I got sick of my oil pressure reading very low when warm (0 to .5 on the factory guage)
so i decided to replace the sensor. You will need an open ended 17 mm spanner and
you will need to undo a hose clamp (mine was a small socket to undo)
this side of the engine bay.
undo the bottom fuel line hose clamp and slide it off (it is the return line so there is no pressure in this line but some fuel will dribble out so be careful)
this is the fuel pressure sensor about 20 cm below the fuel line hopefully you can see it in focus down there with a rubber gromet over the plug on the left hand end of it.
this is what the plug looks like with the grommet pulled back. fairly easy to remove.
you need to get a 17mm open ended spanner on the sensor to undo it.
this is the new sensor i bought off ebay from nissan of chesapeake in usa. it cost me $95 delivered here.
and this is the end result. a good oil pressure reading in the cluster guage. may not be highly accurate but it would certainly be able to warn you of a problem before it does too much damage.
  • Like 2
  • 7 years later...
Afternoon all,
Confirming this guide was fantastic! Oil pressure sensor on my R33 GTR went the other week, ordered a new one off Just Jap.
I used a 17mm stubby spanner from Supercheap Auto ($26 for the set).
I didn't have to remove the fuel line, just pull off the seal boot, unclip it, feel you way around, put the spanner on and undo it. Cleaned up around where it screws in as there was a little oil coming out.
Note, I used some Red Gasket RTV high temp gasket maker to put about 5mm run around the bottom of the screw in bit to then seal it (nissan manual recommends this as well).
Left it an hour, tightened it up and off I went.
Links
    • Hi. A little bit of an update. It maybe(hope not) looks like i would need a new tranny(it would be "maybe" a cheaper or better option anyway) So i need some info. I know i need a different propshaft(i can make custom one) LSD is not a problem cuz the engine will be still(for now) N/A RB20. So if i buy RB25DET NEO tranny...is there something else i need? I read something about push/pull type but i do not know if i need to "change" something or i can just plug n play onto my engine a go? Thanks for the advice
    • Good morning all, Bit of a random question but figured I’d finally throw it out after wondering for a long while. Before I start, I'm hoping to do this purely out of personal preference. I think it would look better at night, and don't mind at all spending a few hours and dollars to get it done. I've copied this from a non-Skyline specific forum, so I apologize for the explanation of our headlight switch setup that we all know. Here we go: Zero lights (switch off) Parking lights (switch position 1) being a rectangular marker on the outside of the housing, my low beam being the projector in the centre (position 2), and a high beam triggered by my turn signal stalk. Most North American cars I’ve owned of this era have power to the amber corner (turning indicator) light as part of the first switch (parking lights). I’d love to have these amber corners receive power when the headlights and parking lights are on (headlight switch), yet still blink when using the turn signal which is of course a separate switch. Hopefully I’ve explained my question correctly. Is anyone aware of a way in which I might be able to achieve this? Thanks in advance
    • My heads are cathedral port! It's likely possible, but I don't want to add any extra moving parts (I know they don't move) between the heads, manifolds, etc. It will also affect how injectors/fuel rails etc sit and I don't really know if it would change how the FAST manifold goes/sits/fits. I have the LS6 steam pipes already as I have a very late LS1 block so it should be fine. I couldn't find anyone who had ever actually used one for this purpose, it seems 100% of people grind the water pump. The thermal spacers are 12mm and are half way to the cost of the newer water pump anyhow... so if it comes to that I suppose I'd rather buy a new pump. The bearing in the pump I do have is a little.. clunky, but it hasn't done that much time and I never noticed it when the car was together in the past few years, so..
    • The bushing has failed, not all that uncommon for a car of this age.  Any mechanic should be able to push in a new bushing for you, or you can probably buy the entire lower control arm, complete with bushes.
    • Could you not use "thermal" spacers to give the clearance, like the ones I used between the blower and head? That raised the manifold height by around 10-15mm Albeit the ones I used were for cathedral ports, but I assume they have similar for rectangular ports????
