Hi guys,
I'm after another Stagea (had a S1 RS4 with all the fruit) but we upgraded to an Elgrand for the extra room. Now we are a different state and much better incomes, so it's time to get another one for me!
I want a factory manual S2, but not the 260RS model. I'll settle for the RB25DET Neo...it's only going to be a daily and will never see track time. Would like dual sunroofs and leather, but not quite deal breakers! No yellow paint, will consider most but not fussed on silver. Prefer stock as possible as I cant be stuffed dealing with transport here in Kalgoorlie. Inspections need to be done in Perth.
Sorry for being fussy. Where is the best place to start my search? I've tried scouring here, and Carsales.com.au but is there anywhere else I should be looking?
Thanks in advance,
Cheers, Greg.
https://www.sau.com.au/forums/topic/420291-buying-a-stagea/
    • Holy hell! That is absolutely stunning! Great work!!!
    • It does when you start adding everything else in. But it's not just compute. It's the logic. Getting your timing right (I'm not meaning ignition timing for the engine). Making sure of your memory mappings, seeing your interrupts. Microcontroller devices only have so much capacity. For the most part, you want all those timers and interrupts in use on your engine control, which means you're left with less than ideal methods for timing and management of other control functions.   Let's put it this way, my job is all about building custom hardware, that goes into cars, and integrates with them. We're also waiting on a media confirmation from SpaceX too fora world first we've just completed with them in NZ too. It's not just the little toys I play with. But you know, you can think and believe what you want.
    • I don't think it's a good buy, the trend looks bad     lol.
