Wrecking a 1998 R34 GTT Coupe. All parts are available minus the engine with ancillaries and gearbox. All parts are in good working condition unless stated otherwise.
Pick-up is from Emerald, Victoria and postage is available for items which meet Auspost size/weight restrictions.
1. Complete engine loom and computer - $250
http://i160.photobucket.com/albums/t177/Shano3000/P1040211.jpg
2. Front brake calipers and rotors, plenty of meat left on both pads and rotors - $300
http://i160.photobucket.com/albums/t177/Shano3000/P1040176.jpg
3. Rear brake calipers and rotors, plenty of meat left on both pads and rotors - $200
http://i160.photobucket.com/albums/t177/Shano3000/P1040222.jpg
4. Factory 17" wheels. Very good condition with only minor gutter rash. Tyres are 98% new Triangle, TR967, 235/45/ZR17. If you're ready for new tyres on your stock R34 GTT rims would be cheaper to buy these, then onsell your rims - $450
http://i160.photobucket.com/albums/t177/Shano3000/P1040204.jpg
http://i160.photobucket.com/albums/t177/Shano3000/P1040205.jpg
http://i160.photobucket.com/albums/t177/Shano3000/P1040206.jpg
5. Rear subframe with diff. Includes rear cradle, diff, drive shafts, hicas, hubs, suspension components and handbrake assembly. Rear brakes have been removed - $350
http://i160.photobucket.com/albums/t177/Shano3000/P1040224.jpg
http://i160.photobucket.com/albums/t177/Shano3000/P1040226.jpg
6. 3" complete turbo back exhaust. Includes 3" Cat back exhaust with cannon muffler and silencer, 3" Cateran high flow catalytic converter and 3" bell mouth dump/front pipe. Has some scratches on the muffler and dints in the silencer. Muffler tip has been shortened. Complete bolt in system - $370
http://i160.photobucket.com/albums/t177/Shano3000/P1040184.jpg
http://i160.photobucket.com/albums/t177/Shano3000/P1040185.jpg
http://i160.photobucket.com/albums/t177/Shano3000/P1040186.jpg
http://i160.photobucket.com/albums/t177/Shano3000/P1040187.jpg
7. Factory front bar. Structurally in good condition, paint has blemishes as shown in pictures. Middle air vents have been removed for FMIC placement - $300
http://i160.photobucket.com/albums/t177/Shano3000/P1040156.jpg
http://i160.photobucket.com/albums/t177/Shano3000/P1040155.jpg
http://i160.photobucket.com/albums/t177/Shano3000/P1040157.jpg
8. Factory struts, complete set - $200
http://i160.photobucket.com/albums/t177/Shano3000/P1040215.jpg
9. Factory front adjustable strut brace - $50
http://i160.photobucket.com/albums/t177/Shano3000/P1040183.jpg
10. Excedy replacement clutch. minimal use, would estimate at 90%+ meat left on clutch plate. No scoring on pressure plate. Comes without thrust bearing - $300
http://i160.photobucket.com/albums/t177/Shano3000/P1040241.jpg
http://i160.photobucket.com/albums/t177/Shano3000/P1040240.jpg
11. Flywheel. No scoring - $70
http://i160.photobucket.com/albums/t177/Shano3000/P1040242.jpg
12. Tail shaft (Manual) - $150
http://i160.photobucket.com/albums/t177/Shano3000/P1040154.jpg
13. Gearbox X-member - $50
http://i160.photobucket.com/albums/t177/Shano3000/P1040195.jpg
12. Manual pedal setup with clutch slave/master cylinders and lines. Includes clutch and brake pedal for conversion - $200
http://i160.photobucket.com/albums/t177/Shano3000/P1040212.jpg
13. Power window motors. Left and right hand side (Coupe) - $100each
http://i160.photobucket.com/albums/t177/Shano3000/P1040161.jpg
14. Ignition, locks and key set. Includes ignition barrel, L+R door locks, boot lock and original factory key - $220
http://i160.photobucket.com/albums/t177/Shano3000/P1040175.jpg
15. Door shells. Painted white, locks and window motors have been removed. Glass included. Passengers door has 2 small pin dents - $100each
http://i160.photobucket.com/albums/t177/Shano3000/P1040198.jpg
http://i160.photobucket.com/albums/t177/Shano3000/P1040199.jpg
16. Drivers side power window switches and surround - $80
http://i160.photobucket.com/albums/t177/Shano3000/P1040163.jpg
