Hey guys,
Was talking to a mate the other day and he told me about performance chips, was wondering if anyone has used performance chips in their V35, i have a 250GT Four and was wondering if a chip would be beneficial or not. If anyone has experience with these chips id love to hear about it.
Thanks
https://www.sau.com.au/forums/topic/420070-performance-chips/
Almost all 'performance chips' are a load of bs ..... the ones you buy on Ebay are almost always just a resisitor that you need to wire/solder into your afm wire to trick the afm into running the car a bit leaner and get slightly better performance. This is of course a load of bull, as 1) our ECUs self-learn anyway and would readjust themselves in a short time, and 2) you don't want the same amount of afr changed at all rev ranges.
In short they are a load of crap, and you get what you pay for.
If by 'performance chip' you mean a piggy back or interceptor computer like an SAFC Neo or Unichip, then some gains can be had by tuning - but you are talking around $500 to buy the units then around $500 to tune.
Your best bet by far (if your model of car supports it) is to buy an Osiris cable and software and have a workshop reflash your stock ECU with a custom tune.
Of course if you are a P plater (which I am guessing you are - there is no reason in the known universe that anyone would buy a 250GT otherwise) then modifying your ecu or tune would be illegal under state laws ayways fyi.
In all of the above scenarios performance benefit is going to be negligible at best, even if you have supporting mods like exhaust, intake, spacer etc etc
Hey Nightcrawler, thanks for your info, very informative, no im not a P plater anymore however i was when i first purchased the car, now i am looking at making it go a little faster, so you say that basically these performace chips are no good, awesome lol
thanks
If it's direct injection, cleaning the intake properly (off the car), blanking the EGR valve and flushing the engine would be a good starting point.
Look to get rid of the intake swirl valves, these block off half the intake ports to promote swirl in the chamber at lower revs. I think good gains can be had here at the expense of a little cruise economy.
many, many moons ago a very wise man said to me that if you want more horsepower in your car, go out and buy a car with that many more horsepower and save your sanity And your bank account.
Years later and lots of bad experiences to draw from, all I can say is - he was right.
But look at all the fun he would have had me miss!!!
I agree with above. all the money you spend on the 250gt will struggle to make it as good as a standard 350gt
I would estimate ive spent $4000 on bolt on upgrades plus trans, and i barely keep up with a 350gt.
For around $5000 you could source a wrecked Stagea and transplant EVERYTHING mechanical and electrical yourself... this is probably the most reliable upgrade to make a 250gt proper fast.
or save your $5k, sell the 250gt, and buy a 350gt.... or an XR6 turbo
Edited by Deep Dish V35
if you want some thing cheap...... safc and sitc. funnily enough i have both for sale.... perfect for autos. :woot:
Hey dude what exactly is a safc and sitc, what do they do? and how muich do you want for them?
i was looking at these valves when i did the plenum clean..... was considering a manually selectable bypass of the actuator valve...
Hey when you did the Plenum spacer upgrade did you notice much performance increase in the 250GT?
was considering this for one of my first mods, mabe then a nice exhaust system will be good aswell
i cant say whether the spacer itself made any difference, as I did a list of other things at the same time.
The combination of plenum spacer, plenum and runner clean, EGR valve blocked off, cooling system mod..... all reduced fuel consumption by 1.5 to 2 litres per 100km, but acceleration doesnt really feel much different. Im used to driving supercharged cars so of course its going to feel slow regardless...
Just piss them off, even when open they limit the flow to the valves. I am interested to see how much difference it makes but I assume you would need a tune afterwards, or at least check the AFR's.
The Stagea turbo VQ25 would be the obvious pick for a transplant, you could get a good engine for around 2k, plus an Emanage Ultimate to tune the mixtures. It should all just work off the stock ecu, as the cams actuation (and most other parts) are the same. I was planning to buy a cheap V35 4 door for the same reason but bought an A4 quattro instead.
until he gets a det, the apexis would be a cheap choice for extra killawasps no?
    • What can't be done with a little bit of decking board or similar timber bolted to a hub flange via 2 wheel nuts is not worth talking about.
    • I noticed something. On the tps sensor and the sensor behind the adjustment screw is adjusted towards the far left. Are these screws supposed to be centered? (this sensor was in the same position before the tune as well)  Also attached a photo of where my car usually idles at when warm (sometimes a tiny bit above that). I think I might have screwed up the calculation and it might have better than I thought lol at 750rpm still not 650rpm though.
    • So for both general interest of engine health, and to rule out any coolant/oil issues, I organised an oil analysis done on the 125,000klm oil Results below, all good, just a bit of fuel dilution which I'm not too worried about
    • This is actually a really good way of measuring what wheels fit. If only there was a similar measurement between hub face and suspension :p That said, it's probably pretty simple to actually measure it all with the wheel off the car for the rear. The front is a bit more complex but..
    • Being the top Google search result for R34 wheel-related inquiries, lemme throw down my experience. I calculated that 100mm from hub face to wheel face is about the perfect fitment for my ENR34 sedan.  I've been running 18x8.5s, ET35, with a 1" spacer. So, 8.5in to mm = 216mm. 216/2 = 108mm. 108-35 = 73mm. 73+ 25 (1" to mm) = 98mm.  If you wanna get close to this on dif widths, here are the offsets you'll want: 9" - ET around 15mm 9.5" - ET around 20mm 10" - you're crazy, but ET around 30mm All these should fit perfectly on a non-widebody, non-GTR Skyline. Note that it's probably the absolute max, and you're probably better off running a couple degrees of camber in this config, but it looks great, super flush.
