i've got the jap copies of all the r32 n r33 service manuals (with pretty detailed instructions from what I can tell) on its way from japan (yes I know "why put a CD on a container?", I posed that question to the agent in japan too).
Once its here I'll have a go at translating it and then sendin whoever wants a copy one.
https://www.sau.com.au/forums/topic/42007-r3233-manuals/#findComment-861318
i bought the CD off EBay because for some reason i couldnt download the one off gtrcentral (damn dial ups!). Its the R32 GTR one so i dont know if its of any help. I have a burner, but alas, i am a retard and dont know how to use it! hehe
https://www.sau.com.au/forums/topic/42007-r3233-manuals/#findComment-861335
Ghost ryder,
yes please, i have been trying to down load at http;sami.kallio.com/skyline/gtr_32_service_manual.pdf. it's there but i am a 43 year old non pdf compliant knob! I can't get the friggen thing to unload (give me a spanner any day!) Frustrated as buggery. I'd love one of the CD's ,How do we go about it? And or how do i get this PDF stuff sorted out ?
Thanks
https://www.sau.com.au/forums/topic/42007-r3233-manuals/#findComment-876170
Ghost ryder,
Thanks
PM me and we can get it all organised from there.
https://www.sau.com.au/forums/topic/42007-r3233-manuals/#findComment-876259
I have down loaded the R33 Service Manual(150Mb) PDF from a UK link in Skylineowners.com thread. It is the business, also have the Workshop manual for the R32 GTR, only 23Mb. Pitty there is not an FTP area on this website. The R33 book is 491 pages in all and cannot be compressed.
Regards
Mark
https://www.sau.com.au/forums/topic/42007-r3233-manuals/#findComment-876922
http://www.gtr.org.uk ..........try this link there is a lot of talk on the www.skylineowners.com site as some of the lads have the R33 Service manual and are downloading it from each other. The above link is fast and active as of today.
Regards
Mark
https://www.sau.com.au/forums/topic/42007-r3233-manuals/#findComment-879189
Well I got off my Ass and had a look at what Manuals I have..
I have the Following.
R32 GTR Service Manual -English- Approx 800 Pages
R33 GTR Service Manual -English- Approx 800 Pages
The Skys the Limit -English- Skylines Downunder Information Book
For the record, you will not find the above service Manuals for a Gts-t, as NONE were ever made in English.
Why? Because only the GTR was released in Europe, Hence the English
https://www.sau.com.au/forums/topic/42007-r3233-manuals/#findComment-879232
does anyone wanna pay me to translate the jap ones? lol... not much I mean like $5 a copy of the disc or whatever once i'm done translating it... just for the first month before everyone start pirating it.
https://www.sau.com.au/forums/topic/42007-r3233-manuals/#findComment-879255
    • https://www.efisolutions.com.au/coolant-temperature-sensor-bosch-180sx-s14-s15-r33?gad_source=1&gclid=CjwKCAjwzMi_BhACEiwAX4YZUHsCQhbiDT_NC3q5wD9jrzH6Dts9eGSr19NXSDw7x9WVm1sH7G3S4hoCwaUQAvD_BwE this is the one i replaced today
    • I have replaced the larger coolant temp sensor, i do see a smaller one next to it (looks to be just 1 pin) but i assume that is just for the dash? or should i replace that aswell?
    • Check coolant temp sensor ~ symptoms fit the hard hot start/cold start OK scenario --- if sensor goes open circuit, ECU thinks engine is cold and enriches mixture ....works when engine cold, but floods them with rich mixture when hot (Hyundi MAP engines are a bit infamous for this)...
    • OK, starter changed for a spare without much trouble. Neil had kindly left space to get to the top starter motor bolt from above with a long spanner which makes the whole deal much easier, and everything else was neat and easy to get at from underneath. Once the starter was changed everything was good, unplugged the CAS and turned the motor on the starter to make sure everything was free and happy. Onto properly priming the oil and first start. I'd picked up one of these oil prime kit from Boost doc a while back and this was my first time using it.  https://boostdoc.com.au/products/engine-oil-prime-kit?_pos=1&_sid=28c628a65&_ss=r While I'd organised all the fittings to hook it up to my GTR (sump plug to -6 feed and -4 T to tap it in and retain the oil pressure gauge, neither suited on this car as the oil pressure needs to T into 1/8 NPT not -4 and the Aeropro sump has some massive drainplug not that factory whatever it is. So, waiting for a couple of fittings, then I'll prime it and do first start, hopefully next weekend. Other than that going well, there is very little stopping a final alignment, tune then shakedown day
    • Also to mention, i just tested the CAS, seems to be working fine, can hear the pulses inbetween 0 and 180 degrees, another mention aswell, when i let the car sit for about a hour today, i went to start it and it almost fired on first crank, then just completely struggled. Could it possibly be blocked injectors?, maybe allowing a little bit of fuel to seep past allowing it it almost start first crank?
