Hi Guys,
Been 10 years in the making but have finally taken ownership of a prestige condition 2001 R34 GTR Vspec 2 in Bayside Blue. This has been one of my all time dream cars! Have been in the car scene for over 15 years, starting with a 81 Pulsar, to a Honda Civic show car, to drift weapon 180sx, to a pimped s2000, to a balls to the wall 310kws Evo and finally to the GTR!! So let the build begin!
Vehicle:
2001 Nissan Skyline GTR V-Spec 2 in Bayside Blue
Engine:
RB26DETT
Current Mods:
Apexi Power FC
HKS 120mm Intercooler
HKS Piping
HKS Dump pipes
HKS Front pipes
HKS Cat back "Silent Power" Exhaust
HKS EVS Boost controller
Trust BOV's
Aftermarket 2 way Rear Diff.
Current power 262kws @ the wheels (about to be retuned)
Future Engine Mods:
Powertune Forged Short Block
T04z 0.86 or PTE 6766 Turbo
Camtech 272 degree cams with titanium retainers and springs
Tomei-Ti Expreme Titanium Exhaust
Twin Bosch 044 in tank fuel pumps
Haltech Platinum Pro with E-Flex sensor
2000 cc Injectors
Possible Head work including porting and polishing etc
Goal is to get 450-470kws @ 30psi on E85 with this setup with a few extra things.
Future Body Styling/Suspension:
TBA
Pics up soon!
https://www.sau.com.au/forums/topic/420020-and-it-begins-2001-r34-gtr-vspec-ii/
Sounds sweet but ull need a bigger exhaust than the tomei system. Will need full 4" exhaust for over 400kw
Have to agree. Tomie Ti is only 3.5inches. For your power output it will be restrictive. Is this a a streeter or mainly racing use?
If predominantly racing use do away with the cat and get more exhaust flow.
BTW nice car.
Sweet, cheers guys. Is there any 4" titanium on the market?
Also missed in the above mods will be getting the following:
Quickspool Custom High Mount Steam Pipe Manifold
50mm External Gate (Brand yet to be decided)
Adjustable Cam Gears
Tomei Baffles and Oil restrictors
N1 Oil Pump
ARP Head Studs
And a few other things as they become needed.
Pads and rotors will also be upgraded when the time comes.
I will be working on stages with this new project starting with cosmetic/suspension and wheels then working my way to the engine build.
Here is a few pics. Plates have now been changed to personalized QLD plates.
BTW nice car.
Cheers Ants, Car will be a Sunday driver/time attack. How restrictive is a highflow cat at that power range?
    • Not noticeably. Arguably, the catless turbo is going to work harder in a different direction, as it will spool up faster, go to higher speeds more easily. Only if it was tuned in the original condition. If it was a stock tune, using the AFM before and after the cat/dump change, then no, no retune needed. If the car is running on a MAP sensor, then it might well benefit from a retune. It might even run a little dangerously without a retune, but it could quite easily be fine.
    • We had this blend that uses 98RON + 10% Ethanol which brought it to 100RON. It's no longer available anymore unfortunately.
    • Does it make a difference in your turbo having a shorter life if you have a cat converter as it causes that back pressure versus less/no back pressure with a decat? (Not sure if this is accurate) Also slightly different question if you went from a oem cat to a decat or vice versa will it require a tune? I heard if you change the dump pipe onwards it requires a tune?
    • No. Have only gotten as far as contemplating the task of having to put in the required fairly heavy wiring and fusing to run it (along with the big alternator), and preferring not to. But otherwise, it would be nice to have a little extra freedom as to exactly where the compressor is located and free up some space around the exhaust side of the engine.
    • Following from this in a related by not closely-related sense... Because I was buying a bunch of other GKTech stuff, I got some rear subframe collars. The history that leads up to this is: 25+ years ago the car arrived into the country with stock subframe bushes. At some point shortly thereafter I added Whiteline pineapple rings, set up neutral, and it improved the rear end behaviour. Well, it is my vague memory that I was happier with it with them in. Less axle tramp on launches, generally better, etc etc. ~2012 it got a new non-HICAS subframe with new stock bushes. No pineapple rings. I reckon that ever since then I've been dissatisfied with the axle tramp. Recently I've been f**king around a lot with all aspects of the suspension. One contemplation has been to relocate the rear lower control arm front mount points (and do the other things needed to make that work) to improve longitudinal rear grip by getting rid of some of the stupid anti-squat that Nissan ladled into the R32. But.... before doing that I thought I'd put some collars in. And.... The collars are good. The rear sounds a little bit different, but there has been no significant increase in NVH coming up into the body. In terms of rear behaviour - expansion joints on long sweeping elevated freeway ramps that would sometimes cause the rear to jiggle around a bit, no longer seem to do so. It appears that jamming chunks of metal into the gaps in the rubber so they can't move much is a really good thing. And the launch behaviour and general forward traction situation seems to be greatly improved too. It's impossible to be really sure, because the tyres are completely shagged - they are freakishly willing to let go right now. But as an A-B test with the same tyres it certainly seems to grip up a lot better. Highly recommended to anyone who still has stock bushes.