17. Passenger side power window switch and surround - $30
http://i160.photobucket.com/albums/t177/Shano3000/P1040169.jpg
18. Mirrors. Painted white. Passenger side has 2 small marks in the paint as shown in picture - $50 drivers and $40 passenger
http://i160.photobucket.com/albums/t177/Shano3000/P1040171.jpg
http://i160.photobucket.com/albums/t177/Shano3000/P1040172.jpg
19. Steering rack - $100
http://i160.photobucket.com/albums/t177/Shano3000/P1040158.jpg
20. Indicator and wiper stalks with steering lock mechanism - $50
http://i160.photobucket.com/albums/t177/Shano3000/P1040202.jpg
21. Steering wheel with airbag. Has minor signs of wear at one leather joint - $180
http://i160.photobucket.com/albums/t177/Shano3000/P1040146.jpg
http://i160.photobucket.com/albums/t177/Shano3000/P1040148.jpg
22. Dashpad with airbag set-up - $250
http://i160.photobucket.com/albums/t177/Shano3000/P1040180.jpg
http://i160.photobucket.com/albums/t177/Shano3000/P1040181.jpg
23. Middle dash gauges - $150
http://i160.photobucket.com/albums/t177/Shano3000/P1040165.jpg
24. Climate control - $120
http://i160.photobucket.com/albums/t177/Shano3000/P1040167.jpg
25. Seats. Have some minor staining which could be removed with a clean. Material has no rips or tears - $180set or $80 for each front seat and $40 for rear seats individually
http://i160.photobucket.com/albums/t177/Shano3000/P1040219.jpg
26. Factory nissan floor mats. Minimal signs of wear - $100
http://i160.photobucket.com/albums/t177/Shano3000/P1040152.jpg
27. Front door cards and back trim set - $150
http://i160.photobucket.com/albums/t177/Shano3000/P1040210.jpg
http://i160.photobucket.com/albums/t177/Shano3000/P1040209.jpg
28. Boot trim. Complete set, one piece has 2 small tears which are unnoticeable once fitted. Comes with about 60% of plastic screws - $150
http://i160.photobucket.com/albums/t177/Shano3000/P1040173.jpg
29. Rear spoiler. Has a scrape along drivers side edge - $50
30. Front hub assembly - $100
http://i160.photobucket.com/albums/t177/Shano3000/P1040190.jpg
40. ABS Pump - $50
http://i160.photobucket.com/albums/t177/Shano3000/P1040178.jpg
41. Lower control arms, LCA's - $50 each
http://i160.photobucket.com/albums/t177/Shano3000/P1040188.jpg
42. Castor rods - $40 each
http://i160.photobucket.com/albums/t177/Shano3000/P1040189.jpg
43. Jack and tool kit - $40
http://i160.photobucket.com/albums/t177/Shano3000/P1040207.jpg
44. Complete seatbelt set - $150
http://i160.photobucket.com/albums/t177/Shano3000/P1040218.jpg
45. Under engine cover - $40
http://i160.photobucket.com/albums/t177/Shano3000/P1040203.jpg
46. Brake master with booster - $80
http://i160.photobucket.com/albums/t177/Shano3000/P1040216.jpg
47. Manual gearstick surround - $80
http://i160.photobucket.com/albums/t177/Shano3000/P1040179.jpg
48. Space saver rear tyre - $40
http://i160.photobucket.com/albums/t177/Shano3000/P1040194.jpg
49. Factory airbox with snorkel and panel filter - $200
http://i160.photobucket.com/albums/t177/Shano3000/P1040149.jpg
50. Middle air vent and hazard light switch - $40
http://i160.photobucket.com/albums/t177/Shano3000/P1040168.jpg
51. Passenger side Xenon headlight *DAMAGED* - $50
http://i160.photobucket.com/albums/t177/Shano3000/P1040193.jpg
http://i160.photobucket.com/albums/t177/Shano3000/P1040192.jpg
52. Badge set. Also includes "SKYLINE" from rear bar (Not pictured) - $30
http://i160.photobucket.com/albums/t177/Shano3000/P1040197.jpg
53. Dash cluster surround - $30
http://i160.photobucket.com/albums/t177/Shano3000/P1040196.jpg
54. Razo turbo timer - $30
http://i160.photobucket.com/albums/t177/Shano3000/P1040200.jpg
55. Rear parcel shelf - $30
http://i160.photobucket.com/albums/t177/Shano3000/P1040208.jpg
56. Drivers and passengers side front inner plastic wheel guards - $40 each
57. JVC DVD headunit. Model KW-AVX710. Fits perfectly into the dash of an R34 - $150
http://i160.photobucket.com/albums/t177/Shano3000/P1040170.jpg
Please contact me through PM here on SAU.
