Hey Guys,
Just wanted to see if anyone else with a v35 coupe (mines 2004) experience problems with their air con?
Mine seems to work fine most of the times i use it whether it be on a 20 degree day or 28 degrees but it seems to stop working anything above 30 degrees?
Like it would start working for a while and then blow out hot air, and it seems to be more frequent when I come to a stop? it seems like it works then stops to recharge itself and then blow cold air again after maybe 10 mins or so?
Please advise what the problem could be? or is it cause its just too hot that the aircon stops running, that and cause its a black car? LOL annoying when im sitting in the car melting....
thanks
https://www.sau.com.au/forums/topic/420204-air-conditioning-issues/
Sounds like one of both of your thermo fans is not working (or not working properly). I have a black 03 coupe and over 35 degrees the a/c will click off if I sit around idling for 10 minutes or more, but it is fine no matter what length of time I idle under 35 degrees. If your thermos are working, perhaps try getting some compressed air onto you radiator and your a/c radiator - the a/c radiator particularly could be full of bugs or dirt, and is not working effectively. Then get your gas checked - there is every chance your gas is low, thus reducing the effifiency of your a/c and making it work too hard - hence shutting off due to heat earlier than usual.
If it is stinking hot and I am planning on idling for an extended period (or the car is really hot), I will often pop the bonnet and pour/spray water out of a water bottle onto the a/c radiator - makes it work 100% better for a short period of time - the air comes out ICY.
^^ what he said..
Sounds like the condensor isn't getting rid of the heat and the AC system is tripping off on high pressure. As Andrew said.. check thermo fans first.. then check the front of the condensor for bugs/leaves/sticks/etc..
The system won't work as well at idle, and the air probably warms up a little between the evaporator and the outlet.. the temp sensor, post evaporator on my old J30 Maxima used to hit 4 deg.
About 10+ years back I had a car with air-con but without climate control. When I got the air-con re-gassed, the shop would test it with the windows closed and on re-circulate, and the temp coming out of the vents would drop to 4 deg. Things have definitely changed over the years...
The V35 also uses a variable displacement compressor, so it can adjust the cooling power based on requirements. the older style compressors were just on or off.. full cooling power, or none at all, even if they had climate control.
  • 4 weeks later...
Hi guys i encountered a major issue yesterday i was driving the v35 coupe in 30 degree temperatures with the a/c on full blast and then o noticed smoke coming from the front right hand side of the engine bay and the temp gauge was at HIGH i opemd the bonnet and noticed the coolant fluid was bubbling.... could you please advise what the problem could be, i havent had the chance to take it to the mechanic as yet.... hope its an easy fix this is a result of the above issue i had previously with the ac thanks
I think coolant was changed roughly 10k ago? But through reserch there seems to be afew issuesthat could be the cause
Thermostat blocked? Fan clutch? Air bubbles? Fan? Condenser clogged i really want to know what the issue is so i can try amd fix it first rathen thn take it straight to the garage
It is very hard to flush the coolant system, unless you know where the drain bung for the block is located. The thermostat isn't hard to remove and test, mind you the kettle doesn't get the water hot enough, you would need to stick it in a pot on the stove.
I would try a thorough system bleed, topping up the rear bleed point (heater pipe near the firewall) when cold, you may need to do it a few mornings to get all the air out. Beware, the bleed point is a plastic Philips head, and is very easy to strip.
Not without the car here. If you want the system bled properly, see if Craig (Jetwreck) can help. Otherwise go to the mechanic, perhaps get him to do a carbon test on the radiator bubbles just to rule out the head gasket while you are there.
These engines are quite hard to bleed, most mechanics won't do it right. It can take a few days (hot/cold cycles and driving) to get all the air out.
    • Good morning all, Bit of a random question but figured I’d finally throw it out after wondering for a long while. Before I start, I'm hoping to do this purely out of personal preference. I think it would look better at night, and don't mind at all spending a few hours and dollars to get it done. I've copied this from a non-Skyline specific forum, so I apologize for the explanation of our headlight switch setup that we all know. Here we go: Zero lights (switch off) Parking lights (switch position 1) being a rectangular marker on the outside of the housing, my low beam being the projector in the centre (position 2), and a high beam triggered by my turn signal stalk. Most North American cars I’ve owned of this era have power to the amber corner (turning indicator) light as part of the first switch (parking lights). I’d love to have these amber corners receive power when the headlights and parking lights are on (headlight switch), yet still blink when using the turn signal which is of course a separate switch. Hopefully I’ve explained my question correctly. Is anyone aware of a way in which I might be able to achieve this? Thanks in advance
    • My heads are cathedral port! It's likely possible, but I don't want to add any extra moving parts (I know they don't move) between the heads, manifolds, etc. It will also affect how injectors/fuel rails etc sit and I don't really know if it would change how the FAST manifold goes/sits/fits. I have the LS6 steam pipes already as I have a very late LS1 block so it should be fine. I couldn't find anyone who had ever actually used one for this purpose, it seems 100% of people grind the water pump. The thermal spacers are 12mm and are half way to the cost of the newer water pump anyhow... so if it comes to that I suppose I'd rather buy a new pump. The bearing in the pump I do have is a little.. clunky, but it hasn't done that much time and I never noticed it when the car was together in the past few years, so..
    • The bushing has failed, not all that uncommon for a car of this age.  Any mechanic should be able to push in a new bushing for you, or you can probably buy the entire lower control arm, complete with bushes.
    • Could you not use "thermal" spacers to give the clearance, like the ones I used between the blower and head? That raised the manifold height by around 10-15mm Albeit the ones I used were for cathedral ports, but I assume they have similar for rectangular ports????
    • Thanks Paul I reached out to Autotainment but they no longer work on JDM cars as the guy who used to do the work moved on and is no longer doing that kind of work. I am talking with Level Up Audio though.
