Hey guys,
Selling my REGISTERED r34 4 door for sale. rb25 neo turbo. sunroof model, manual. coil overs, rear camber arms, front castor rods, lock spacers, adjustable lcas, fmic, hks 2835, hks dump, full exhaust (needs to be raised and hangers fixed up), intake with pod, turbotech boost controller, factory gauges etc, greddy turbo timer, r33 gtrs with rsr fronts and kinforest rears, strut brace, momo 3 spoke wheel, aftermarket fuel pump, au twin thermo fans, viva garage roof spoiler.
brand new npc organic clutch put in with new oil n machined flywheel, forced motorworx locked 4.11 diff also.
body is a little rough (rear bar is slightly different silver, front gaurds have been flared, bonnet has a couple of small dints, but car is priced accordingly.
Asking 12500kono with rego. Cheapest one on the market, most are between 15k and 17k, this ones tastefully modified making around 220-230rwkw, put some injectors and tune and make 270rwkw+. Full boost around 3500, awesome turbo!
may be able to negotiate and provide a RWC to transfer it!
Located in VIC,
sms 0418578922.555809_10151523334607990_2105673571_n.jp
    • You guys need to live a little! Nothing keeps the blood flowing like lying under something that could collapse on you at any time! The vast majority of the weight of my car is out of it. There's zero attached outside of the interior of the car. It's pretty much full interior but once I take the front seats out it's just the dash and some of the boot contents remaining. I would guess that as it sits it would be already well under a tonne, even less without the seats.
    • https://www.youtube.com/watch?v=KyZDvZmvhik
    • You'd be better off digging a pit and standing under it to shoot it.
    • The easiest way would to be ignore the oscilloscope, grab a multimeter, and make sure all the main connections are right. An oscilloscope will give 99.9% of even technicians so much grief, as they have no idea what things should even look like on an oscilloscope. Which is also even more likely for someone who's first ever major work on a car is this If the battery volts are dropping down so low, the LDV will reboot the ECU, when it does so, it will drop out the start circuit. If this is occuring, the battery voltage should also come back up. Give it a few tests, even simple ones like when you're attempting to crank it, measure voltage from the engine block, to the negative terminal. You might find you've got really bad connections somewhere. My guess is the "new" motor has something like a shit starter motor, at which point, you can swap the starter motor from the old motor, to the new motor. Before I did any of the above though, I'd 100% confirm the battery in the vehicle. Most jumper packs are absolutely useless, especially if a battery has a bad cell for example. Also the new modern "jump packs" if you don't know what you're doing with them, you won't even get them into high current stage. So go back to basics, check the battery, especially with a known good one as a replacement test. Check ALL the wiring, this includes where they're bolted onto the battery, and bolted onto the starter motor. Check all the earth straps are on. Measure your resistances across your earth straps. A good check here is to measure voltage across the earth straps while you're trying to crank it. If you're seeing voltage, you've got high resistance joints! Oh, and once you've done the above, check the battery over again.
