I'm not a diet expert.
There are many that are that you can find on the net.
But if you want my opinion in it's simplest form.
animals and vegetables = 90%
wheat/grain related stuff = 10%
beef, lamb, chicken, fish, pork (if you are an infidel), turk3y, roo, emu etc etc
vegetables of all colours.. the more colours the better.
the way you described the pizza and wrap make them sound much better than how I pictured them initally.
If you are happy with your diet, then fine.
But if you are hitting a platue, it will most likely be diet or rest related.
  • Replies 119
I would say my diet may be a touch carb heavy some times but is otherwise not bad, I think sleep is a big part, but honestly how can you make yourself sleep better.
I've started going to bed earlier but my real issue is waking up repeatedly be it from temp or being uncomfortable.
Just reading about that, cheers for the suggestion.
Anyone here have experience with it? Supp for more naturally occurring?
A quick read shows foods only contain low amounts.
Its unfair to call it a diet, its just crap he shoves in his mouth
Tolga is a young Markos lol
He too will one day learn the term "wasting your time"
But for now, he needs to experience this
Amusing thread
I was waiting for you to pop in, I just thought you'd have more to add lol
I'll admit I do not follow a strict eating regime, I just try and be mindful of fats and sugars, don't eat too much or too little. As I said earlier, I'm not out to set the weight lifting world on fire. I'm not sure I need to be too hardcore to get what I'm after, but perhaps my goals are much further down the ladder than others.
I'd of thought the preference would be that someone puts it all out there, takes the advice on board and looks to do it better, rather than having another person doing it wrong, or worse, telling others that what they do is right/better when it's not.
Give me some credit :D
Edited by ActionDan
ok serious response.
you have hit a platue where you can bench 87kg for 3 sets of 8, but when you do 88kg, you get 2 sets of 8 and 2 set of 7 right?
this is your platue?
do 88kg for 2 sets.
then wait 3 minutes and do the last set.
problem solved.
your platue isn't really a platue of strength, it's more about recovery in between sets.
just rest more man.... you're at home anyway, not like someones going to come up and ask if you've finished curling in the squat rack.
other choices.
reduce the weight to 80kg and do 10-12 reps
increase the weight to 90 and do 5 reps
increase it to 100 and do 1 or 2 reps.
then after a few weeks go back to 88kg and do 3 x 8 with your designated rest times (which you seem to find important)
The designated rest times are only "important" because I like to not be in the gym foreve. 60-70mins is already enough, I'd be happier with 50-60 which I'd say is do-able with that different routine as there's less time wasted moving plates.
I can work around the bench "plateau" so to speak, but it'll all go out the window next week when I give this different routine a whirl, even if it turns out not to be for me, still better than lifting zero.
Curling in the squat rack, god damn lol that comes up in every pet peeves at the gym thread ever.
Seems there's more issues with the routine that just my recovery times, so I'll mix it up and try some new things, I'm old enough now that if I go a bit backwards in numbers for a bit that's fine with me.
I train at home too mate.
Here is what I have.
1 x shitty "ol Rusty" power cage.
1 x budget olympic barbell
1 x shitty adjustble bench (this is really shitty and will be replaced with a simple flat bench soon)
Lots x weight plates of varying sizes.
all sits outside under the patio.
All get used and abused nightly.
If there is an exercise that I can do on there, it's not worth doing.
No dumbbells, no cables, no bros.
That routine that Brids pasted is one that Markos put together as a "beginners program" some years back.
nothing magical about it. MATE where is this?? hehe.
What approach are people taking to deloading in terms of frequency.
I always get sucked into thinking one more session then I'll take a break but it never happens.
    • First up, I wouldn't use PID straight up for boost control. There's also other control techniques that can be implemented. And as I said, and you keep missing the point. It's not the ONE thing, it's the wrapping it up together with everything else in the one system that starts to unravel the problem. It's why there are people who can work in a certain field as a generalist, IE a IT person, and then there are specialists. IE, an SQL database specialist. Sure the IT person can build and run a database, and it'll work, however theyll likely never be as good as a specialist.   So, as said, it's not as simple as you're thinking. And yes, there's a limit to the number of everything's in MCUs, and they run out far to freaking fast when you're designing a complex system, which means you have to make compromises. Add to that, you'll have a limited team working on it, so fixing / tweaking some features means some features are a higher priority than others. Add to that, someone might fix a problem around a certain unrelated feature, and that change due to other complexities in the system design, can now cause a new, unforseen bug in something else.   The whole thing is, as said, sometimes split systems can work as good, and if not better. Plus when there's no need to spend $4k on an all in one solution, to meet the needs of a $200 system, maybe don't just spout off things others have said / you've read. There's a lot of misinformation on the internet, including in translated service manuals, and data sheets. Going and doing, so that you know, is better than stating something you read. Stating something that has been read, is about as useful as an engineering graduate, as all they know is what they've read. And trust me, nearly every engineering graduate is useless in the real world. And add to that, if you don't know this stuff, and just have an opinion, maybe accept what people with experience are telling you as information, and don't keep reciting the exact same thing over and over in response.
