I'm not a diet expert.
There are many that are that you can find on the net.
But if you want my opinion in it's simplest form.
animals and vegetables = 90%
wheat/grain related stuff = 10%
beef, lamb, chicken, fish, pork (if you are an infidel), turk3y, roo, emu etc etc
vegetables of all colours.. the more colours the better.
the way you described the pizza and wrap make them sound much better than how I pictured them initally.
If you are happy with your diet, then fine.
But if you are hitting a platue, it will most likely be diet or rest related.
  • Replies 119
I would say my diet may be a touch carb heavy some times but is otherwise not bad, I think sleep is a big part, but honestly how can you make yourself sleep better.
I've started going to bed earlier but my real issue is waking up repeatedly be it from temp or being uncomfortable.
Just reading about that, cheers for the suggestion.
Anyone here have experience with it? Supp for more naturally occurring?
A quick read shows foods only contain low amounts.
Its unfair to call it a diet, its just crap he shoves in his mouth
Tolga is a young Markos lol
He too will one day learn the term "wasting your time"
But for now, he needs to experience this
Amusing thread
I was waiting for you to pop in, I just thought you'd have more to add lol
I'll admit I do not follow a strict eating regime, I just try and be mindful of fats and sugars, don't eat too much or too little. As I said earlier, I'm not out to set the weight lifting world on fire. I'm not sure I need to be too hardcore to get what I'm after, but perhaps my goals are much further down the ladder than others.
I'd of thought the preference would be that someone puts it all out there, takes the advice on board and looks to do it better, rather than having another person doing it wrong, or worse, telling others that what they do is right/better when it's not.
Give me some credit :D
Edited by ActionDan
ok serious response.
you have hit a platue where you can bench 87kg for 3 sets of 8, but when you do 88kg, you get 2 sets of 8 and 2 set of 7 right?
this is your platue?
do 88kg for 2 sets.
then wait 3 minutes and do the last set.
problem solved.
your platue isn't really a platue of strength, it's more about recovery in between sets.
just rest more man.... you're at home anyway, not like someones going to come up and ask if you've finished curling in the squat rack.
other choices.
reduce the weight to 80kg and do 10-12 reps
increase the weight to 90 and do 5 reps
increase it to 100 and do 1 or 2 reps.
then after a few weeks go back to 88kg and do 3 x 8 with your designated rest times (which you seem to find important)
The designated rest times are only "important" because I like to not be in the gym foreve. 60-70mins is already enough, I'd be happier with 50-60 which I'd say is do-able with that different routine as there's less time wasted moving plates.
I can work around the bench "plateau" so to speak, but it'll all go out the window next week when I give this different routine a whirl, even if it turns out not to be for me, still better than lifting zero.
Curling in the squat rack, god damn lol that comes up in every pet peeves at the gym thread ever.
Seems there's more issues with the routine that just my recovery times, so I'll mix it up and try some new things, I'm old enough now that if I go a bit backwards in numbers for a bit that's fine with me.
I train at home too mate.
Here is what I have.
1 x shitty "ol Rusty" power cage.
1 x budget olympic barbell
1 x shitty adjustble bench (this is really shitty and will be replaced with a simple flat bench soon)
Lots x weight plates of varying sizes.
all sits outside under the patio.
All get used and abused nightly.
If there is an exercise that I can do on there, it's not worth doing.
No dumbbells, no cables, no bros.
That routine that Brids pasted is one that Markos put together as a "beginners program" some years back.
nothing magical about it. MATE where is this?? hehe.
What approach are people taking to deloading in terms of frequency.
I always get sucked into thinking one more session then I'll take a break but it never happens.
    • Throwing my spoon to the soup here a bit.  When I installed a 044 back in 2012, along with the direct power mod, the car became very difficult to start. To a point I burned one starter motor as I was late for work and tried to get the thing going. With some tuning and careful use of gas pedal when cranking it became bearable. Trying to make this short as possible, but the 044 died after 2-3 years, after which I went with an AEM 320lph pump, which also died after about 4 years to my dismay. After that I went with a Nismo pump, and while trying diagnose an emissions problem, I noticed for the first time that my fuel pressure was 5bar/72psi on idle, and that removing the vacuum line did nothing. After monitoring the situation, and removing the direct power feed and going back to FPCM in attempts to remedy it, I noticed there was fuel in the pressure regulator vac line. Kept the FPCM, installed AEM external regu and the car became sooo much better in every way, including starting. And I had driven it like it was for 11 years.. Anyway, I agree these are likely two different problems, and the FP problem you just haven't noticed before. I do not know much about haltecs, but what first came to mind was the CAS, which probably is not there any more. So how is the wiring from haltec to gauge cluster? How is the battery voltage and alternator?
    • Your car was auto before? You have different diff ratio (auto vs manual i think? or n/a and turbo?)
    • +1 for getting a screen off alibaba, CarPlay/Android Auto is vastly better than whatever navigation cars had 10 years ago. I got an Android screen for my 2015 BMW, huge difference. Fully compatible with factory stuff including iDrive controls.
    • Yeah, my offer was more to show exactly how rough and ready the rig can be and still be useful. Youtube vids will definitely show cleaner setups. Same concept though.
    • I would guess the seal has gone down at the speedo drive and gearbox oil has crept up the drive cable sheath and fouled the speedo head.
