i have my GTR32 for abt one year,should i modify my GTR or sell it to get R33GTR??
someone tell me R33GTR much better than R32GTR,what do you guys think?
here is the spec for my GTR32 and plz told me what to do next?
1994 white,zeal racing suspension,17 inch N1 wheel,N1 exhaust system,up grade ecu,up grade clutch,nismo side skirt,
should i modify or sell??
https://www.sau.com.au/forums/topic/42002-what-should-i-do-abt-my-gtr32/
Who says the 33GTR is better?
THey are both excellent cars, same engine...
My opinion is the 33GTR looks better, but not everyone agrees - its a personal preference.
Stock the 32GTR is quicker - its lighter and a stiffer body/shorter wheel base so it handles better...
yes,my car are in excellent condition and engine are running very well,have no problem with the car,
coz i already have the car for over one year and i think is time to up grade or change the car,
they told me R33GTR have better turbo than R32GTR and body are stronger,
thats why i think may be up grade to R33GTR,
should i change? or i should use the money to modify my GTR32?
Vspec 32GTR attessa was quicker than non vspec... non vspec checks 4 times a second, i think vspec 32 checks 100 times a second...not sure of the specifics...
its up to you... don't think the body on the 33 is stronger. like i said, 32 has a stiffer body/shorter whele base and handles better stock...
not sure about the turbos - just upgrade yours then they will be better than all the series stock turbos :P
if you like the r32 gtr thats in ur garage but ur bored with it, the rb26 has very long lists of parts available aftermarket that can be used to make the car faster ect. if you got a sweet car already why not modify it and improve on it
R32 GTR is the only real Godzilla. The others just ride on the reputation forged by the R32 on the Race Track.
thats obviously why in japan 33 gtrs and 34 gtrs are popularly raced in n1 racing series, or at drag racing meets there are plenty of the later model gtrs sitting there ready to stop the clocks at impressive times....
or why the r34 is known to have held the lap record on the nurburgring (sp?) something porsche didnt like at all....
whilst i agree that the 32 gtr was designed for the track and is an awesome car, i dont think you can say the later gtrs are riding along on the 32 gtrs improvement.
with each revision came better technology, the attessa 4wd systems for example, in the later gtrs run faster and process information faster making them inherently a better system
there might have been a r32 godzilla but there has also been 400R, nur spec ect
tho i may be misinformed, forgive me, i just own a gts :):P
i think its all depend on you,if you like R32GTR,than you just modify the car,if you like R33GTR,than just sell your car and buy the R33GTR,
i think R33GTR looks much better than R32GTR,but R32GTR more fun to drive than R33GTR,R33GTR are very big car not very good for track use,R32GTR are better for the track day,
good luck mate
    • Very nice - I also have a 92 GTST and hardly see any others around these days
    • When I need something else to edit, I use Movavi. A friend who does video editing on a daily basis recommended me) it's an easy video cutter to use for beginners
    • I need to edit some videos for work but I'm not good at all this. Which video editor can you recommend?
    • I think you're really missing the point. The spec is just the minimum spec that the fuel has to meet. The additive packages can, and do, go above that minimum if the fuel brand feels they need/want to. And so you get BP Ultimate or Shell Ultra (or whatever they call it) making promises to clean your engine better than the standard stuff....simply because they do actually put better additive packages in there. They do not waste special sauce on the plebian fuel if they can avoid it. I didn't say "energy density". I just said "density". That's right, the specific gravity (if you want to use a really shit old imperial description for mass per unit volume). The density being higher indicates a number of things, from reduces oxygen content, to increased numbers of double bonds or cyclic components. That then just happens to flow on to the calorific value on a volume basis being correspondingly higher. The calorific value on a mass basis barely changes, because almost all hydrocarbon materials have a very similar CV per kg. But whatever - the end result is that you do get a bit more energy per litre, which helps to offset some of the sting of the massive price bump over 91. I can go you one better than "I used to work at a fuel station". I had uni lecturers who worked at the Pt Stanvac refinery (at the time they were lecturing, as industry specialist lecturers) who were quite candid about the business. And granted, that was 30+ years ago, and you might note that I have stated above that I think the industry has since collected together near the bottom (quite like ISPs, when you think about it). Oh, did I mention that I am quite literally a combustion engineer? I'm designing (well, actually, trying to avoid designing and trying to make the junior engineer do it) a heavy fuel oil firing system for a cement plant in fricking Iraq, this week. Last week it was natural gas fired this-that. The week before it was LPG fired anode furnaces for a copper smelter (well, the burners for them, not the actual furnaces, which are just big dumb steel). I'm kinda all over fuels.
    • Well my freshly rebuilt RB25DET Neo went bang 1000kms in, completely fried big end bearing in cylinder 1 so bad my engine seized. No knocking or oil pressure issue prior to this happening, all happened within less than a second. Had Nitto oil pump, 8L baffled sump, head drain, oil restrictors, the lot put in to prevent me spinning a bearing like i did to need the rebuild. Mechanic that looked after the works has no idea what caused it. Reckoned it may have been bearing clearance wrong in cylinder 1 we have no idea. Machinist who did the work reckoned it was something on the mechanic. Anyway thats between them, i had no part in it, just paid the money Curiosity question, does the oil system on RB’s go sump > oil pump > filter > around engine? If so, if you had a leak on an oil filter relocation plate, say sump > oil pump > filter > LEAK > around engine would this cause a low oil pressure reading if the sensors was before the filter?   TIA
