Hey all,
I have a good one for all the investigators out there. I’m trying to get my hands on a replacement rubber seal for the below pictured “Hella” side indicators on an R32 GTR. I've attached some images...
I have found several numbers on the lamp however sadly according to Hella they have been manufactured specifically for a car manufacturer and they are unable to tell me which one *facepalm*. These lamps would have been fitted during compliance and I can see a date of 2005. Numbers below;
1. On the side there is a "Hella" paper sticker. Code: D27691 Date: 23NOV05.
2. Pressed into the rear side of the light I can see: 81730YC020
3. Pressed into the clip of the light I can see: B1730 YA020
I have also spoken with Nissan and they are able to replace the whole lamp with the ones that came on the Australian Delivered R32s however the issue I have is two part;
1. The lamp offered by Nissan appear to be a different shape looking at the Australian Delivered examples on the Forum and may not fit into the existing hole in the fender (really don’t want to cut any metal for the sake of replacing a rubber seal)
2. They a pretty pricy and would much rather just get a replacement seal
If anybody knows where I can get my hands on a replacement seal I’m more than happy to buy you a six pack :cheers:
Cheers lads,
Sean
Why don't you just go to Clark rubber and buy a sheet of suitable thickness high density foam or rubber, a steady hand and a craft knife would get you around the mystery?
You're right! They look identical the to the ones I had on my 1993 Lexus ls400. I knew I had seen them before.
From memory they are also on a certain model corolla - cant remember which one.
Edit: false alarm....they're not the same I checked.
Edited by SMOKEYV35
Thanks for the info guys, I'll try Toyota on Monday morning to see if they are able to track those numbers
I've tried all the usual sources like Bursons, SuperCheap, AutoBarn, internet searching etc
I'll let you know how it goes
Cheers,
Sean
Hey all,
So turns out the indicators were off a Toyota Camry 36 series
Toyota side indicator
I've ordered a pair and I'll let you know how the install goes when I pick them up next weekend
Cheers,
Sean
Hey all,
Just to keep you in the loop how the search is going. I went down to Toyota today to pick up the lamp but sadly there were two issues;
1. The colour was incorrect (admittedly the bloke was unable to confirm the colour, worth a shot though)
2. The lamp does have a rubber seal but it's different from the other one already on the car and appears to be the same "thin" rubber seal that broke last time (not really interested in using it)
I brought the parts guy out to the car to show him exactly what type of rubber seal I was after but he was unsure.
After a bit of hunting around in their system I suggested maybe a Toyota Starlet had the correct seal (I saw one at the shops the other day and both the lamp and seal looked very similar to what I was after).
Luckily for the Starlet lamp I'm able to buy the rubber seal separately which is good considering the lamp for the Camry I won't be using and hopefully some bloke will buy it on Ebay :rolleyes:
I'll give you all an update once the Starlet seal comes in,
Cheers,
Sean
Personally I'd have done this^ Likely they would have given you an off cut for nothing.
2nd choice would have been replace with Nismo R34 side winkers.
However it looks like your almost sorted :thumbsup:
    • Just don't use ChatGPT or any other artificial stupidity for the equivalent of googling. Their demonstrated inability to discriminate reality from hallucination should be enough to make them totally untrusted. LLMs don't know anything and cannot think to even the smallest extent. They are just predictors of the next word, and that should never be confused with capability.
    • I think, given the usage model described in the OP, I'd never ever experience the wonders of the 400kW upgrade. What I really need is boost from 2000rpm and probably no more than 260-270rwkW. But I suspect that the highflow is not actually the turbo for that purpose, so I may in fact need to get a G25 or 30 or something right sized and very spooly. We shall see after it is tuned. I've had to back the boost and boost ramp off to stop the thing from pinging since the highflow went on, so I've been almost living the NA life for 9 months now! Injectors are recently in hand. AFM is in hand. Dyno is fixed. Just need to clear a queue of f**king Supras out of the way (and probably fit my new gearbox). So....some time this year? Lol.
    • For what I gather is a Sunday/summer car....braided is fine. You're not going to be left without a vehicle and you have plenty of time for inspection/maintenance. Oof. I wouldn't use them that way. They can probably handle the temperature** but the internal corrugations means that their flow characteristics are a bit shit. Lots of extra friction and pressure loss. Makes them flow like the next pipe size down. ** They are stainless, and the stainless can usually be at least something like 304L, which is pretty good at higher temperatures (unlike 316L, which I would use for a wrt/corrosive environment, but not a particularly hot environment). But the welding needs to be top notch. And even then, because you usually need at least one cone-seat end on them (because you can twist the hose and do up both ends at the same time unless one of them is a union) they can be prone to coming loose with heat cycles.
    • I don't have the OEM oil feed lines though and the turbo-wraparound line is torn, only has water. My plan is to get replacements for these and just connect a braided line to there. And make sure it's leak free. Hoses like these are also sometimes used to connect external wastegates, so for an EGR I think you're good using them.
    • Alright I understand. The most likely case is probably gonna be that I just keep the OEM unit in the car as long as it works.
