mick, [i could be mistaken?] but to run Step 2 Cams, I think there's alot more involved and may require head work for clearances etc etc... I'm not sure exactly what your after & what you plan on doing, however I dd go down this path myself for my internally stock GTR, and I found that generally, everyone seems to go for the Tomei 256's with a 9.1 lift on either side or a 256 & 260~.. Anything bigger and I think you start to loose alot of bottom end. Someone please confirm???
https://www.sau.com.au/forums/topic/42003-gtr-cam-upgrade/#findComment-861496
mickr32gtr,
There are reasonable gains to be had from the higher (9.2mm) lift 260deg Tomei shafts. 15-20rwkw or so up on the stockers.
The camshaft swap including tune should be around $800-$900 with the cams costing about $800 pair (greenline/nengun). The head need not be removed.
https://www.sau.com.au/forums/topic/42003-gtr-cam-upgrade/#findComment-861722
Still reckon best bang-for-buck for similar money would be a pair of used N1 (or equivalent) terbs.
For around $1,500, you'll get a lot more gain for your $$$. Especially given that you already have the PFC fitted.
Fit the cams later when you hunger for more power intensifies (and it will - trust me!)
https://www.sau.com.au/forums/topic/42003-gtr-cam-upgrade/#findComment-861736
I'd love to install N1 turbos but where do you find them?
https://www.sau.com.au/forums/topic/42003-gtr-cam-upgrade/#findComment-864730
just got my set of N1's installed. found them on the forums. they set me back approx $3500+ which includes N1's, installation and tune. made 283rwkw @ 20psi.
max power from a set of N1's are apparently 300rwkw
previous mods were Z32's, cam gears, pfc, trust cat back, bigger in-tank fuel pump @ 1 bar making 210rwkw
i would also recommend going the bigger turbo route if you can afford it. the difference in power is amazing.
https://www.sau.com.au/forums/topic/42003-gtr-cam-upgrade/#findComment-865871
http://www.skylinesaustralia.com/forums/sh...ead.php?t=32571
this thread may be of interest to you
https://www.sau.com.au/forums/topic/42003-gtr-cam-upgrade/#findComment-865975
