Hey guys,
Was talking to a mate the other day and he told me about performance chips, was wondering if anyone has used performance chips in their V35, i have a 250GT Four and was wondering if a chip would be beneficial or not. If anyone has experience with these chips id love to hear about it.
Thanks
https://www.sau.com.au/forums/topic/420070-performance-chips/
Almost all 'performance chips' are a load of bs ..... the ones you buy on Ebay are almost always just a resisitor that you need to wire/solder into your afm wire to trick the afm into running the car a bit leaner and get slightly better performance. This is of course a load of bull, as 1) our ECUs self-learn anyway and would readjust themselves in a short time, and 2) you don't want the same amount of afr changed at all rev ranges.
In short they are a load of crap, and you get what you pay for.
If by 'performance chip' you mean a piggy back or interceptor computer like an SAFC Neo or Unichip, then some gains can be had by tuning - but you are talking around $500 to buy the units then around $500 to tune.
Your best bet by far (if your model of car supports it) is to buy an Osiris cable and software and have a workshop reflash your stock ECU with a custom tune.
Of course if you are a P plater (which I am guessing you are - there is no reason in the known universe that anyone would buy a 250GT otherwise) then modifying your ecu or tune would be illegal under state laws ayways fyi.
In all of the above scenarios performance benefit is going to be negligible at best, even if you have supporting mods like exhaust, intake, spacer etc etc
Hey Nightcrawler, thanks for your info, very informative, no im not a P plater anymore however i was when i first purchased the car, now i am looking at making it go a little faster, so you say that basically these performace chips are no good, awesome lol
thanks
If it's direct injection, cleaning the intake properly (off the car), blanking the EGR valve and flushing the engine would be a good starting point.
Look to get rid of the intake swirl valves, these block off half the intake ports to promote swirl in the chamber at lower revs. I think good gains can be had here at the expense of a little cruise economy.
many, many moons ago a very wise man said to me that if you want more horsepower in your car, go out and buy a car with that many more horsepower and save your sanity And your bank account.
Years later and lots of bad experiences to draw from, all I can say is - he was right.
But look at all the fun he would have had me miss!!!
I agree with above. all the money you spend on the 250gt will struggle to make it as good as a standard 350gt
I would estimate ive spent $4000 on bolt on upgrades plus trans, and i barely keep up with a 350gt.
For around $5000 you could source a wrecked Stagea and transplant EVERYTHING mechanical and electrical yourself... this is probably the most reliable upgrade to make a 250gt proper fast.
or save your $5k, sell the 250gt, and buy a 350gt.... or an XR6 turbo
Edited by Deep Dish V35
if you want some thing cheap...... safc and sitc. funnily enough i have both for sale.... perfect for autos. :woot:
Hey dude what exactly is a safc and sitc, what do they do? and how muich do you want for them?
i was looking at these valves when i did the plenum clean..... was considering a manually selectable bypass of the actuator valve...
Hey when you did the Plenum spacer upgrade did you notice much performance increase in the 250GT?
was considering this for one of my first mods, mabe then a nice exhaust system will be good aswell
i cant say whether the spacer itself made any difference, as I did a list of other things at the same time.
The combination of plenum spacer, plenum and runner clean, EGR valve blocked off, cooling system mod..... all reduced fuel consumption by 1.5 to 2 litres per 100km, but acceleration doesnt really feel much different. Im used to driving supercharged cars so of course its going to feel slow regardless...
Just piss them off, even when open they limit the flow to the valves. I am interested to see how much difference it makes but I assume you would need a tune afterwards, or at least check the AFR's.
The Stagea turbo VQ25 would be the obvious pick for a transplant, you could get a good engine for around 2k, plus an Emanage Ultimate to tune the mixtures. It should all just work off the stock ecu, as the cams actuation (and most other parts) are the same. I was planning to buy a cheap V35 4 door for the same reason but bought an A4 quattro instead.
until he gets a det, the apexis would be a cheap choice for extra killawasps no?
    • Hi guys, has anyone either purchased or built themselves a rotisserie for their car before? I can only just justify the need for one hence why I should just make one but at the same time, if I make one I can kiss another 4 weeks of potentially productive car working time goodbye because I'm building a bloody rotisserie....  I mainly want it for the application of the body deadener.  Cleaning the old stuff off, priming and then colour over the deadener doesn't worry me, it's just the application using the Schutz Gun that I feel would achieve a significantly better finish painting it side on and keeping the Schutz Gun upright.  I don't think they would work well on the side let alone almost upside down for some areas.  If the product I use (Terosun, etc) could work through a HVLP ok then it might be ok to apply without the rotisserie.   I can get one of these style ones for about $1200 which is pretty good value-     I reckon if I made one it would cost around $500 but it's more the time that it would take is more of a killer than the cost.  They look to hold their value pretty well second hand so I could always sell it after using it and realistically only lose $200-$300 at worst.  Or keep it and buy another project when this one finally sees the light of day... Anyone selling one...? Cheers!
    • While it is a very nice idea to put card style AFMs into the charge pipe (post intercooler, obviously), the position of the AFM and the recirc valve relative to each other starts to become something that you really have to consider. The situation: The stock AFM is located upstream the turbo, and the recirc valve return is located between the AFM and the turbo inlet, aimed at the turbo inlet, so that it flows away from and not through the AFM. Thus, once metered air is not metered again, neither flowing forwards, or backwards, when vented out of the charge pipe. When you put the AFM between the turbo outlet and the TB, there is a volume of pressurised charge pipe upstream of the AFM and there is a volume of pressurised pipe downstream of the AFM. When the recirc valve opens and vents the charge pipe, air is going to flow from both ends of the charge pipe towards the recirc valve. If the recirc valve is in the stock location, then the section between it and the TB doesn't really matter here - you're not going to try to put the AFM in that piece of pipe. But the AFM will likely be somewhere between the intercooler and the recirc valve, So the entire charge pipe volume from that position (upstream of the AFM, back through the intercooler, to the turbo outlet) is going to flow through the AFM, get registered as combustion air, cause the ECU to fuel for it, but get dumped out of the recirc valve and you will end up with a typical BOV related rich spike. So ideally you want to put the AFM as close to the TB as possible (so, just upstream of the crossover pipe, assuming that the stock crossover is still in use, or, just before the TB if an FFP is being used) and locate the recirc valve at the turbo outlet. Recirc valve at the turbo outlet is the new normal for things like EFRs anyway. In the even of a recirc valve opening dumping all the air in the charge pipe, pretty much all of it is going to go backwards, from the TB to the recirc valve near the turbo outlet. But only a small portion of it (that between the TB and the AFM) will pass through the AFM, and it will pass through going backwards. The card style AFMs are somewhat more immune to reading flow that passes through them in reverse than older AFMs are, so you should absolutely minimise the rich pulse behaviour associated with the unavoidable outcome of having both a recirc valve and an AFM in the charge pipe.
    • Yep, in my case as soon as I started hearing weird noises I backed off the tension until it sounded normal again. Delicate balance between enough tension to avoid that cold start slip and too much damaging things.
    • I'm almost at a point where I feel like changing the alternator. Need to check the stuff you mentioned first though.
