  • Replies 119
Well based on that I'm in the 12-15 range then so maybe the scales are OK.
The 10-12 is leaner than me, but I'm leaner than the 15 guy.
Edited by ActionDan
OK after having a proper go at that routine, it took 53mins, including keeping in my previous ab work and the dips because I like those at the end.
The order taken was.
stretch
crunches
squats (as mentioned these are quite hard on my ankle at the moment so only 25kg and only parallel, I also have to have my feet at roughly 45 degrees, further in i go the worse my ankle protests)
bench
SLDL
overhead press
ab work
bb curls
bb rows
bench style dips
Taking 2min breaks, I can see I'll be able to add weight to pretty much everything, but will hold off for now while some back/shoulder/arm twinges go away (from working on the car flat out lately).
I don't get the same pump after a workout as I did, especially in the bicep area, hopefully that will change a bit when i up the weight on a few things as im doing everything fairly light on.
Pump isn't a reflection of a good workout though. It's just a mental thing.
Do weighted chins and see if you get bicep pump.
Also, how are these twinges going away? Just because the pain eases doesn't mean the knotted muscle or impinged nerve does. Get a decent treatment.
Have you thought about doing conventional dead lifts? Or are they another day? Just thinking they will work your ankle a bit driving through the feet
It will change as you up the weights. The other day I set PBs in deadlifts and I struggled bad on barbell curls. Gotta remember that a "pump" does not mean you've worked harder or lifted more.
Recommend sticking crunches and barbell curls at the end too. You did curls before rows, which recruit biceps. Always do the compounds first and finish with isolation...start from the core and work out to the limbs.
Yeah fair point re pump. I'm looking around for a cage with a chin up bar and dip station.
I rub and stretch out twinges myself usually. If an exercise movement is not aggravating it then I've usually done it working on the car etc so it goes away in time when I get a chance to rest.
I'm doing SLs because they were what was listed in starting strength, probably easier on the back too?
The ankle gets plenty of work via squats and 3k walk with some light jogging thrown in each day, the surgeon said it takes a good 12mths to come back from what I didi, it's only been 4.
Yeah I can move curls to last easy enough,I thought I was showing some real dedication putting them fairly towards the end and doing squats first lol I've also tried to break it up with push/pull alternating to an extent.
Why move crunches? They help me warm up.
just do all your CAARMING at home instead of at the gym.
Home = gym but what is Caarming?
Have you ever known someone to pull their abs during a workout? You use them every minute of the day, you don't need to warm them up. You do, however, need them for compound exercises...so there's no point wearing them out in isolation...just like biceps. The common theme here is that if you are lifting heavy enough on the compounds, you'll barely be able to do the isolation because the muscle group has already been used.
Good work on alternatIng push and pull...definitely works well for me breaking things up like that. But yeah, compound first, isolation last.
As for the pump, as jangles said it's all mental...as are a lot of your habits like crunches to warm up. Forget that dude who said it, but fitness industry is a breeding ground for OCD behaviour. We get good results and misattribute everything we do towards them, including the pointless shit. Less is sometimes more, it's about working out smarter rather than harder. More important is that you have lifted more weight rather than how faxed you feel or tight your biceps are.
I've never pulled an ab but I've always done ab work. I'm not warming up the abs, just warming up myself.
I never used to put the crunches first, I only started doing it with this routine to switch things up and it helps me get blood flowing and a light sweat going, I can move it anywhere as I couldn't care less when/where I do it, I just don't like to start out with a heavy motion straight off the bat.
you don't know what CAARMING is?
youtube - Arnie the pump
Also - SLDL is not in starting strength. the program listed on the earlier pages is not from starting strength.
edit - seems all your injuries/twinges etc come from that anchor you call a motor.
Fit a VH45 and win at life.
Edited by TTT
Bad luck. Start out with a compound movement. That's what warm up sets are for. Your crunches are doing nothing but costing you good lifts, so stick them at the end. I stretch my arms and then it's straight into an 85kg bench for 10 reps. What makes me better than you, captain crunch?
Warm up sets arguably cost good lifts too...
I'm surprised, I thought you guys would be into warming up, good way to avoid injury which is why i do it now, that and being 30 means I'm not as injury resistant as I used to be.
Edited by ActionDan
Haven't trained abs in years cause I know squatting uses your core like a motherf**ker. Good thing is most compound movements will work your core since that area is for stability.
The program listed is something Markos put together for beginners to lifting.
Starting Strength has even less volume and therefore less pump so you'd go crazy.
Edit - doing crunches is not a warm up for any exercise.
how would doing multiple bending of the middle be a warm up for anything you will use during any of the exercises listed in the program?
Edited by TTT
We do warm up, with warm up sets.
Can you explain how crunches are going to stop a shoulder injury from bench or a leg injury in deads and squats? If anything they are more likely to cause injury, because you are weakening your core before doing big lifts. You need to have a tight core during squats and deads else you can end up with injury when you're going heavy. Warm up by doing the exercise lightly...you're not going to hurt anything by doing this.
It's like I said in my previous post, there's a whole heap of stuff you're misattributing to success...need to break the mental barriers.
    • Back in January, I noticed my car felt noticeably weak. I had the injectors cleaned, which seemed to solve the problem -- until now. Recently, the car suddenly lost power again while driving. Suspecting the injectors, I brought it to the mechanic. He recommended replacing them entirely, saying the current ones were getting unreliable and fiddly to work with. I could not find a direct replacement for my current injectors. The closest match I found were 440cc injectors. This led me to look into the possibility of upgrading -- and of course, that would mean remapping the ECU. From my research I found: The OEM Part numbers are 16600-72L20 and 16600-72L21 Both the RB20DE and RB20DET use the same 270cc injectors. There are much better options out there over the old OEM injectors. Nistune could be a viable tuning option. While the RB20DE isn’t explicitly listed on their site, the ECU is essentially the same as the GTS-T version - just with a different map. The ECU code on mine is listed as supported. One concern is finding a tuner who works with Nistune. Aftermarket ECU like Haltech and Link, but this would be the most expensive choice (and possibly overkill for a mostly stock RB20DE) I admit that I am very new to the tuning scene and would appreciate any insight or recommendations regarding this.   These are some SAU links where I got some of my information from for reference: https://www.sau.com.au/forums/topic/380324-rb20de-injectors/ https://www.sau.com.au/forums/topic/477396-factory-270cc-injectors/
    • The inspectors are not forensic by any means but if you forge your documents and/or badgings on vehicle parts and are found out, the consequences are just far bigger than if you just run illegal parts. And their job quite literally is to cross reference what parts you got installed and what your papers say you got. Something as silly as your suspension being 1mm too low will fail you. Nonetheless I asked if someone knew the damn pipe and I certainly did not ask for smartassery or underhanded comments, no idea why you need to be told this. Great way to waste both our time.
    • As useful as you explaining what forgery is... But then again, I wasn't aware your inspectors were also forensic experts and inspect nameplates on each component to confirm everything is original. They must inspect roughly 3 cars a year at that rate. You're right though, my comment doesn't help you in anyway, so I'll go talk to my wall now. Cheers.
    • Say that to the guy that is going to fail your inspection or tow your car for illegal exhaust modifications. If you have anything else useful to say, please go tell your wall.
    • You must be fun at parties.
