  • Replies 245
Low cars should be fine, just look at how long and easy the tracks up to the dyno are:
901C85B7-39AD-41C0-996C-13C738F181AB-172
Having said that, the owners are car enthusiasts and if a car is too low I'm sure they will accommodate for that too
Well done with the thread Aaron! It will be a great day :D
nick should lower his car more then.... :devil:
why arent you entering?!
naice, ok well I'll probably go for lowest kw then..... Try get a laugh too with my soot chucker tdi
Will pay tomorrow when I'm doing my banking
Awesome!! see you there
i will come along...i will enter if i find 60$ laying around anywhere... :) we can enter on the day yeah?
It's about about 40mm lowest, but can't go any more
driveshaft hits the chassis :P
niiiiice...i got about 60mm but thats just a stupidly low exhaust...i need a new one...
haha yeah my exhaust tucks up well, it's my crossmember that's low
yep on the day is fine, but will need to cancel without enough pre entries :(..
oh really...how many more you need...
are we talking about the Gulf...
*actually yes i think i saw pictures of it somewhere...post your ride thread yeah?
    • They see me rollin' they hatin'....... Took me most of the day to make the necessary mods to the mounts to make them fit the car.  Fortunately I was able to just use the mounts that came with the rotisserie. The rear ones are really secure, the front I feel i might reinforce a bit more as it doesn't seem like enough attachment to the vehicle. I'm sure it's fine but better to be safe than (extremely...) sorry.  I drilled and tapped thread into additional M12 holes to each car mount where it attaches to the rotisserie as an extra fail-safe. Without them the side to side movement is just restricted by the allen head pinch bolts, nothing actually goes though the beam. Does now! I still need to adjust the rotisserie to get the car centred in terms of centre of gravity. If it's too high or too low relative to the rotational centre line of the car, it will be like a turtle and roll onto its back or as it currently sits, I dont think I'd be able to rotate it as it sits as it needs to lift the whole car up as it rotates. Ain't happening... I'm going to be nervous as hell the first time I go to spin it on its side...
    • Oh yes done this when the window started flopping around.  Turns out the guides that run along the rail chanel had crumbed way. Took off the door card and pulled out the window mech, then the window, which you have to pull out through the top. As said unbolt the guide rail and don't spend 30 minutes getting frustrated trying to find a way to slide it out upwards cause that don't frigging work. Drop it down and out through the door hole. All I did to repair it was slice some 10mm clear plastic tube, vertically, then screw it to the guide rail both sides. This tubing rolls inward on both sides and leaves a gap wide enough to hold the window. To finish all I did was lube the plastic tube with olive oil and Bob's your uncle . . . well if he has the operation he can be your Aunt ! !  10 bucks in plastic tube and another 5 minute job done again . . . . YEH BULLSH#T ! My love for Skylines knows no bounds !
    • So was there a solution to this problem? I’m having this issue now.
    • not expensive, just irreplaceable if you don't go sub 60 at wakie in that thing people will start talking
    • I haven't replaced that, but I have had the doors apart on the r32 a couple of times The door skin will be held on by a combination of clips and bolts, just take it slowly and make sure all the sneaky hidden bolts are out Once the skin is off you should be able to pop that piece off pretty easily, looks like there are only 2 bolts holding it on
