  • Replies 119
Well based on that I'm in the 12-15 range then so maybe the scales are OK.
The 10-12 is leaner than me, but I'm leaner than the 15 guy.
Edited by ActionDan
OK after having a proper go at that routine, it took 53mins, including keeping in my previous ab work and the dips because I like those at the end.
The order taken was.
stretch
crunches
squats (as mentioned these are quite hard on my ankle at the moment so only 25kg and only parallel, I also have to have my feet at roughly 45 degrees, further in i go the worse my ankle protests)
bench
SLDL
overhead press
ab work
bb curls
bb rows
bench style dips
Taking 2min breaks, I can see I'll be able to add weight to pretty much everything, but will hold off for now while some back/shoulder/arm twinges go away (from working on the car flat out lately).
I don't get the same pump after a workout as I did, especially in the bicep area, hopefully that will change a bit when i up the weight on a few things as im doing everything fairly light on.
Pump isn't a reflection of a good workout though. It's just a mental thing.
Do weighted chins and see if you get bicep pump.
Also, how are these twinges going away? Just because the pain eases doesn't mean the knotted muscle or impinged nerve does. Get a decent treatment.
Have you thought about doing conventional dead lifts? Or are they another day? Just thinking they will work your ankle a bit driving through the feet
It will change as you up the weights. The other day I set PBs in deadlifts and I struggled bad on barbell curls. Gotta remember that a "pump" does not mean you've worked harder or lifted more.
Recommend sticking crunches and barbell curls at the end too. You did curls before rows, which recruit biceps. Always do the compounds first and finish with isolation...start from the core and work out to the limbs.
Yeah fair point re pump. I'm looking around for a cage with a chin up bar and dip station.
I rub and stretch out twinges myself usually. If an exercise movement is not aggravating it then I've usually done it working on the car etc so it goes away in time when I get a chance to rest.
I'm doing SLs because they were what was listed in starting strength, probably easier on the back too?
The ankle gets plenty of work via squats and 3k walk with some light jogging thrown in each day, the surgeon said it takes a good 12mths to come back from what I didi, it's only been 4.
Yeah I can move curls to last easy enough,I thought I was showing some real dedication putting them fairly towards the end and doing squats first lol I've also tried to break it up with push/pull alternating to an extent.
Why move crunches? They help me warm up.
  On 27/02/2013 at 10:49 PM, TTT said:
just do all your CAARMING at home instead of at the gym.
Home = gym but what is Caarming?
Have you ever known someone to pull their abs during a workout? You use them every minute of the day, you don't need to warm them up. You do, however, need them for compound exercises...so there's no point wearing them out in isolation...just like biceps. The common theme here is that if you are lifting heavy enough on the compounds, you'll barely be able to do the isolation because the muscle group has already been used.
Good work on alternatIng push and pull...definitely works well for me breaking things up like that. But yeah, compound first, isolation last.
As for the pump, as jangles said it's all mental...as are a lot of your habits like crunches to warm up. Forget that dude who said it, but fitness industry is a breeding ground for OCD behaviour. We get good results and misattribute everything we do towards them, including the pointless shit. Less is sometimes more, it's about working out smarter rather than harder. More important is that you have lifted more weight rather than how faxed you feel or tight your biceps are.
I've never pulled an ab but I've always done ab work. I'm not warming up the abs, just warming up myself.
I never used to put the crunches first, I only started doing it with this routine to switch things up and it helps me get blood flowing and a light sweat going, I can move it anywhere as I couldn't care less when/where I do it, I just don't like to start out with a heavy motion straight off the bat.
you don't know what CAARMING is?
youtube - Arnie the pump
Also - SLDL is not in starting strength. the program listed on the earlier pages is not from starting strength.
edit - seems all your injuries/twinges etc come from that anchor you call a motor.
Fit a VH45 and win at life.
