  • Replies 245
Hey guys I'm keen also. Heard about this from Oscar. Is it safe to assume that there is a spot for me. Don't have a GTR anymore however I'll be bringing my stock EVO 8 for a power run before starting on the mods.
I'll wait for the confirmation before making the deposit.
Cheers
Las
Hey Las, anybody and everybody is welcome to go on the dyno. Bring the evo, bring the Z, bring your lawn mower!
Special announcement coming later tonight for the dyno day! :D
So it's full? I was hoping to use this opportunity to Sign up (will assist in getting CAMS?) and Dyno the Car - which would be great!
Pretty sure 30 is the max and they've got 16-20 cars or so right now, so you could still run your car; unless my comprehension fails me :P.
Edited by kaitoukid
Guest
    • Sadly I can confirm if you are actually seeking to drift, you will quite easily spin up one wheel. Even if you're going in a straight line. I am not entirely sure of the metrics/terminology here but there's only a certain amount that the helical will actually spin both wheels. I've seen it on video with my own car where two lines of smoke switch over to just one after you really get in to it. Unlike with a clutch diff where you can keep your foot planted until the car regains grip, in my experience with the helical you want to be utilizing traction control allowing LIMITED slip or lifting (partially) when you start to spin up both tyres with a Nissan helical. Which makes them pretty sub optimal for drifting duty. That said... this is probably a helical on numbers alone. Just put the Kazz in
    • Let's just fix the problem by f**king the rest of the gearbox.
    • Unlikely, as per Greg's post. This is not helical diff behaviour unless one wheel is up off the ground. Shimming what? You don't "shim" a mechanical LSD. Probably not in the sense that you have heard of people "shimming" a diff. And the process that Nissan f**kwits call "shimming" a diff involves super-preloading a VLSD cartridge against the side of the diff to create a friction/wear point (in a place that it wasn't supposed to have one) to make the sloppy, useless, viscous diff into a hybrid viscous/mech abortion. In case it isn't clear, I consider the process to be stupid. Nike.
    • How much does the shifter move when the car is in gear with the engine off? If it is more than about 1cm you need to replace your shifter bush. Your shifts will just get crunchier, not faster, with a short shifter unless you also rebuild the whole box
    • I should video mine, will prob do it tomorrow    Between 1st and 3rd, you could fit another two gears. That is how loose and wobbly it is   horrible:(
