Hahaaa
Actually, I'm thinking in reverse.
...that if I get an R32 GTR, would certain LMGTs look good and fill the guards without rolling them - and are the LMGT4s too contemporary?
So my former Q was in fact, a leading Q. ;)
17*9 +22 was the default size for R32 R's before fitment happened. So an 18 in that size if you must. But given a +22 rim with a 255 bag tyre will scrape (depending on rear ride height and camber, obviously) I cant see how you would get a +12 in there without issues.
LMGT4's look underwhelming in 17's, good in 18's. CE28's are much better in both. Both are colour sensitive, however.
I had to roll the rear guards (only) for 9in +20 wearing 255s with RT615s. Fed SSes were ok - remember different 255 tyres will have slightly different treadwidths. To to get the same level of clearance to the guards as that in a 10 you'd have to be running about +32. R34 GTR rims are 9in +30s so tons of room between tyre and guard.
OP - do you mean max offset (as in smaller track, wheels toward the center of the car), or minimum offset (wider track, wheels closer to the outside of the car)?
