONE thing, it's the wrapping it up together with everything else in the one system that starts to unravel the problem. It's why there are people who can work in a certain field as a generalist, IE a IT person, and then there are specialists. IE, an SQL database specialist. Sure the IT person can build and run a database, and it'll work, however theyll likely never be as good as a specialist.   So, as said, it's not as simple as you're thinking. And yes, there's a limit to the number of everything's in MCUs, and they run out far to freaking fast when you're designing a complex system, which means you have to make compromises. Add to that, you'll have a limited team working on it, so fixing / tweaking some features means some features are a higher priority than others. Add to that, someone might fix a problem around a certain unrelated feature, and that change due to other complexities in the system design, can now cause a new, unforseen bug in something else.   The whole thing is, as said, sometimes split systems can work as good, and if not better. Plus when there's no need to spend $4k on an all in one solution, to meet the needs of a $200 system, maybe don't just spout off things others have said / you've read. There's a lot of misinformation on the internet, including in translated service manuals, and data sheets. Going and doing, so that you know, is better than stating something you read. Stating something that has been read, is about as useful as an engineering graduate, as all they know is what they've read. And trust me, nearly every engineering graduate is useless in the real world. And add to that, if you don't know this stuff, and just have an opinion, maybe accept what people with experience are telling you as information, and don't keep reciting the exact same thing over and over in response.