Edited by Shano3000
    • Yep super expensive, awesome. It would be a cool passion project if I had the money.
    • Getting the setup right, is likely to cost multiples of the purchase price of the vehicle.
    • So it's a ginormous undertaking that will be a massive headache but will be sorta cool if pulled off right. And also expensive. I'm sure it'll be as expensive as buying the car itself. I don't think you could just do this build without upgrading other things to take the extra power. Probably lots of custom stuff as well. All this assuming the person has mechanical knowledge. I'm stupid enough to try it but smart enough to realize there's gonna be mistakes even with an experienced mechanic. I'm a young bloke on minimum wage that gets dopamine from air being moved around and got his knowledge from a Donut video on how engines work.]   Thanks for the response though super informative!
    • Yes, it is entirely possible to twincharge a Skyline. It is not....without problems though. There was a guy did it to an SOHC RB30 (and I think maybe it became or already was a 25/30) in a VL Commode. It was a monster. The idea is that you can run both compressors at relatively low pressure ratios, yet still end up with a quite large total pressure ratio because they multiply, not add, boost levels. So, if the blower is spun to give a 1.4:1 PR (ie, it would make ~40 kPa of boost on its own) and the turbo is set up to give a 1.4:1 PR also, then you don't get 40+40 = 80 kPa of boost, you get 1.4*1.4, which is pretty close to 100 kPa of boost. It's free real estate! This only gets better as the PRs increase. If both are set up to yield about 1.7 PR, which is only about 70 kPa or 10ish psi of boost each, you actually end up with about 1.9 bar of boost! So, inevitably it was a bit of a monster. The blower is set up as the 2nd compressor, closest to the motor, because it is a positive displacement unit, so to get the benefit of putting it in series with another compressor, it has to go second. If you put it first, it has to be bigger, because it will be breathing air at atmospheric pressure. The turbo's compressor ends up needing to be a lot larger than you'd expect, and optimised to be efficient at large mass flows and low PRs. The turbo's exhaust side needs to be quite relaxed, because it's not trying to provide the power to produce all the boost, and it has to handle ALL the exhaust flow. I think you need a much bigger wastegate than you might expect. Certainly bigger than for an engine just making the same power level turbo only. The blower effectively multiplies the base engine size. So if you put a 1.7 PR blower on a 2.5L Skyline, it's like turboing a 4.2L engine. Easy to make massive power. Plus, because the engine is blown, the blower makes boost before the turbo can even think about making boost, so it's like having that 4.2L engine all the way from idle. Fattens the torque delivery up massively. But, there are downsides. The first is trying to work out how to size the turbo according to the above. The second is that you pretty much have to give up on aircon. There's not enough space to mount everything you need. You might be able to go elec power steering pump, hidden away somewhere. but it would still be a struggle to get both the AC and the blower on the same side of the engine. Then, you have to ponder whether you want to truly intercool the thing. Ideally you would put a cooler between the turbo and the blower, so as to drop the heat out of it and gain even more benefit from the blower's positive displacement nature. But that would really need to be a water to air core, because you're never going to find enough room to run 2 sets of boost pipes out to air to air cores in the front of the car. But you still need to aftercool after the blower, because both these compressors will add a lot of heat, and you wil have the same temperature (more or less) as if you produced all that boost with a single stage, and no one in their right mind would try to run a petrol engine on high boost without a cooler (unless not using petrol, which we shall ignore for the moment). I'm of the opinnion that 2x water to air cores in the bay and 2x HXs out the front is probably the only sensible way to avoid wasting a lot of room trying to fit in long runs of boost pipe. But the struggle to locate everything in the limited space available would still be a pretty bad optimisation problem. If it was an OEM, they'd throw 20 engineers at it for a year and let them test out 30 ideas before deciding on the best layout. And they'd have the freedom to develop bespoke castings and the like, for manifolds, housings, connecting pipes to/from compressors and cores. A single person in a garage can either have one shot at it and live with the result, or spend 5 years trying to get it right.
    • Good to know, thank you!
