if you dont use a canton 1 way valve you'll be just fine.
How did you guys conclude the canton valve is a big restriction - did you measure pressure either side?
I run a canton check valve in my sandwich block (T'd in). I don't know what the 1 way is rated at for oil flow but now I'm curious. I run a tomei oil pump and see 3-9bar from cold/hot when driving/idling. According to other users this is normal but I also crank walked a 1200km old engine. So I wonder if this check valve has something to do with the higher pressure (alog with the tuner riding the clutch on start up, not starting with the clutch out)...
Clutch is a twin Carbonetic. Clutch parts were correct and the Only thing found missing was the brass pilot bushing. I did not do the build. I also had not started using the the accusump yet but the check valve was obviously in use.
Anyone have proof or numbers for actual flow of the canton? Compared to an earls even?
you do know that as flow goes dow pressure goes up. so that could explain your high pressure readings.
i dont have flow charts of the valve but you can visually see that its smaller internally then say a moroso one or anything else on the market. doing a quick google for canton check valve restrictions returns plenty of complaints from users. who interestingly enough ditch the check valve all together. i might end up doing this with mine. at the end of the day the oil pump itself is a check valve. oil cannot flow back through the pump
Ok yeah I'll buy that but the thing is, the oil pump isn't at the T (where the Check valve should be), it's through the filter, cooler, back and so on... Maybe 1L? So in order for the oil to 100% go into the engine, I'd have to lose a L, so to speak.
well not really.. your not going to have an air gap through the whole system. oil isnt compressible so it cant flow back or move back the length of your system due to the fact that again the oil pump cannot allow oil to flow backwards into the engine while running.
I've set up with the canton valve, had a quick look and the moroso item appears identical. I'll grab an earls flapper and compare pressure between the two when the thing gets run in.
  • 4 years later...
On 9/12/2013 at 10:55 PM, ZT-R said:
Would this be correct? Would it still draw oil if the thermostat was closed?
Hello all, can anyone confirm that the configuration pictured above works? I too have this sandwhich plate on my RB26, the 2 angled fittings go to the oil cooler, and I currently have the other 2 as oil temp and pressure. If possible, I’d remove one of the sensors and plumb in the accusump. Thanks
  • 2 months later...
    • Back in January, I noticed my car felt noticeably weak. I had the injectors cleaned, which seemed to solve the problem -- until now. Recently, the car suddenly lost power again while driving. Suspecting the injectors, I brought it to the mechanic. He recommended replacing them entirely, saying the current ones were getting unreliable and fiddly to work with. I could not find a direct replacement for my current injectors. The closest match I found were 440cc injectors. This led me to look into the possibility of upgrading -- and of course, that would mean remapping the ECU. From my research I found: The OEM Part numbers are 16600-72L20 and 16600-72L21 Both the RB20DE and RB20DET use the same 270cc injectors. There are much better options out there over the old OEM injectors. Nistune could be a viable tuning option. While the RB20DE isn’t explicitly listed on their site, the ECU is essentially the same as the GTS-T version - just with a different map. The ECU code on mine is listed as supported. One concern is finding a tuner who works with Nistune. Aftermarket ECU like Haltech and Link, but this would be the most expensive choice (and possibly overkill for a mostly stock RB20DE) I admit that I am very new to the tuning scene and would appreciate any insight or recommendations regarding this.   These are some SAU links where I got some of my information from for reference: https://www.sau.com.au/forums/topic/380324-rb20de-injectors/ https://www.sau.com.au/forums/topic/477396-factory-270cc-injectors/
    • The inspectors are not forensic by any means but if you forge your documents and/or badgings on vehicle parts and are found out, the consequences are just far bigger than if you just run illegal parts. And their job quite literally is to cross reference what parts you got installed and what your papers say you got. Something as silly as your suspension being 1mm too low will fail you. Nonetheless I asked if someone knew the damn pipe and I certainly did not ask for smartassery or underhanded comments, no idea why you need to be told this. Great way to waste both our time.
    • As useful as you explaining what forgery is... But then again, I wasn't aware your inspectors were also forensic experts and inspect nameplates on each component to confirm everything is original. They must inspect roughly 3 cars a year at that rate. You're right though, my comment doesn't help you in anyway, so I'll go talk to my wall now. Cheers.
    • Say that to the guy that is going to fail your inspection or tow your car for illegal exhaust modifications. If you have anything else useful to say, please go tell your wall.
    • You must be fun at parties.
