  • Replies 121
A friend recently bought a 33 from a car yard on South Road.  The car yard owner had picked the car up at an auction in Sydney and therefore had to have the car registered in SA before he could sell it.  He told us that he simply took the car to the Sturt Police Station and it was inspected and then passed with an aftermarket blow off valve, turbo timer and 20% tint.
Another 33 he had at the yard was also passed at Sturt Police Station on a different day with extremely dark tint, EBC, blow off valve and turbo timer. The only thing he was told to remove was the dual A-pillar pod gauges.
I'm not sure why there was not a requirement for him to have these cars Regency inspected as I thought was the requirement for cars that come from interstate.
there is a regency inspection station NEXT to sturt police station that do interstate transfer inspections (ID inspections)
if it was already low volume complianced there, then they cna get it inspected for SA rego
https://www.sau.com.au/forums/topic/42029-defected/page/7/#findComment-882455
    • If you are genuinely considering trying to get this engineered, I would strongly advise finding the engineer that is happy to sign that off first before you put the hole in your car.  I've seen cars get defected for this and not be able to be put back on the road as no engineer they spoke to was happy to sign if off.
    • Apologies, while id like to put the MAF as close to the TB and relocate the recirc, this may be too much work. Will most likely end up just putting it on the original AFM spot ( onto/next to the airbox ).  Was going through nistune, found a pretty nifty doc on this. Nistune MAF Notes. Also, i was looking through the bay, and there seems to be a tube/line connected from the A/C to the intercooler piping ( Between the smic and the recirc), what does this do as the crossover fmic piping doesnt have any connection? plumbing? not sure what you call it but the nipple thing ahah.  Also, been reading up more about crossover fmic in regards to the legality of having the hole drilled for the piping, this would most likely need to be engineered right?
    • My advice is if you need a big build done do it in Japan. The yen rate is so favorable and there are shops that can be genuinely trusted and not micromanaged/carefully monitored every step of the way. Garage Yoshida is obviously my preferred option but they're so busy these days and all interaction with new customers has to be mediated through BBL/Toprank now.
    • I haven't....but a poorly made one would terrify me. Surely a good second hand one is the go, as they don't work hard and no-one wants to keep one after they are finished with it A big consideration would be the weight of the shell you are putting on it....is it a fully dressed chassis or just the body
