ive searched and read through afew different threads but couldnt find the info im after.
on my old r32 i put an rb25 turbo on my rb20 and just drilled and put a tap on the front housing.
now im going to put my spare rb25 turbo i got laying around on my rb20 in my current r32.
just wondering how else others have ran there boost lines with out having to use the r33 boost solenoid or boost controller on their rb20's.
thanks
https://www.sau.com.au/forums/topic/420156-rb25-turbo-on-rb20/
haha left that part out , how else have they been installed with out drilling the front housing and adding a tap like i did the first time i did it.
is there a way to install them with out having to do it like i previously did , and can it be done with out using the r33 boost solenoid or a boost controller.
You either need to to drill and tap the housing or weld on a tapping point on the hot side intercooler pipe (preferably at the turbo outlet end of the pipe). Not really any other option than to source a boost reference from there. Don't listen to anyone who tells you to get it off the plenum.
Yes it can be done without any boost controller at all - just run a hose direct from boost reference location to actuator**. You will get whatever the R33 actuator is set to give (5 or 7 psi). If you want more, then you either need some sort of boost controller or you need an R32 actuator (which will give you ~10 psi). The R33 solenoid will do you no good on an R32 as the ECU doesn't know what to do with it.
**this is exactly how my Neo25 is set up at the moment in R32 until I get it inspected and can put the boost controller back on.
Edited by GTSBoy
    • I recently got their dbw 74mm throttle body and pedal kit. It is sensational quality especially the wiring harnesses. Unfortunately I can’t answer u about the fitment to stock inlet manifold as I’m going Rahjab Racing forward plenum. Only one thing to be careful of is understand u have to pay gst and import fees if your purchase is over $1,000 in one shipment.
    • yeah i agree paint match stops it from standing out so much, oh that's actually really good to know i was wondering if it would help with air flow now actually having an outlet in the bonnet. Will have to focus on ducting into and out of the radiator now to make the most of it.
    • I would paint match the whole thing to avoid unwanted attention  I had a similar bonnet, paint matched, on my old R33 GTST, but mine was a fibreglass jobbie made by Blitz in QLD, they work extremely well for radiator efficiency and under bonnet temps
    • Does anyone run this kit with factory plenum? Does the adapter and bosch tb fit under factory strut brace? I wanted to get this setup before going forward facing manifold. Thanks
    • small update time, after always wanting a "cool" looking bonnet for my car and always struggling to find one for the series 2 that i liked and wasn't an insane amount of money. Saw one i liked on RHDjapan from D-speed in Japan the price was very good for a carbon bonnet so good infact i was a little unsure how much i trusted it, decided to bite the bullet and with the help of jesse streeter in not long at all it was at my door. Once it was delivered i ran in from work and quickly unboxed it and to my surprise the quality was actually pretty good i quickly removed the old bonnet and placed on the new one to test it out and even the fitment wasnt too bad at all. Then decided to paint the little grille in the bonnet black to stop it sticking out so much.   I decided to not mess around with the hood latch and just install some aero catch hood pins, having never installed them before did some YouTube university classes and i was good to go. fair to say it is not a fun job at all from making brackets so the pins sit nicely and actually cutting through the bonnet but also being very scared of cutting the holes too big it took wayyyy longer than i would like to admit but finally got it there. Then it was time for a quick test drive to ensure the latches actually worked and thankfully the bonnet looked very stable. I still think paint matching the bonnet and leaving just the part that sticks up as carbon would help make it all look alot neater as im not sure how i feel about all that carbon on a very fridge white car but will leave it as is and see how i feel with time.