Edited by TTT
Bad luck. Start out with a compound movement. That's what warm up sets are for. Your crunches are doing nothing but costing you good lifts, so stick them at the end. I stretch my arms and then it's straight into an 85kg bench for 10 reps. What makes me better than you, captain crunch?
Warm up sets arguably cost good lifts too...
I'm surprised, I thought you guys would be into warming up, good way to avoid injury which is why i do it now, that and being 30 means I'm not as injury resistant as I used to be.
Edited by ActionDan
Haven't trained abs in years cause I know squatting uses your core like a motherf**ker. Good thing is most compound movements will work your core since that area is for stability.
The program listed is something Markos put together for beginners to lifting.
Starting Strength has even less volume and therefore less pump so you'd go crazy.
Edit - doing crunches is not a warm up for any exercise.
how would doing multiple bending of the middle be a warm up for anything you will use during any of the exercises listed in the program?
Edited by TTT
We do warm up, with warm up sets.
Can you explain how crunches are going to stop a shoulder injury from bench or a leg injury in deads and squats? If anything they are more likely to cause injury, because you are weakening your core before doing big lifts. You need to have a tight core during squats and deads else you can end up with injury when you're going heavy. Warm up by doing the exercise lightly...you're not going to hurt anything by doing this.
It's like I said in my previous post, there's a whole heap of stuff you're misattributing to success...need to break the mental barriers.
    • I get that taking off the head is best but that's a bit much for "just" valve seals. I was just under the impression that one would be able to rotate to TDC and be able to temporarily drop the valve without losing it and effectively having to remove the head to then recover it. I never knew people actually pushed rope into the cylinder to do valve seals hahaha So just to confirm, just going to TDC will not work? In that case I know when I do valve seals I'll maybe just remove the head and do some other things while I'm there, or just wait until I do an engine build.
    • The old approach was to fill the cylinder/chamber with a length of rope pushed in through the sparkplug hole. The new approach is to connect compressed air to the sparkplug hole and fill it with enough pressure to push the valves up. Doing either of these things with the head on and the engine in the car is a lot less pleasant than doing it properly.
    • Can't you put the pistons to TDC and then do the valve seals? Or will the drop down too far to pull them back up?
    • One thing I can tell you is, do it properly the first time. If you encounter unexpected problems just let the car sit for a week or two if you have to get some other parts or figure stuff out.  I'd have said go and use as many OEM parts as possible but since you want to change the turbo later on a custom kit is probably the better choice. Since I have no experience with RB25 just compare parts diagrams and images before buying a line kit and it should be easy to see if it has everything you need. Amayama has very good parts diagrams and part number lists, that is what I used a bunch to figure out what I might need. And don't forget to plan ahead and possibly renew other stuff that's easy to get to while you're in there doing the turbo lines. Happy wrenching
    • Update 4:   Hi all, good news. Engine is running and all the gaskets and seals seem to be working as intended. No leaks so far, even the JB Weld seems to hold. I flushed out the old coolant a few times and put in fresh coolant, not Nissan stuff, I decided to try the Ravenol Protect FL22, they claim it works for a wide variety of JDM cars and the opinions on it by some people were pretty good. And it has the nice poison green color! And man am I glad I bought a coolant system tester earlier this year, vacuum filling works wonders on this engine. I can definitely recommend this to anyone still doing it the old school way. All you need is compressed air supply. Will have to do a small test drive as soon as I can, I removed the gauge cluster again as the tacho needle was still bouncing around a bit but it was much better than before already.  I also found some cracks on all 4 tires inner and outer sidewalls. Apparently these tires should 't be parked on for extended periods or be kept under 0 degrees during storage, which I did not know. Clearly the previous owner didn't look into those details either, he probably bought them just cause they are cool semi-slicks. I'm just wondering how tf I am supposed to reach 30-80 degree tire temperatures on the public road consistenly, these tires were never going to work for my use case. I'll probably order Continental SportContact7 ones as these are the best allround summer tire available right now and I don't think I'll need anything crazier for now. Do let me know if you have experience with various tires and which ones you recommend.
