are the grill mounts detachable for the n1 headlamps? or are they moulded to the housing? iv seen some n1 types that have the mounts and some doesnt have it..attachicon.gifimages.jpgattachicon.gifpicture008g.jpg
With mounts = R32 GTR N1 headlights, to secure front grill.
Without mounts = R32 GTS-T headlights.
This is not entirely correct.
No the standard GTS-t's did not have the clips for the grill, although they did have screw holes for an option to fit the brackets (which were metal) for a GTR style grill. You can get these through NISSAN. So any reflector style (N1 style) headlights that have the brackets which are held on by screws and are removable, are NOT genuine N1s.
The genuine N1s have the brackets which are plastic and are molded into the body of the headlight itself. These are NOT removable.
Sorry Damien but that is not accurate.
(OO)SKYLINE(OO) is right.
Genuine N1's do not come with plastic brackets molded into the headlight. Standard R32 projector type headlights do.
If you were to source N1 (Zenki) Headlights from Nissan they come with metal brackets that are bolted each N1 headlight.
GTS'ts have N1 type headlights without brackets and can sometimes fool people that they are genuine N1 headlights.
I have both sets (with N1 recently purchased) be more than happy to post up pics for comparison.
Edited by Ants
Hey Ant,
I spoke to Kudos (SAU trader) about 6 months ago about this same thing as i was after genuine Zenki N1s, and he supplies them direct from NISSAN Japan, and he assured me the brackets were molded plastic (like the GTR projectors) and are part of the body and not removable. This is what distinguishes the difference between the N1 and the GTS items.
I did a fair bit of research into this as i was searching for a set myself, and i found a lot of conflicting information and could not get a straight answer, so i spoke to a specialist who deals in new original Nissan parts.
Ill ask someone on here who i know purchased a set through them so i can get a straight answer and ill let you guys know.
i prefer my projectors ;)
i wonder why they never moulded the braket on?
Well I have both. So change it when I want :yes:
No idea why N1's were not molded on - maybe it was in case they got damaged in racing it was easier to fix up :closedeyes:
hmmmm, bolts=metal, they should be moulded for light weight :D
