ive been playing with my 98 GTT a bit lately... new 3" turbo back and a couple of other replacement items.
ive just scored a stock XR6T front mount for the right price ($0 to be exact) and wodered if it would provide any gains over the standard item?
it will be a no cost mod as i have plenty of pipes and joiners at work, but ultimately would it be worth fitting up???
any advice is appreciated.
thanks in advance
Matt
if you are running stock boost and stock turbo then the gain would be minimal IMO.
Also if you plan on mounting it in the factory location i think you might find it worse as the airflow is directed to the stock cooler via shielding etc
happy to be corrected but i dont see it being a worth while 'upgrade', the stock cooler is good for 10-12psi for road use, track is different story
Are XR6T FMIC's return flow?
You'll have to get custom piping made up for it... and work out a way to mount it...
Probably better off getting a JJR Cooling Pro FMIC which you know will fit perfectly.
If it's a BA/BF cooler it's return flow. FG's are similar to a Gtr cooler but narrower and almost twice as tall.
If the car is fairly standard the the BA cooler might be worth it but if you plan on running more than 12psi then you need something decent.
yes its return flow
id look at mounting it up front.
as i said pipe work is no issue as i have access to a pipe bender and plenty of rubber/silicone couplings.
i do have a new turbo sitting at home for the baby ( not sure of exact specs) that came of a mates r33.
ive got new coils on the way.
i will be upgrading computer and injectors in the near future.
it was the right price so i considered putting it in since im a tight arse and would rather spend money on a computer so i can run the new turbo...
Waste of time.
The BA/BF return flow cooler will heatsoak at 240rwkw as noted. The massive FG cooler will do the same thing at about 300kw, so neither of which are worthy options.
Better off with an off the shelf cross flow china kit.
China kit - easier to install, waste less time making piping, comes with brackets will perform better
DIY kit - headache, waste more money overall once done, won't sit nice and will perform crap like others have mentioned
Should weigh it out, ling long kit will be better in terms of fitment, cost effectiveness and performance
    • Hey everyone!!  I've noticed that whenever I do my oil changes, after putting 4L in, the oil level sits at the top mark in the dipstick. This is after letting the old oil drain for a very long time too! I've checked the oil level daily for the past few mornings. It happens every time and it's confusing because all the threads say that it should take about 4.7L (With some just adding the full 5L) My next thought is to figure out if the dipstick I have is correct so could someone please tell me the length of the RB25DET engine oil dipstick?  I've checked images of some of the genuine dipsticks, but none of them have the length in it. https://justjap.com/products/genuine-nissan-engine-oil-level-dipstick-fits-nissan-r34-skyline-c34-stagea-c35-laurel-y34-cedric-gloria-rb25de-t-neo?currency=AUD&srsltid=AfmBOortQXofgmiHVRKuIaiKuygL4k0Ewp68c3isGZk0vvKOJ7Yqf3iB However.... the engraving on the genuine ones say 05002 while mine says AA000. This makes me believe that maybe I have a wrong dipstick? I just want to confirm before I buy a new one. The car is a fresh import from Japan so I don't have details of the previous owner to ask him. Thanks in advance 🙏🏾
    • Sport. I didn’t rebleed it cause I just removed the slave and left connected.    I will change line and slave and see how it goes.
    • Oh and how is the rattle when foot is on the clutch ?
    • Did you get the sport or track ? From what the documentation says the uniclutch has a small amount of movement to disengage.  So your story of tricky pedal setup seems common.    Hopefully you got it bled up too, as the bite point moving around is usually either plates wearing in or air in the line.
    • There's always "MIG it up and grind it back".
